  3. SCT-013-030 current monitor sensor
65 Posts 16 Posters 58.5k Views 15 Watching
  • chatainsimC
    chatainsimC
    chatainsim
    Do you now if someone already made a sketch for the SCT-013-030 sensors ?
    I'm trying to find something on google, but I haven't found nothing for now.
    Thanks !
      maglo18
      @chatainsim said:
      SCT-013-030
      I create custom energy monitor and use mysesnors to send data to server.
      http://forum.mysensors.org/topic/703/custom-power-meter/4
      My final sketch
      #include "EmonLib.h"             // Include Emon Library
      EnergyMonitor emon1;             // Create an instance
      EnergyMonitor emon2;             // Create an instance
      EnergyMonitor emon3;             // Create an instance
      #define CHILD_ID 0
      #define CHILD_ID2 1
      #define CHILD_ID3 2
      unsigned long lastSend;
      unsigned long SEND_FREQUENCY = 10000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      unsigned long lastSend2;
      unsigned long SEND_FREQUENCY2 = 300000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      MyMessage realPowerMsg(CHILD_ID,V_VAR1);
      MyMessage apparentPowerMsg(CHILD_ID,V_VAR2);
      MyMessage powerFActorMsg(CHILD_ID,V_VAR3);
      MyMessage supplyVoltageMsg(CHILD_ID,V_VAR4);
      MyMessage IrmsMsg(CHILD_ID,V_VAR5);
      MyMessage realPowerMsg2(CHILD_ID2,V_VAR1);
      MyMessage apparentPowerMsg2(CHILD_ID2,V_VAR2);
      MyMessage powerFActorMsg2(CHILD_ID2,V_VAR3);
      MyMessage supplyVoltageMsg2(CHILD_ID2,V_VAR4);
      MyMessage IrmsMsg2(CHILD_ID2,V_VAR5);
      MyMessage realPowerMsg3(CHILD_ID3,V_VAR1);
      MyMessage apparentPowerMsg3(CHILD_ID3,V_VAR2);
      MyMessage powerFActorMsg3(CHILD_ID3,V_VAR3);
      MyMessage supplyVoltageMsg3(CHILD_ID3,V_VAR4);
      MyMessage IrmsMsg3(CHILD_ID3,V_VAR5);
        gw.begin(NULL, 4, false, 0);
        Serial.begin(115200); // opens serial port, sets data rate to 9600 bps
        gw.sendSketchInfo("Energy Meter x 3v2", "1.2");
        gw.present(CHILD_ID, S_POWER);
        gw.present(CHILD_ID2, S_POWER);
        gw.present(CHILD_ID3, S_POWER);
        emon1.voltage(A3, 116.26, 1.7);  // Voltage: input pin, calibration, phase_shift
        emon1.current(A0, 29.0);       // Current: input pin, calibration.
        emon2.voltage(A4, 116.66, 1.7);  // Voltage: input pin, calibration, phase_shift
        emon2.current(A1, 29.0);       // Current: input pin, calibration.
        emon3.voltage(A5, 115.91, 1.7);  // Voltage: input pin, calibration, phase_shift
        emon3.current(A2, 29.0);       // Current: input pin, calibration.
