MySensors Error received
  • I am getting this error about every 20 minutes from my gateway and it appears to be happening to all of my sensors. I am running all of my devices including the USB gateway on MySensors library 2.3.2. The gateway is connected to a Perceptive Automation Indigo home controller. Any ideas? A snip of the log is below:
    2022-11-26 16:38:11.012 MySensors Error received '17:255' NoneNone0 failed: item type not found
    2022-11-26 17:18:06.844 MySensors Error received '60:255' NoneNone0 failed: item type not found
    2022-11-26 17:18:11.917 MySensors Error received '100:255' NoneNone0 failed: item type not found
    2022-11-26 17:18:16.992 MySensors Error received '17:255' NoneNone0 failed: item type not found
  • @TurboMaster66
    Do you have nodes with addresses ## 17 60 100 on your network?
  • @yury Yes
  • @TurboMaster66 said in MySensors Error received:
    item type not found
    Seems like some sensor types you created in those nodes not supported\accepted by the controller. try different types. That is my best guess. I've seen something like that in homeassistant and domoticz
  • I successfully worked around the issue by updating the /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/MySensors.indigoPlugin/Contents/Server Plugin
    /plugin.py script to recognize the internal 21 code.
    Here's the diff:
    34c134,135
    < "GATEWAY_READY" : [14, "Gateway ready", ""]
    "GATEWAY_READY"             : [14, "Gateway ready",             ""],
    "DISCOVER_RESPONSE"         : [21, "Discover response",             ""]
    715a717,719
            elif itemType == self.getInternalNumber("DISCOVER_RESPONSE"):
                # 21 Ignore
                pass
    P.S. Indigo 2022.1 is complaining about this plugin that it won't be supported in future releases. Is there anyone out there planning to update this plugin?
