15 blinds driver at Mega2560 - Domoticz synchronisation problem
  • Hi,
    I made a blinds driver (30 relays, 15 buttons) to go with Domoticz. I am using Mega2560 as MySensors board to communicate with Domoticz at RaspberryPi 4. Code below:
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #include <Bounce2.h>
    #define MY_REPEATER_FEATURE
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  5
    #define RELAY_3  6
    #define RELAY_4  7
    #define RELAY_5  8
    #define RELAY_6  9
    #define RELAY_7  10
    #define RELAY_8  11
    #define RELAY_9  22
    #define RELAY_10  23
    #define RELAY_11  24
    #define RELAY_12  25
    #define RELAY_13  26
    #define RELAY_14  27
    #define RELAY_15  28
    #define RELAY_16  29
    #define RELAY_17  30
    #define RELAY_18  31
    #define RELAY_19  32
    #define RELAY_20  33
    #define RELAY_21  34
    #define RELAY_22  35
    #define RELAY_23  36
    #define RELAY_24  37
    #define RELAY_25  38
    #define RELAY_26  39
    #define RELAY_27  40
    #define RELAY_28  41
    #define RELAY_29  42
    #define RELAY_30  43
    #define NUMBER_OF_RELAYS 30 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define BUTTON_PIN A1
    #define BUTTON2_PIN A2
    #define BUTTON3_PIN A3
    #define BUTTON4_PIN A4
    #define BUTTON5_PIN A5
    #define BUTTON6_PIN A6
    #define BUTTON7_PIN A7
    #define BUTTON8_PIN A8
    #define BUTTON9_PIN A9
    #define BUTTON10_PIN A10
    #define BUTTON11_PIN A11
    #define BUTTON12_PIN A12
    #define BUTTON13_PIN A13
    #define BUTTON14_PIN A14
    #define BUTTON15_PIN A15
    void before() {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
    Bounce debouncer3 = Bounce();
    Bounce debouncer5 = Bounce();
    Bounce debouncer7 = Bounce();
    Bounce debouncer9 = Bounce();
    Bounce debouncer11 = Bounce();
    Bounce debouncer13 = Bounce();
    Bounce debouncer15 = Bounce();
    Bounce debouncer17 = Bounce();
    Bounce debouncer19 = Bounce();
    Bounce debouncer21 = Bounce();
    Bounce debouncer23 = Bounce();
    Bounce debouncer25 = Bounce();
    Bounce debouncer27 = Bounce();
    Bounce debouncer29 = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      pinMode(BUTTON2_PIN, INPUT_PULLUP);
      pinMode(BUTTON3_PIN, INPUT_PULLUP);
      pinMode(BUTTON4_PIN, INPUT_PULLUP);
      pinMode(BUTTON5_PIN, INPUT_PULLUP);
      pinMode(BUTTON6_PIN, INPUT_PULLUP);
      pinMode(BUTTON7_PIN, INPUT_PULLUP);
      pinMode(BUTTON8_PIN, INPUT_PULLUP);
      pinMode(BUTTON9_PIN, INPUT_PULLUP);
      pinMode(BUTTON10_PIN, INPUT_PULLUP);
      pinMode(BUTTON11_PIN, INPUT_PULLUP);
      pinMode(BUTTON12_PIN, INPUT_PULLUP);
      pinMode(BUTTON13_PIN, INPUT_PULLUP);
      pinMode(BUTTON14_PIN, INPUT_PULLUP);
      pinMode(BUTTON15_PIN, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer3.attach(BUTTON2_PIN);
      debouncer3.interval(5);
      debouncer5.attach(BUTTON3_PIN);
      debouncer5.interval(5);
      debouncer7.attach(BUTTON4_PIN);
      debouncer7.interval(5);
      debouncer9.attach(BUTTON5_PIN);
      debouncer9.interval(5);
      debouncer11.attach(BUTTON6_PIN);
      debouncer11.interval(5);
      debouncer13.attach(BUTTON7_PIN);
      debouncer13.interval(5);
      debouncer15.attach(BUTTON8_PIN);
      debouncer15.interval(5);
      debouncer17.attach(BUTTON9_PIN);
      debouncer17.interval(5);
      debouncer19.attach(BUTTON10_PIN);
      debouncer19.interval(5);
      debouncer21.attach(BUTTON11_PIN);
      debouncer21.interval(5);
      debouncer23.attach(BUTTON12_PIN);
      debouncer23.interval(5);
      debouncer25.attach(BUTTON13_PIN);
      debouncer25.interval(5);
      debouncer27.attach(BUTTON14_PIN);
      debouncer27.interval(5);
      debouncer29.attach(BUTTON15_PIN);
      debouncer29.interval(5);
      //presentation();
        present(sensor, S_LIGHT);
    MyMessage msg(1, V_LIGHT);
    MyMessage msg2(2, V_LIGHT);
    MyMessage msg3(3, V_LIGHT);
    MyMessage msg4(4, V_LIGHT);
    MyMessage msg5(5, V_LIGHT);
    MyMessage msg6(6, V_LIGHT);
    MyMessage msg7(7, V_LIGHT);
    MyMessage msg8(8, V_LIGHT);
    MyMessage msg9(9, V_LIGHT);
    MyMessage msg10(10, V_LIGHT);
    MyMessage msg11(11, V_LIGHT);
    MyMessage msg12(12, V_LIGHT);
    MyMessage msg13(13, V_LIGHT);
    MyMessage msg14(14, V_LIGHT);
    MyMessage msg15(15, V_LIGHT);
    MyMessage msg16(16, V_LIGHT);
    MyMessage msg17(17, V_LIGHT);
    MyMessage msg18(18, V_LIGHT);
    MyMessage msg19(19, V_LIGHT);
    MyMessage msg20(20, V_LIGHT);
    MyMessage msg21(21, V_LIGHT);
    MyMessage msg22(22, V_LIGHT);
    MyMessage msg23(23, V_LIGHT);
    MyMessage msg24(24, V_LIGHT);
    MyMessage msg25(25, V_LIGHT);
    MyMessage msg26(26, V_LIGHT);
    MyMessage msg27(27, V_LIGHT);
    MyMessage msg28(28, V_LIGHT);
    MyMessage msg29(29, V_LIGHT);
    MyMessage msg30(30, V_LIGHT);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (debouncer3.update()) {
          int value3 = debouncer3.read();
        if(value3 == LOW){
             saveState(3, !loadState(3));
