  3. Convert sketch from 1.3 to 1.4
14 Posts 5 Posters 8.7k Views 3 Watching
  • A
    A
    a-lurker
    wrote on last edited by a-lurker
    @C4Vette
    "Are there any guidelines on how to convert a sketch that was made for the 1.3 libraries to 1.4?
    I would very much like to use the DimmableLED sketch but I know too little about coding. I found a few obvious differences but nevertheless did not succeed in making the sketch work.
    I found it here: http://forum.micasaverde.com/index.php/topic,23342.0.html and I know the maker blacey is also on this forum and think it is a very nice sketch. The only way I see how to get this to work is to downgrade to the 1.3 libraries but than I would have to start all over."
    It's not easy to cover all possibilities but here are a few notes and examples based on a temperature sensor plus some other info that might help with the DimmableSketch. I can re-edit this post if there are any corrections needed or something else needs to be added.
    AT THE START OF THE PROGRAM:
    #include <Sensor.h>  change to  #include <MySensor.h>
    #include <EEPROM.h>  <-- this line is no longer required  - delete
    #include <RF24.h>    <-- this line is no longer required  - delete
    Sensor gw;           change to -->  MySensor gw;
    Sensor gw(9,10);     change to -->  MySensor gw;
    // Initialize temperature message   <-- insert line
    MyMessage msg(0,V_TEMP);            <-- insert line
    IN void setup():
    // send the Sketch Version Information to the Gateway   <-- insert line
    gw.sendSketchInfo("My sketch name", "0.50");            <-- insert line
    gw.sendSensorPresentation(i, S_TEMP);  change to -->  gw.present(i, S_TEMP);
    metric = gw.isMetricSystem();  change to -->  metric = gw.getConfig().isMetric;
    IN void loop():
    // process incoming messages (like config from server)   <-- insert line
    gw.process();                                        <-- insert line
    gw.sendVariable(i, V_TEMP, temperature, 1);  change to -->  gw.send(msg.setSensor(i).set(temperature,1));  // send float with one decimal point
    SEARCH FOR THE FOLLOWING:
    gw.powerUp();   <-- this line is no longer required - delete if found
    sendSensorPresentation   change variable name to --> present
    If the following is found then this can be deleted:
    // Set RADIO_ID to something unique in your sensor network (1-254)
    // or set to AUTO if you want gw to assign a RADIO_ID for you.
    #define RADIO_ID AUTO
    If the #define RADIO_ID AUTO was found and deleted as above then change this also
    gw.begin( RADIO_ID ); change to --> gw.begin();
    OTHER EXAMPLE MESSAGES:
    // batteryPcnt is a uint8_t
    // I've not checked this
    gw.sendVariable( 0, V_DIMMER, currentLevel ); change to --> gw.send(currentLevel);
    INITIALIZING THE SENSOR TO HANDLE A MESSAGE FROM THE MAIN GATEWAY:
    // handle incoming messages
    void incomingMessage(MyMessage message)
       // handle your messages here
       setDimmableLEDState(message);
    // the call back incomingMessage receives any incoming messages
    gw.begin(incomingMessage);
    • A a-lurker
      @C4Vette
      IN void setup():
      IN void loop():
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @a-lurker
      I looked this over, thanks. This, and @hek's update on the new version are falling a bit short for me to convert some of my sketches.
      I guess I really need to see some better examples of converted code, before and after.
      I must be missing something, to me it should be more intuitive what to do here.
      hekH 1 Reply Last reply
        @a-lurker
        @BulldogLowell
        You just have to compare the provided examples between 1.3<->1.4. They have all been converted.
        BulldogLowellB clippermiamiC 2 Replies Last reply
          @BulldogLowell
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @hek
          Is this needed for every child device??
          YveauxY 1 Reply Last reply
            @hek
            YveauxY
            YveauxY
            @BulldogLowell yes, if you declare a message for each child and initialize it once.
            You can also create a single message in loop () and change its properties on the fly (don't have my PC near right now, so no code example.... :cry:
            • YveauxY Yveaux
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @Yveaux
              thanks, I guess I have tunnel vision here.
              I have 3 hours on a plane tonight, I'll fiddle with it then and see if I can't get a sketch to even compile!
              gw.loadState???
              where is all of this explained? Did I miss some document that has all of these?
                @BulldogLowell
                clippermiamiC
                clippermiamiC
                clippermiami
                @hek So, all the examples provided on MySensors.org are already configured for the 1.4 Library including the Serial Gateway? It will probably be easier to simply make minor tweaks to the examples to suit my specific configs then.
                  @Yveaux
                  gw.loadState???
