[Domoticz] Electrical Sensor?
  • Hi!
    Does anyone use 'electric pulse meter' with Domoticz?
    Does the value shown as a 'current usage' meets the real usage of power?
    And how often should values be sent to Domoticz to get proper real values of usage? I guess 20 seconds is too often - my energy meter is 1000 imp/kWh and when usage from apartment is low (sometimes may be lower than 100W per minute) it don't get any impulse per minute...
    Anyway, earlier I was using my own custom built pulse meter which was counting pulses for 1 minute and calculating usage. May it be done with MySensors and Domoticz too?
    Here's thread in which I was trying to get info at Domoticz forum:
    http://www.domoticz.com/forum/viewtopic.php?f=6&t=6369
    Regards
  • Hero Member
    As far as I know, and what I did is calculating the figures in the node and send them to Domoticz. Example is in the projects "my 12 input...."
  • Admin
    I made my own (non-mysensor) setup for reporting electricity usage, as I have a raspberry mounted in the same cupboard as the utility meter resides in.
    It reports to domoticz everytime a pulse is detected (1 pulse / wh). reports actual power used (calculated by the arduino), and a pulse count.
  • Does anyone tested/use the sketch from MySensors website?
    It sends pulse count and usage calculated... Just the values sometimes seems very strange...
  • 5
  • 5
  • 4
  • 8
11.3k
