void receive not work with RelayActuator.ino ?
  • Hi all,
    I don't understand a problem,
    My receive function is not working in the sktech relayActuator.ino
    If I simply add the following code :
       Serial.print("--- Incoming Message ---");
      if (message.getType()==V_STATUS) {
    I never have anything.
    But in the node logs I do receive the information:
    Relay OFF :
    345110 TSF:MSG:READ,0-180-162,s=180,c=3,t=6,pt=0,l=1,sg=0:0
    Relay ON:
    355655 TSF:MSG:READ,0-180-162,s=180,c=3,t=6,pt=0,l=1,sg=0:1
    For information I use a gateway+W5100 in MQTT.
    An idea why the receive function is not working here ?
    Thank you all
  • @yourry Don't use serial print inside the receive function.
    instead set a variable in receive and test for that in the main loop and then send serial from the main loop.
    This is probably all the problem is........ probably....... 😉
  • Thanks for the answer, I keep the advice.
    Finally I looked for a while and the problem was with the MQTT publish syntax.
    It works perfectly, the difficulty is to find the right publish MQTT request.
    Thank you.
  • Mod
    @skywatch said in void receive not work with RelayActuator.ino ?:
    Why not? Receive doesn't run in interrupt context, so it should be safe to serial print from it...
  • @Yveaux I'm sure it's in the forum posts somewhere but I don't have time to look for it.
    Maybe you could do a list of what is and isn't possible in void receive to mitigate further confusions?
  • 10
  • 1
11.3k
