problem with Dallas temperature
  • hello,
    I have problems with my 1-wire node, so I used two buses (pin2 and pin3).
    all my temperatures are visible but some have the same id.
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on serial which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <OneWire.h>
    #define ONE_WIRE_BUS3 3 // Pin where dallase sensor is connected
    #define ONE_WIRE_BUS2 2 // Pin where dallase sensor is connected
    OneWire oneWire3(ONE_WIRE_BUS3); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    OneWire oneWire2(ONE_WIRE_BUS2);
    DallasTemperature sensors3(&oneWire3); // Pass the oneWire reference to Dallas Temperature.
    DallasTemperature sensors2(&oneWire2);
    float lastTemperature3[MAX_ATTACHED_DS18B20];
    float lastTemperature2[MAX_ATTACHED_DS18B20];
    int numSensors3=0;
    int numSensors2=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg3(0,V_TEMP);
    MyMessage msg2(0,V_TEMP);
    void before()
      sensors3.begin();
      sensors2.begin();
      sensors3.setWaitForConversion(false);
      sensors2.setWaitForConversion(false);
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
      numSensors3 = sensors3.getDeviceCount();
      numSensors2 = sensors2.getDeviceCount();
      for (int i=0; i<numSensors3 && i<MAX_ATTACHED_DS18B20; i++) {
         present(i, S_TEMP);
      for (int j=0; j<numSensors2 && j<MAX_ATTACHED_DS18B20; j++) {
         present(j, S_TEMP);
      sensors3.requestTemperatures();
      sensors2.requestTemperatures();
      int16_t conversionTime = sensors3.millisToWaitForConversion(sensors3.getResolution());
      sleep(conversionTime);
      int16_t conversionTime2 = sensors2.millisToWaitForConversion(sensors2.getResolution());
      sleep(conversionTime2);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors3.getTempCByIndex(i):sensors3.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        if (lastTemperature3[i] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msg3.setSensor(i).set(temperature,1));
          lastTemperature3[i]=temperature;
        float temperature2 = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors2.getTempCByIndex(j):sensors2.getTempFByIndex(j)) * 10.)) / 10.;
        if (lastTemperature2[j] != temperature2 && temperature2 != -127.00 && temperature2 != 85.00) {
        #else
        if (temperature2 != -127.00 && temperature != 85.00) {
          send(msg2.setSensor(j).set(temperature2,1));
          lastTemperature2[j]=temperature2;
      sleep(SLEEP_TIME);
    for me the first 2 lines and the last two are different probes but with the same id.
    how can I have a single id ?
    thanks
  • If you have two nodes with the same ID, the MySensors system can not work good. You solve this by clearing the EEPROM, see https://www.mysensors.org/build/debug at least for one of the nodes. After this, the gateway will send a new node id to the node.
  • hello,
    I just deleted the eeprom but I still have the problem.
  • 1
  • 5
  • 198
  • 10
  • 1
