Node broadcast loop
  • Hi all,
    I have a node with 2 sensor that have been working well for weeks and suddenly starts to loop on some kind of broadcasting message. It comes back if I restart the RPI+Gateway (but not if I just restart the Mysensor service at RPI).
    I would like to solve it the right way, instead of having to reboot the server every time it happens.
    This is the log at the server:
    Oct 13 20:44:27 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Oct 13 20:44:27 DEBUG TSF:MSG:BC
    Oct 13 20:44:27 DEBUG TSF:MSG:FPAR REQ,ID=2
    Oct 13 20:44:27 DEBUG TSF:CKU:OK,FCTRL
    Oct 13 20:44:27 DEBUG TSF:MSG:GWL OK
    Oct 13 20:44:28 DEBUG !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Oct 13 20:44:30 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Oct 13 20:44:30 DEBUG TSF:MSG:BC
    Oct 13 20:44:30 DEBUG TSF:MSG:FPAR REQ,ID=2
    Oct 13 20:44:30 DEBUG TSF:CKU:OK,FCTRL
    Oct 13 20:44:30 DEBUG TSF:MSG:GWL OK
    Oct 13 20:44:31 DEBUG !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Oct 13 20:44:32 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Oct 13 20:44:32 DEBUG TSF:MSG:BC
    Oct 13 20:44:32 DEBUG TSF:MSG:FPAR REQ,ID=2
    Oct 13 20:44:32 DEBUG TSF:CKU:OK,FCTRL
    Oct 13 20:44:32 DEBUG TSF:MSG:GWL OK
    Oct 13 20:44:34 DEBUG !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Oct 13 20:45:35 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Oct 13 20:45:35 DEBUG TSF:MSG:BC
    Oct 13 20:45:35 DEBUG TSF:MSG:FPAR REQ,ID=2
    Oct 13 20:45:35 DEBUG TSF:PNG:SEND,TO=0
    Oct 13 20:45:35 DEBUG TSF:CKU:OK
    Oct 13 20:45:35 DEBUG TSF:MSG:GWL OK
    Oct 13 20:45:37 DEBUG !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    This is the node's code:
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    // Atualizar para nó esperado
    #define MY_NODE_ID 2
    // Novo driver para gateway RPI
    #define MY_RFM69_NEW_DRIVER
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    #include <DHT.h>
    #include <NewPing.h>
    #define DHT_DATA_PIN 3
    // Sonar parameters
    #define TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     9  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    #define ITERATIONS     5 // Number of iterations.
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    static const uint64_t UPDATE_INTERVAL = 600000; // 600000 = 10 min
    static const uint8_t FORCE_UPDATE_N_READS = 5;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RSSI 2               //RSSI
    #define CHILD_ID_VOLT 3               //Voltage
    #define CHILD_ID_DIST 4                //Distance
    //float lastTemp;
    //float lastHum;
    //uint8_t nNoUpdatesTemp;
    //uint8_t nNoUpdatesHum;
    bool metric = true;
    int8_t rssiVal;               //RSSI
    uint8_t dist;
    //static const uint8_t update_count = 6; // 6 = every 1 hour
    //uint8_t count = 100;  // > than update_count
    MyMessage msgRSSI(CHILD_ID_RSSI,V_VAR5);
    MyMessage msgDist(CHILD_ID_DIST, V_DISTANCE);
    MyMessage msgVOLT(CHILD_ID_VOLT,V_VOLTAGE);
    DHT dht;
      sendSketchInfo("Temperature+Humidity+Sonar", "2.0");
    //  sendSketchInfo("Battery Meter", "1.0");
    //  sendSketchInfo("No02_DHT11+Sonar_v06");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RSSI, S_CUSTOM);
      present(CHILD_ID_DIST, S_DISTANCE);
      present(CHILD_ID_VOLT, S_MULTIMETER);
      // Battery
        analogReference(INTERNAL1V1);
      #else
        analogReference(INTERNAL);
      dht.readSensor(true);
      if (isnan(temperature)) {
      } else {
    //  } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
    //    lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
          if (!metric) {
        // Reset no updates counter
    //    nNoUpdatesTemp = 0;
        send(msgTemp.set(temperature, 2));
        #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
    //  } else {
    //    nNoUpdatesTemp++;
      if (isnan(humidity)) {
      } else {
    //  } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
    //    lastHum = humidity;
    //    nNoUpdatesHum = 0;
        send(msgHum.set(humidity, 2));
        #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
    //  } else {
    //    nNoUpdatesHum++;
    //  rssiVal = _radio.readRSSI();  // Old Driver
      rssiVal = RFM69_getSendingRSSI();  // New Driver
      send(msgRSSI.set(rssiVal));
      #ifdef MY_DEBUG
        Serial.print("RSSI Sending: ");
        Serial.println(rssiVal);
    //    Serial.print("RSSI Receiving: ");
    //    Serial.println(RFM69_getReceivingRSSI());
      dist = sonar.convert_cm(sonar.ping_median(ITERATIONS, MAX_DISTANCE));
      #ifdef MY_DEBUG
        Serial.print("Dist: ");
        Serial.print(dist);
        Serial.println("cm");
      if (dist > 0) {
        dist = 90 - dist;
        send(msgDist.set(dist, 2));
      long batteryMillivolts = hwCPUVoltage();
      send(msgVOLT.set(batteryMillivolts / 1000.0, 2));
      #ifdef MY_DEBUG
        Serial.print(batteryMillivolts / 1000.0);
        Serial.println(" V");
      sleep(UPDATE_INTERVAL);
    This is the configuration of the RPI gateway
    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=user --my-mqtt-password=password --my-mqtt-publish-topic-prefix=mygateway1-out --my-mqtt-subscribe-topic-prefix=mygateway1-in --my-mqtt-client-id=gw_02 --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw --extra-cxxflags="-DMY_DEBUG_VERBOSE_GATEWAY"
    Thanks!
  • Solved. Issue with power supply. Added a capacidade to power source.
