@andriej
Hi, I had problem using the main branch mysensors/Raspberry, that because of the bit-field struct (header_s) in Sensor.h They will get packed in different order on the arduino compared to the RPi (at least with my compiler, gcc). In order to fix this I created the 1.4dev branch. It uses full bytes instead of the bit-fields, but you need (of cause) to compile both the sensors (arduino) and the gateway (RPi) using the 1.4dev branch.
We need to fix this in the main branch later on (and use the same files as in mysensors/Arduino/libraries/MySensors)
@skywatch said in Awesome tip: run LinuxFX instead of Windows!:
@NeverDie Thanks - Interestingly they show a free version on their site still. Did they revert due to bad publicity?
https://www.linuxfx.org/
I stopped following it, but I seem to recollect that the free version was noticeably missing things--otherwise, who'd buy the paid-for version? Anyway, its standing on Distro-watch has fallen considerably. It may seem unfair to niche distros, but I think it's generally better to stick with the more popular distros, unless you have good reason to choose otherwise.
@OldSurferDude My old 2.0 setup is with nRF24L01 radios. This is a link to the thread on some light switches that I designed and built.
https://forum.mysensors.org/topic/7376/us-decora-wall-switch-continued/2
I am aware that you cannot have two MQTT gatways. When I designed my old setup I was not that familiar with MQTT so I never ended up implementing it. On the home assistant server that I have set up though, I have installed the MQTT broker on there so I should be able to comunicate with any MySensors stuff over MQTT in the future devices I make/set up. As I mentioned, I do have a Home Assistant box that I have started about 4 months ago and eventually want to migrate my Vera equipment to the HA box.
As for the YAML and Python, I'll muddle my way through. used to program in PHP and have done enough on Arduino that I'm sure it won't hurt my brain too much.
Of possible interest: Here's a guy who is building an inexpensive open source ethernet controller for stepper motors:
What happend to Ethersweep? Project Update! – 12:36— Neumi
If you listen to the end, it's revealed that there is now generous funding available which allows people to do this kind of open-source development as a full time job, which is what he is now doing. For that reason, I think there's a good chance he will complete his project within the allowed 6 months., and so by the deadline it will likely be nicely polished.
