  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 595.0k Views 69 Watching
  • petewillP
    petewillP
    petewill
    wrote on last edited by petewill
    Does anyone know of any 120V AC to 5V DC transformers that are safe to put in a wall electrical box? I have been using old cell phone chargers for most of my projects but I was recently pondering putting something right in the wall. Since shipping can take so long I thought I'd ask now before I even start on the project.
    I did some searching and couldn't find anything so I thought I'd ask the experts here.
    Thanks in advance!
    EDIT 9/7/2016
    Watch out for Fakes! Read more here: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/355
    If in doubt you can get them directly from the vendor here: http://www.hlktech.net/product.php?CateId=10
    EDIT 12/28/2015
    After MUCH discussion on this here are the findings of this thread (as of now):
    Here is the diagram for how things should be wired:
    These are the parts I ordered. I haven't tested any of these parts yet as this project has been put on the back burner for now :(. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
    Also, see these posts for more discussion/ideas if interested:
    http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
    http://forum.mysensors.org/topic/2488/in-wall-pcb
    Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
    250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
    HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Pete
    Moshe LivneM J N MattNYM 5 Replies Last reply
    • DidiD
      DidiD
      Didi
      wrote on last edited by Didi
      here you go
      http://www.recom-international.com/pdf/Powerline-AC-DC/RAC03-SCR_277.pdf
      http://www.tracopower.com/products/tiw.pdf
      if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
      • petewillP petewill
        Thanks in advance!
        EDIT 9/7/2016
        EDIT 12/28/2015
        Pete
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @petewill got these http://www.aliexpress.com/item/Free-Shippingn-2pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32296988259.html in the mail today. not as sexy as the ones @Didi lists but maybe cheaper? Haven't tried them yet.
        • scalzS
          scalzS
          I have ordered same as @Moshe. I think those @Didi listed are larger and expensive. It is not very easy to find something small and cheap, or it needs to make your own.
          • scalzS scalz
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @scalz I actually ordered the same as you :relaxed:
            they look very well made. I am not equipped to test any of the parameters but i am sure that for me they will do.
            • scalzS
              scalzS
              @Moshe Livne : yep! it is the smallest and cheapest I have found. What could be great would be to find cheap and little core transformer to make custom step down.
              • sundberg84S
                As long as they dont catch fire and deliver 5v im happy! :fearful:
                DidiD 1 Reply Last reply
                • scalzS scalz
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @scalz How do you connect these to the mains? direct soldering and heatshrink over?
                  • sundberg84S sundberg84
                    DidiD
                    DidiD
                    Didi
                    That´s the problem i see with the cheap ones
                    • DidiD Didi
                      here you go
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @Didi These are huge... they are 5x5cm. Do you have any idea of their pricing?
                      • Moshe LivneM Moshe Livne
                        DidiD
                        DidiD
                        Didi
                        @Moshe-Livne
                        About 20-25 euro
                        • DidiD Didi
                          @Moshe-Livne
                          About 20-25 euro
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @Didi ouch!
                            @Didi ouch!
                            DidiD
                            DidiD
                            Didi
                            @Moshe-Livne said:
                            @Didi ouch!
                            Yes,but they have over temperature protection :wink:
                            • DidiD Didi
                              @Moshe-Livne said:
                              @Didi ouch!
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @Didi it is cheaper to buy better fire and life insurance :wink:
                                DidiD
                                DidiD
                                Didi
                                That´s a good point :joy:
                                • scalzS
                                  scalzS
                                  wrote on last edited by scalz
                                  @Moshe Livne: it is ordered, I have not them yet. I hope it will be good quality.I don't know.
                                  I agree with you for fire and co. But I think in commercial products they don't use big things.
                                  As we can see on some picture here : http://www.aliexpress.com/store/product/Free-Shipping-Livolo-Luxury-White-Crystal-Glass-Switch-Panel-EU-Standard-VL-C701-11-110-250V/500715_512886492.html
                                  Sure it is maybe not top quality, but I think in fibaro or other it's near the same thing. but I am not sure as I have none. And of course they have enclosure (maybe flame retardant).
                                  Maybe I am not enough paranoid...or you can for example put an onboard temperature sensor for additional security.
                                  But of course, ac is very dangerous, you must know what you do if you don't want to die. You have to take all securities like you said.
                                  • petewillP
                                    petewillP
                                    petewill
                                    Thanks for the quick replies! I am torn. The ones @Didi posted look great but they are large and expensive. The ones @Moshe-Livne and @scalz ordered look appealing because of cost and size but I don't want to sacrifice safety for cost. It looks like they have temperature protection but I don't know enough about electronics to test for safety. Hmm...
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @petewill
                                      I wonder if you could open one of these and solder to the USB power leads...
                                      petewillP 1 Reply Last reply
                                        @petewill
                                        petewillP
                                        petewillP
                                        petewill
                                        @BulldogLowell Yeah I was thinking about that too. I'm really trying to keep costs down though. When I hit the $25 price point it's almost as much as a standard z-wave switch when all the other parts and time are included.
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          My only recommendation; (if you are going to put this in side a utility box, in the wall) might want to find a solution that has the 3 standard safety features. (OTP, OVP, SCP)
                                          These work well, but you need to follow the data-sheet for noise and ripple control.
                                          RJ_Make
