Need a Guide to debug MySensor and Home Assistant
  • Dear,
    I don't know what happened, but after a lot of test, no more new sensors appeared in HA.
    I read a lot of documentation about DEBUG and enabled LOG in HA.
    But, it doesn't exist a guide and I at the end, I give up.
    I decided to :
    1. Rebuild a new Hyper V with last version of HA. No improvement.
    2. Rebuild a new MySensorGW. No improvement. I was never able to build the stable version (compilation error at the end). I'm with version 2.4.0.
    3. Restart a new arduino SENSOR
      Nothing worked until I finally get a new SENSOR in HA. I don't know why.
    My question is to have a quick guide to understand the following :
    1. Enable DEBUG LOG in HA (what is the best and quick way).
    2. Check Configuration of ADDON like Mosquitto, MySENSORS,
    Best Regards
  • @esa1966
    Sounds similar to the problems I was having. See if what I did works for you.
    Also, I think I remember seeing a variable that limits the number of connections to the gateway. MY_GATEWAY_MAX_CLIENTS ?
    OSD
  • The only think I'm able to do is to enable everything to mode "DEBUG"
    I'm not able to SET specific LEVEL to DEBUG mode for MQTT, MYSENSOR, SERVICE.
