  2. Enclosures / 3D Printing
  3. MySensors Sensebender Micro 3DP Case
22 Posts 8 Posters 16.9k Views 3 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    It's by far complete, but here is the first revision. There are few design errors, but the overall main case works.
    Sorry about the terrible pictures..
    RJ_Make
    • tbowmoT
      tbowmoT
      tbowmo
      Two things :)
      1. Why an extra cap on the radio? (Not using it myself in my micros from itead)
      2. If you place the boards at the end of the battery pack instead of the backside, wouldn't the casing be smaller then? (If I remember correctly, the sensebender is roughly the same dimensions as the end of the battery pack)
      RJ_MakeR 2 Replies Last reply
      • Roberto BrunialtiR
        Roberto BrunialtiR
        Roberto Brunialti
        Just a check: does'nt the micro have a capacitor on the pcb to serve the radio? So is it really necessary to stick the huge cap on top of radio ?
          mvader
          I'm not using a cap on mine.. seems to be working fine.
          is there any openings in that case? you will need some air flow to correctly monitor the temp and humidity.
          nice start though. what printer do you have?
          • tbowmoT tbowmo
            Two things :)
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            wrote on last edited by RJ_Make
            1. The radio is from the original sensor (just transfered it to the Sensebender Micro.)
            2. There are small ridges, one on each side, that stop the battery housing. (can be seen in the first picture of the case)
            3. There are some vents in the bottom of the case, but wasn't sure if it would work. (can be seen in the first picture of the case on the bottom)
            4. It's a Flashforge Creator Pro.
            I've change the top; got rid of the screw holes, and went with a top that has longer side walls to create a friction fit.
            RJ_Make
            • tbowmoT tbowmo
              Two things :)
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @tbowmo
              Missed one part of your question. The reason I went with the backside; I wanted a "slide in" design for the battery holder.
              I'm not talented enough to create a solution that allowed that with the SBM (Sensebender Micro) on the bottom. :bowtie:
              RJ_Make
              • DrJeffD
                DrJeffD
                DrJeff
                Nice! What is your print time? What printer do you have?
                RJ_MakeR 1 Reply Last reply
                • DrJeffD DrJeff
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @DrJeff 3.25 Hours I believe.
                  RJ_Make
                  • P
                    P
                    Porky6666
                    @ServiceXp
                    Would you share the .stl file?
                    Greets
                    Stefan
                    • P Porky6666
                      @ServiceXp
                      Greets
                      Stefan
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @Porky6666
                      Here ya go..
                      http://www.thingiverse.com/thing:891486
                      RJ_Make
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        V2. Case is smaller, and lighter (much thinner walls) and includes mounting tabs (instead of the rear mounting holes). I also added some side ventilation holes.
                        RJ_Make
                          mvader
                          v2 looks good.. would you guess at how much each one of those cost you to make?
                          • M mvader
                            RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            @mvader Cost In terms of what?
                            Printer cost, Electricity, Time, Filament??
                            RJ_Make
                              mvader
                              i would say filament cost.
                              more like if you look at how much it cost to print pictures vs have them printed. you don't take the cost of the printer into account.
                              I've been thinking about getting into 3d printing but outside of cases for my sensors i cant think of anything i would print lol
                              so i was just curious, how much it would cost you to print something like that.
                              thanks
                              • M mvader
                                thanks
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @mvader Around $1.75 in filament for 1 top and body.
                                RJ_Make
                                • RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  Added a Motion Sensor Top
                                  RJ_Make
                                    got a few print to do when I get home...
                                    • K
                                      K
                                      kalle
                                      wrote on last edited by kalle
                                      here is my first 3D print for the sensbender micro, printed with Arduino Materia 101 printer - STL files available if needed.
                                      I think it is also possible to fit a motion sensor in the top - will try ;-)
                                      • K
                                        K
                                        kalle
                                        part 2:
                                        • K kalle
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @kalle Nice.. What are you using for the battery contacts?
                                          RJ_Make