        gw.process();
        unsigned long now = millis();
        emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
        //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
        emon2.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
        //emon2.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
        emon3.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
        //emon3.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
        bool sendTime = now - lastSend > SEND_FREQUENCY;
        if (sendTime) {
          float realPower       = emon1.realPower;        //extract Real Power into variable
          float realPower2       = emon2.realPower;        //extract Real Power into variable
          float realPower3       = emon3.realPower;        //extract Real Power into variable
          if(realPower > 0 && realPower < 10000){
          gw.send(realPowerMsg.set(realPower,1));
          if(realPower2 > 0 && realPower2 < 10000){
          gw.send(realPowerMsg2.set(realPower2,1));
          if(realPower3 > 0 && realPower3 < 10000){
          gw.send(realPowerMsg3.set(realPower3,1));
          lastSend = now;
        bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
        if(sendTime2){
          float apparentPower   = emon1.apparentPower;    //extract Apparent Power into variable
          float powerFactor     = emon1.powerFactor;      //extract Power Factor into Variable
          float supplyVoltage   = emon1.Vrms;             //extract Vrms into Variable
          float Irms            = emon1.Irms;             //extract Irms into Variable
          float apparentPower2   = emon2.apparentPower;    //extract Apparent Power into variable
          float powerFactor2     = emon2.powerFactor;      //extract Power Factor into Variable
          float supplyVoltage2   = emon2.Vrms;             //extract Vrms into Variable
          float Irms2            = emon2.Irms;             //extract Irms into Variable
          float apparentPower3   = emon3.apparentPower;    //extract Apparent Power into variable
          float powerFactor3     = emon3.powerFactor;      //extract Power Factor into Variable
          float supplyVoltage3   = emon3.Vrms;             //extract Vrms into Variable
          float Irms3            = emon3.Irms;             //extract Irms into Variable
          if(apparentPower > 0 && apparentPower < 10000){
          gw.send(apparentPowerMsg.set(apparentPower,1));
          if(powerFactor > 0 && powerFactor < 10000){
          gw.send(powerFActorMsg.set(powerFactor,1));
          if(supplyVoltage > 0 && supplyVoltage < 1000){
          gw.send(supplyVoltageMsg.set(supplyVoltage,1));
          if(Irms > 0 && Irms < 1000){
          gw.send(IrmsMsg.set(Irms,1));
          if(apparentPower2 > 0 && apparentPower2 < 10000){
          gw.send(apparentPowerMsg2.set(apparentPower2,1));
          if(powerFactor2 > 0 && powerFactor2 < 10000){
          gw.send(powerFActorMsg2.set(powerFactor2,1));
          if(supplyVoltage2 > 0 && supplyVoltage2 < 1000){
          gw.send(supplyVoltageMsg2.set(supplyVoltage2,1));
          if(Irms2 > 0 && Irms2 < 1000){
          gw.send(IrmsMsg2.set(Irms2,1));
          if(apparentPower3 > 0 && apparentPower3 < 10000){
          gw.send(apparentPowerMsg3.set(apparentPower3,1));
          if(powerFactor3 > 0 && powerFactor3 < 10000){
          gw.send(powerFActorMsg3.set(powerFactor3,1));
          if(supplyVoltage3 > 0 && supplyVoltage3 < 1000){
          gw.send(supplyVoltageMsg3.set(supplyVoltage3,1));
          if(Irms3 > 0 && Irms3 < 1000){
          gw.send(IrmsMsg3.set(Irms3,1));
          lastSend2 = now;
      • chatainsimC
        chatainsimC
        chatainsim
        Thank you for the code.
        Can you tell me how to wire the sensor ?
        I have only two wire connected to the jack.
        Thanks !
        • korttomaK
          korttomaK
          korttoma
          This post is deleted!
          • epierreE
            epierreE
            epierre
            this code is for three, first one is wired on A3 / A0, second A4/A1 and third on A5/A2
            z-wave - Vera -> Domoticz
            • chatainsimC
              chatainsimC
              chatainsim
              Yes, I've understand this but how is it possible to wire on A3 and A0 with only two wires ? Where is connected the VCC ?
              I've used this : http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only
                maglo18
                @maglo18 said:
                A3 is from transformer and A0 is from CT sensor
                Voltage input http://openenergymonitor.org/emon/buildingblocks/measuring-voltage-with-an-acac-power-adapter
                CT input http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only
                I have 3 x voltage input and 3 x ct input.
                • chatainsimC
                  chatainsimC
                  chatainsim
                  Ahhh ! Ok.
                  That why there is A3 and A0 in use !
                  I'll digg into the voltage input to know how it's working.
                  Thank you.
                  • chatainsimC
                    chatainsimC
                    chatainsim
                    I've change the code to only use A0 for CT sensor.
                    It's not plug in the cable, it's for testing.