                  YveauxY
                  YveauxY
                  @BulldogLowell The 1.4 library is still under development and documentation is only present in the code. If you're unable to read the code then maybe you should delay the switch to 1.4 until released and stable...
                  clippermiamiC BulldogLowellB 2 Replies Last reply
                  • YveauxY Yveaux
                    clippermiamiC
                    clippermiamiC
                    clippermiami
                    @Yveaux Good idea :)
                    John
                    • YveauxY Yveaux
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      sort of goes without saying, right?!!
                      I can read the code, I just have to spend the time deciphering the calls.
                      I have built some more complex sketches that were using a lot of the richness of the MySensors capability, I am just trying to piece it all together from the bits that are in each (very lean) example.
                        YveauxY
                        YveauxY
                        @BulldogLowell said:
                        Not necessarily... Some people just want it because it's new and probably better.
                        Then they get frustrated when they run into problems.
                        I'm not saying you're one of them and I also don't mean you cannot read code, I just want to stress that it might be better to wait unless you are prepared to run into troubles ;-)
                        • YveauxY Yveaux
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @Yveaux
                          yeah, perhaps I'll go back to creating new stuff and wait for the dust to settle on the API.
                          I may sneak n a bit of time on this, though. I cannot stand not knowing! :)
                          thanks!!
                            @Yveaux
                            thanks!!
                            YveauxY
                            YveauxY
                            @BulldogLowell Just some stuff for in the plane tonight, should you decide to dive into 1.4 a little deeper.
                            It shows how to create and send messages with the 1.4 library.
                            The example below shows 3 possible scenarios, each with their own pros & cons. Combinations are also possible.
                            It will depend on the application and your preference which one to choose.
                            I prefer option 1.
                            #define NODE_ID              (64)
                            #define CHILD_ID_TEMP         (0)
                            #define CHILD_ID_HUMIDITY     (1)
                            #define CHILD_ID_LIGHT        (2)
                              gw.begin( NULL, NODE_ID, false /*relay*/ );
                              gw.sendSketchInfo("My 1.4 Sensor", "1.0");
                              gw.present(CHILD_ID_HUMIDITY, S_HUM);
                              gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                              // ... fetch data from sensors ...
                              double humi = SHT2x.GetHumidity();
                              double temp = SHT2x.GetTemperature();
                              int lightLevel = analogRead(LDR_PIN)/10.23;
                              // Option 1 -- compact, message on stack:
                              // Create a new MyMessage instance for every message to send,
                              // and set the value by chaining (using the reference to the
                              // MyMessage instance returned by the constructor)
                              gw.send( MyMessage(CHILD_ID_TEMP, V_TEMP).set(temp, 1) );
                              gw.send( MyMessage(CHILD_ID_HUMIDITY, V_HUM).set(humi, 1) );
                              gw.send( MyMessage(CHILD_ID_LIGHT, V_LIGHT_LEVEL).set(lightLevel) );
                              // Option 2 -- longer, message in RAM:
                              // Create the MyMessage instance once, and re-use it for every sensor
                              static MyMessage msg;
                              msg.setSensor(CHILD_ID_TEMP);
                              msg.setType(V_TEMP);
                              msg.set(temp, 1);
                              gw.send(msg);
                              msg.setSensor(CHILD_ID_HUMIDITY);
                              msg.setType(V_HUM);
                              msg.set(humi, 1);
                              gw.send(msg);
                              // etc.
                              // Option 3 -- static msg for each sensor. More RAM, less CPU:
                              // Create a MyMessage instance for each sensor once.
                              static MyMessage msgTemp;
                              static MyMessage msgHum;
                              static MyMessage msgLight;
                              static bool initDone = false;
                              if (!initDone)   // Better to do the init once in setup(), it is only here for clarity.
                                msgTemp.setSensor(CHILD_ID_TEMP);
                                msgTemp.setType(V_TEMP);
                                msgTemp.setSensor(CHILD_ID_HUMIDITY);
                                msgTemp.setType(V_HUM);
                                msgTemp.setSensor(CHILD_ID_LIGHT);
                                msgTemp.setType(V_LIGHT_LEVEL);
                                initDone = true;
                              msgTemp.set(temp, 1);
                              gw.send(msgTemp);
                              msgHum.set(humi, 1);
                              gw.send(msgHum);
                              msgLight.set(light);
                              gw.send(msgLight);
                              // ... e.g. sleep the CPU & radio
                            • YveauxY Yveaux
                              I prefer option 1.
                                msg.set(temp, 1);
                                gw.send(msg);
                                msg.setType(V_HUM);
                                msg.set(humi, 1);
                                gw.send(msg);
                                // etc.
                                  initDone = true;
                                gw.send(msgTemp);
                                gw.send(msgHum);
                                gw.send(msgLight);
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Yveaux
                              WOW! thanks!
                              I appreciate that and will look it over. Hopefully I'll have something to share with you tomorrow (or a problem that I need help).
                              thanks again.
                              Jim