             digitalWrite(RELAY_3, loadState(3)?RELAY_ON:RELAY_OFF);
             send(msg3.set(loadState(3)));
       if (debouncer5.update()) {
          int value5 = debouncer5.read();
        if(value5 == LOW){
             saveState(5, !loadState(5));
             digitalWrite(RELAY_5, loadState(5)?RELAY_ON:RELAY_OFF);
             send(msg5.set(loadState(5)));
      if (debouncer7.update()) {
          int value7 = debouncer7.read();
        if(value7 == LOW){
             saveState(7, !loadState(7));
             digitalWrite(RELAY_7, loadState(7)?RELAY_ON:RELAY_OFF);
             send(msg7.set(loadState(7)));
      if (debouncer9.update()) {
          int value9 = debouncer9.read();
        if(value9 == LOW){
             saveState(9, !loadState(9));
             digitalWrite(RELAY_9, loadState(9)?RELAY_ON:RELAY_OFF);
             send(msg9.set(loadState(9)));
      if (debouncer11.update()) {
          int value11 = debouncer11.read();
        if(value11 == LOW){
             saveState(11, !loadState(11));
             digitalWrite(RELAY_11, loadState(11)?RELAY_ON:RELAY_OFF);
             send(msg11.set(loadState(11)));
      if (debouncer13.update()) {
          int value13 = debouncer13.read();
        if(value13 == LOW){
             saveState(13, !loadState(13));
             digitalWrite(RELAY_13, loadState(13)?RELAY_ON:RELAY_OFF);
             send(msg13.set(loadState(13)));
      if (debouncer15.update()) {
          int value15 = debouncer15.read();
        if(value15 == LOW){
             saveState(15, !loadState(15));
             digitalWrite(RELAY_15, loadState(15)?RELAY_ON:RELAY_OFF);
             send(msg15.set(loadState(15)));
      if (debouncer17.update()) {
          int value17 = debouncer17.read();
        if(value17 == LOW){
             saveState(17, !loadState(17));
             digitalWrite(RELAY_17, loadState(17)?RELAY_ON:RELAY_OFF);
             send(msg17.set(loadState(17)));
      if (debouncer19.update()) {
          int value19 = debouncer19.read();
        if(value19 == LOW){
             saveState(19, !loadState(19));
             digitalWrite(RELAY_19, loadState(19)?RELAY_ON:RELAY_OFF);
             send(msg19.set(loadState(19)));
             Serial.println("19 zmiana");
      if (debouncer21.update()) {
          int value21 = debouncer21.read();
        if(value21 == LOW){
             saveState(21, !loadState(21));
             digitalWrite(RELAY_21, loadState(21)?RELAY_ON:RELAY_OFF);
             send(msg21.set(loadState(21)));
       if (debouncer23.update()) {
          int value23 = debouncer23.read();
        if(value23 == LOW){
             saveState(23, !loadState(23));
             digitalWrite(RELAY_23, loadState(23)?RELAY_ON:RELAY_OFF);
             send(msg23.set(loadState(23)));
       if (debouncer25.update()) {
          int value25 = debouncer25.read();
        if(value25 == LOW){
             saveState(25, !loadState(25));
             digitalWrite(RELAY_25, loadState(25)?RELAY_ON:RELAY_OFF);
             send(msg25.set(loadState(25)));
       if (debouncer27.update()) {
          int value27 = debouncer27.read();
        if(value27 == LOW){
             saveState(27, !loadState(27));
             digitalWrite(RELAY_27, loadState(27)?RELAY_ON:RELAY_OFF);
             send(msg27.set(loadState(27)));
       if (debouncer29.update()) {
          int value29 = debouncer29.read();
        if(value29 == LOW){
             saveState(29, !loadState(29));
             digitalWrite(RELAY_29, loadState(29)?RELAY_ON:RELAY_OFF);
             send(msg29.set(loadState(29)));
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    It works fine, however I have a synchronisation problem. When there is a power loss, Arduino restores relay states form EEPROM, using this line:
    Domoticz seems to have its own way to remeber what relays were on. When power is restored there is a mismatch between arduino EEPROM data and domoticz. Is there any way to fix this? I was thinking 2 ways: either resend all relay statuses right after restoring them from arduino EEPROM or download on/off status from domoticz? I would actually prefer the first method. How can it be done?
  • Contest Winner
    You could send the blinds statess to Domoticz in the presentation method. My experience is that my setup doesn't like it when I send a lot messages to the gateway. So I use some small delays between each message I send from the node to the gateway, I didn't have time to look at your sketch. But here's some pseudo code:
    void presentation() {
         ... // the presentation code goes here.
          for ( int = 0; i < BLINDS_COUNT; i++ ) {
                send( message for blinds i, state of blinds i );
                delay( 50 ); // or do less it's a bit of trial and error.
    In your case using random delays might be better, because you send 15 states with a delay of 50ms. So it takes at least 750ms to send all values. Adding the delay will also give other nodes time to interact with Domoticz.
  • 1
  • 10
  • 24