                    Here is the output in arduino serial console :
                    sensor started, id 2
                    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                    read: 2-1-0 s=255,c=3,t=6,pt=1,l=1:0
                    read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
                    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Energy Meter
                    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0
                    send: 2-2-0-0 s=0,c=0,t=13,pt=0,l=5,st=ok:1.4.1
                    read: 2-1-0 s=0,c=0,t=13,pt=0,l=5:1.4.1
                    0.00 0.00 0.00 69.60 nan
                    0.00 0.00 0.00 62.07 nan
                    0.00 0.00 0.00 55.65 nan
                    0.00 0.00 0.00 48.57 nan
                    0.00 0.00 0.00 40.78 nan
                    0.00 0.00 0.00 35.21 nan
                    0.00 0.00 0.00 30.80 nan
                    0.00 0.00 0.00 24.84 nan
                    0.00 0.00 0.00 19.95 nan
                    0.00 0.00 0.00 16.46 nan
                    send: 2-2-0-0 s=0,c=1,t=24,pt=7,l=5,st=ok:0.0
                    send: 2-2-0-0 s=0,c=1,t=25,pt=7,l=5,st=ok:0.0
                    send: 2-2-0-0 s=0,c=1,t=26,pt=7,l=5,st=ok:NAN
                    send: 2-2-0-0 s=0,c=1,t=27,pt=7,l=5,st=fail:0.0
                    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:16.5
                    0.00 0.00 0.00 13.53 nan
                    0.00 0.00 0.00 11.34 nan
                    0.00 0.00 0.00 9.73 nan
                    0.00 0.00 0.00 8.11 nan
                    0.00 0.00 0.00 6.84 nan
                    0.00 0.00 0.00 5.72 nan
                    0.00 0.00 0.00 4.71 nan
                    0.00 0.00 0.00 3.90 nan
                    0.00 0.00 0.00 3.18 nan
                    0.00 0.00 0.00 2.61 nan
                    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:2.6
                    0.00 0.00 0.00 2.22 nan
                    0.00 0.00 0.00 1.97 nan
                    0.00 0.00 0.00 1.76 nan
                    0.00 0.00 0.00 1.62 nan
                    0.00 0.00 0.00 1.51 nan
                    0.00 0.00 0.00 1.40 nan
                    0.00 0.00 0.00 1.26 nan
                    0.00 0.00 0.00 1.13 nan
                    0.00 0.00 0.00 0.99 nan
                    0.00 0.00 0.00 0.85 nan
                    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:0.8
                    0.00 0.00 0.00 0.74 nan
                    0.00 0.00 0.00 0.65 nan
                    0.00 0.00 0.00 0.57 nan
                    0.00 0.00 0.00 0.50 nan
                    0.00 0.00 0.00 0.40 nan
                    0.00 0.00 0.00 0.33 nan
                    0.00 0.00 0.00 0.29 nan
                    0.00 0.00 0.00 0.25 nan
                    0.00 0.00 0.00 0.23 nan
                    0.00 0.00 0.00 0.20 nan
                    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:0.2
                    0.00 0.00 0.00 0.19 nan
                    0.00 0.00 0.00 0.16 nan
                    0.00 0.00 0.00 0.13 nan
                    0.00 0.00 0.00 0.14 nan
                    0.00 0.00 0.00 0.11 nan
                    0.00 0.00 0.00 0.09 nan
                    There are some fail, is it normal ?
                    • chatainsimC
                      chatainsimC
                      chatainsim
                      I starting to understand.
                      The SCT-013-030 is used only to get Ampere, nothing more ? Is it correct ?
                      If I want the Watt I need more sensors connected to the arduino, right ?
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        @chatainsim, if you know the Voltage, just multiply the voltage by the amperage and you will have the wattage...
                        http://en.wikipedia.org/wiki/Ohm's_law
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        chatainsimC 1 Reply Last reply
                          maglo18
                          In Emonlib you have example to measure watt etc. without measure voltage.
                          https://github.com/openenergymonitor/EmonLib
                          • rvendrameR rvendrame
                            chatainsimC
                            chatainsimC
                            chatainsim
                            @rvendrame Thanks, I will try this.
                            @maglo18 I will try to use some example.
                            First I need to check if my sketch and my assemble works at least.
