serial nrf24 gateway is rebooting over and over
  • Hi,
    i built a serial gateway with a nano and E01-ML01SP4 nrf24 ebyte module
    https://www.ebyte.com/en/product-view-news.aspx?id=114
    i posted about it here https://forum.mysensors.org/topic/12109/nano-e01-ml01sp4-gateway
    the problème is the gate way is rebooting alone each time i try to read the serial
    of course my controler (HA) can't get the data as the gateway is always rebooting
    my node (wich is working with an other nrf24 gateway) can't connect neither
    my gateway sketch is default one with
    #define MY_DEBUG_VERBOSE_GATEWAY
    #define MY_DEBUG_VERBOSE_RF24
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_RF24_CE_PIN (12)
    //#define MY_RF24_CS_PIN (13)
    //#define MY_RF24_IRQ_PIN (5)
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_DURATION 180
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
    #define MY_RF24_CHANNEL 14
    // signing
    #define MY_SIGNING_SIMPLE_PASSWD "MYAWSOMEPASSWD"
    i can't figure what is going out
    some help would be really appreciated
    ---- Opened the serial port /dev/ttyUSB2 ----
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS--,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;39 TSM:INIT
    0;255;3;0;9;41 TSF:WUR:MS=0
    0;255;3;0;9;45 RF24:INIT:PIN,CE=9,CS=10
    0;255;3;0;9;48 RF24:SBY
    0;255;3;0;9;50 RF24:WBR:REG=0,VAL=14
    0;255;3;0;9;58 RF24:WBR:REG=3,VAL=3
    0;255;3;0;9;61 RF24:WBR:REG=4,VAL=95
    0;255;3;0;9;64 RF24:WBR:REG=5,VAL=14
    0;255;3;0;9;68 RF24:WBR:REG=6,VAL=39
    0;255;3;0;9;71 RF24:WBR:REG=29,VAL=4
    0;255;3;0;9;74 RF24:RBR:REG=29,VAL=4
    0;255;3;0;9;77 RF24:RBR:REG=6,VAL=39
    0;255;3;0;9;81 RF24:RBR:REG=5,VAL=14
    0;255;3;0;9;84 RF24:WBR:REG=2,VAL=2
    0;255;3;0;9;88 RF24:WBR:REG=1,VAL=0
    0;255;3;0;9;91 RF24:WBR:REG=28,VAL=3
    0;255;3;0;9;95 RF24:FRX
    0;255;3;0;9;97 RF24:FTX
    0;255;3;0;9;99 RF24:WBR:REG=7,VAL=112
    0;255;3;0;9;102 TSM:INIT:TSP OK
    0;255;3;0;9;105 TSM:INIT:GW MODE
    0;255;3;0;9;108 RF24:WBR:REG=2,VAL=3
    0;255;3;0;9;111 RF24:WBR:REG=1,VAL=1
    0;255;3;0;9;114 RF24:STL
    0;255;3;0;9;117 RF24:WBR:REG=0,VAL=15
    0;255;3;0;9;120 RF24:WBR:REG=10,VAL=0
    0;255;3;0;9;123 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;128 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;132 MCO:BGN:STP
    0;255;3;0;9;139 RF24:RBR:REG=6,VAL=39
    0;255;3;0;9;142 RF24:RBR:REG=5,VAL=14
    0;255;3;0;9;145 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;149 TSM:READY:NWD REQ
    0;255;3;0;9;152 RF24:SPL
    0;255;3;0;9;154 RF24:WBR:REG=0,VAL=14
    0;255;3;0;9;157 RF24:OWP:RCPT=255
    0;255;3;0;9;160 RF24:WBR:REG=10,VAL=255
    0;255;3;0;9;164 RF24:WBR:REG=16,VAL=255
    0;255;3;0;9;167 RF24:TXM:TO=255,LEN=7
    0;255;3;0;9;172 RF24:FTX
    0;255;3;0;9;174 RF24:WBR:REG=4
    ---- Closed serial port /dev/ttyUSB2 due to disconnection from the machine ----
    ---- Reopened serial port /dev/ttyUSB2 ----
    0;255;3;0;9;40 TSM:INIT
    0;255;3;0;9;43 TSF:WUR:MS=0
    0;255;3;0;9;49 RF24:SBY
    0;255;3;0;9;51 RF24:WBR:REG=0,VAL=14
    0;255;3;0;9;59 RF24:WBR:REG=3,VAL=3
    0;255;3;0;9;62 RF24:WBR:REG=4,VAL=95
    0;255;3;0;9;65 RF24:WBR:REG=5,VAL=14
    0;255;3;0;9;75 RF24:RBR:REG=29,VAL=4
    0;255;3;0;9;78 RF24:RBR:REG=6,VAL=39
    0;255;3;0;9;89 RF24:WBR:REG=1,VAL=0
    0;255;3;0;9;92 RF24:WBR:REG=28,VAL=3
    0;255;3;0;9;100 RF24:WBR:REG=7,VAL=112
    0;255;3;0;9;103 TSM:INIT:TSP OK
    0;255;3;0;9;106 TSM:INIT:GW MODE
    0;255;3;0;9;109 RF24:WBR:REG=2,VAL=3
    0;255;3;0;9;112 RF24:WBR:REG=1,VAL=1
    0;255;3;0;9;115 RF24:STL
    0;255;3;0;9;121 RF24:WBR:REG=10,VAL=0
    0;255;3;0;9;124 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;129 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;133 MCO:BGN:STP
    0;255;3;0;9;143 RF24:RBR:REG=5,VAL=14
    0;255;3;0;9;146 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;155 RF24:WBR:REG=0,VAL=14
    0;255;3;0;9;158 RF24:OWP:RCPT=255
    0;255;3;0;9;161 RF24:WBR:REG=10,VAL=255
    0;255;3;0;9;165 RF24:WBR:REG=16,VAL=255
    0;255;3;0;9;168 RF24:TXM:TO=255,LEN=7
    0;255;3;0;9;175 RF24:WBR:REG=
    0;255;3;0;9;44 RF24:INIT:PIN,CE=9,CS=10
    etc
    etc
    etc
    home assistant logs
    Logger: mysensors.transport
    Source: runner.py:179
    First occurred: 19:54:22 (99 occurrences)
    Last logged: 22:38:52
    device reports readiness to read but returned no data (device disconnected or multiple access on port?)
    Logger: mysensors.gateway_serial
    First occurred: 19:54:22 (1033 occurrences)
    Last logged: 22:49:22
    Unable to connect to /dev/ttyUSB2
  • Have you tried a different pc? What about your power supply? It could be the standard nano regulator isn't powerful enough.
  • hi electrick,
    thank you for the hint, i'm so glad that someone finally talks to me 🙂
    Yes i reached the same conclusion about power supply of the nrf24 board.
    3.3V pin from nano can only deliver 50mA when e01-ml01sp4 needs 120mA.
    I redesigned my project including a ams1117 between nano's 5V pin and the radio board
    https://forum.mysensors.org/topic/12109/nano-e01-ml01sp4-gateway/4?_=1679247873047
    next episode when i'll receive the new pcb !
