WeMos D1 mini won't start as gateway.
  • Just bought a WeMos D1 mini to use as a standalone gateway. I load the example sketch on to it and nothing happens. The router does not show a new device connecting. There is no serial debug, nothing shows up at all. I'm powering it from my computers USB. The rails are 3.31V and 4.95V. The mysensors library version is 2.3.2
    To try and troubleshoot I added some blink code to the sketch. Nothing happens. If I comment out #include <MySensors.h> the light on the board will blink. I added some serial prints and they will send but only with the MySensors.h commented out. The issue seems to be with the library but without serial debug I don't know where to go next.
    Here is my code.
     * Version 1.0 - Henrik Ekblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "SSID" //removed not to show in internet
    #define MY_WIFI_PASSWORD "password" //removed not to show in internet
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    //#define MY_DEFAULT_ERR_LED_PIN 2  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  2  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
    	pinMode(2, OUTPUT);
      static bool pinstate = 0;
      static unsigned long time = millis();
      if (millis() - time > 1000){
        pinstate = pinstate ^ 1;
        time = millis();
    	digitalWrite(2, pinstate);
  • Mod
    Welcome to the forum @Igor-Vinograd
    If you haven’t already, see https://forum.mysensors.org/post/113281
    My guess is that you are experiencing the same problem.
  • @mfalkvidd
    Thanks, that did the trick. The board came up with DHCP right away. Then I enabled static IP and the board also came right up.
  • Mod
    Nice work @Igor-Vinograd, thanks for reporting back.
  • 15
  • 10
  • 24