                            Thanks for your help. I think I will need more from you guys !
                            • chatainsimC
                              chatainsimC
                              chatainsim
                              Hello guys,
                              I've working on my sensor.
                              It's seems working, but I have some trouble with Watt or Kwh.
                              Here is the sketch:
                              // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
                              #define CHILD_ID 0
                              unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                              MyMessage IrmsMsg(CHILD_ID,V_WATT);
                                gw.begin();
                                gw.sendSketchInfo("Energy Meter", "1.0");
                                gw.process();
                                double Irms = emon1.calcIrms(1480);
                                //emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
                                if (sendTime) {
                                  //float Irms = emon1.Irms;             //extract Irms into Variable
                                  gw.send(IrmsMsg.set(Irms*232.0,1));
                                  Serial.println(Irms*232.0);
                                  lastSend = now;
                              I've got around 390 for the Irms*232, do you thinks it's a correct value ?
                              Can I calculated the current kwh with the ampere ?
                              Thank you.
                              AWIA 1 Reply Last reply
                              • chatainsimC
                                chatainsimC
                                chatainsim
                                I've made some change in the code :
                                #define CHILD_ID_WATT 0
                                #define CHILD_ID_KWH 1
                                MyMessage IrmsMsg(CHILD_ID_WATT,V_WATT);
                                MyMessage kWhMsg(CHILD_ID_KWH,V_KWH);
                                  gw.begin();
                                  gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
                                  gw.present(CHILD_ID_WATT, S_POWER);  // Register this device as power sensor
                                  gw.present(CHILD_ID_KWH, S_POWER);
                                  gw.process();
                                  if (sendTime) {
                                    gw.send(IrmsMsg.set((Irms*232.0)*1000, 1));
                                //    Serial.print("Watt: ");
                                //    Serial.println(Irms*232.0);
                                    gw.send(kWhMsg.set((Irms*232.0)/1000, 1));
                                //    Serial.print("kWH: ");
                                //    Serial.println((Irms*232.0)/1000);
                                    lastSend = now;
                                But in Domoticz, I've two line for this but in kWh and not on in kWh and other in Watt :
                                Do you know why ?
                                Regards,
                                • chatainsimC chatainsim
                                  Hello guys,
                                  Here is the sketch:
                                  #define CHILD_ID 0
                                    gw.begin();
                                    gw.process();
                                    if (sendTime) {
                                      lastSend = now;
                                  Thank you.
                                  AWIA
                                  AWIA
                                  AWI
                                  @chatainsim Domoticz does not have a different device for power (Watt) and energy(kWh) but combines them in a single device. What you need to do is send both the power and energy to the same child.
                                  • chatainsimC
                                    chatainsimC
                                    chatainsim
                                    Thanks, but I've already test this and only the kWh is updated in domoticz, not watt.
                                    #define CHILD_ID 0
                                    MyMessage kWhMsg(CHILD_ID,V_KWH);
                                      gw.begin();
                                      gw.present(CHILD_ID, S_POWER);  // Register this device as power sensor
                                      gw.process();
                                      if (sendTime) {
                                        lastSend = now;
                                    Can you help me with this ?
                                      #define CHILD_ID 0
                                        gw.begin();
                                        gw.process();
                                        if (sendTime) {
                                          lastSend = now;
                                      AWIA
                                      AWIA
                                      AWI
                                      @chatainsim I am pretty sure it is a combined device which shows Watt only when added ...:
                                      upload-40825a2f-8628-4412-8fdb-44b222576843
                                      upload-11b440e7-718e-46ae-87f1-a4eb3c913c7e
                                      upload-408228f1-e921-418e-bae9-db19b6d47eee
                                      Although I am not sure if the Domoticz MySensors plug-in handles it right (I'm still using my own script).
                                      • chatainsimC
                                        chatainsimC
                                        chatainsim
                                        Ok, thanks.
                                        How do you get your watt info ? With teleinfo ?
                                          Ok, thanks.
                                          AWIA
                                          AWIA
                                          AWI
                                          @chatainsim
                                          I send the V_Watt messages from the Power meter to Domoticz.
