  2. Announcements
  3. MySensors 1.5 Released
34 Posts 21 Posters 19.0k Views 9 Watching
  • hekH Offline
    hekH Offline
    Master branch on github is now 1.5! This means that we finally made a drop from the (hopefully) stable development branch.
    This version should be backward compatible with 1.4 both over-the-air and sketch-vise unless you use the constructor arguments which has changed to cope with a more flexible architecture.
    So you can safely update one node (or gateway) to 1.5 without affecting the rest of your radio network.
    Here are some of the new stuff (we have probably talked about most of it already on the forum):
    • Message signing using ATSHA204 hardware or software driver
    • Multiple radio transport driver architecture
    • RFM69 radio support
    • Support for multiple hardware layers (ATMega328 default implementation)
    • New sensors: RGB, RGBW, Color, Multimeter, HVAC, Sprinkler, Water leak, Sound, Vibration, Moisture
    • New variables: Voltage, Current, RGB RGBW, Id, Unit prefix, Setpoint, Level
    • Allow indication LEDs (tx,rx,err) on sensors
    • Sensor presentation description message
    • OTA updates using on-board flash (and DualOptiboot bootloader)
    • Allow SOFTSPI configuration from MyConfig.h
    • Bugfixes!
    I'm having problems getting the codebender examples up and running with 1.5. Hopefully I'll get some support on this soon.
    YveauxY DidiD 2 Replies Last reply
    • E Offline
      E Offline
      elite
      Congrats on the release - and thanks for all the hard work
      • scalzS Offline
        scalzS Offline
        Congrats too! lots lots of fun in perspective...
        • barduinoB Offline
          barduinoB Offline
          barduino
          Great news!!!
          • greglG Offline
            greglG Offline
            gregl
            Wow...great stuff Hek.
              • Bugfixes!
              YveauxY Offline
              YveauxY Offline
              @hek Good move! Thanks! :+1:
              • FrancoisF Offline
                FrancoisF Offline
                Francois
                Great work thanks for all the hard work you putting in to this Hek and team
                • Q Offline
                  Q Offline
                  Qu3Uk
                  wrote on last edited by Qu3Uk
                  When you say backwards compatible does this include a 1.5 sensor talking to a 1.4 gateway? I'm assuming not.
                  Can't wait to update though. I'm working on an RGB light so this is cool.
                  • epierreE Offline
                    epierreE Offline
                    epierre
                    @hek I hope you haven't change fields order this time, backward compatibility is a must !
                    z-wave - Vera -> Domoticz
                      • Bugfixes!
                      DidiD Offline
                      DidiD Offline
                      Didi
                      Great work
                      if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                      • D Offline
                        diggs
                        looking forward to trying the new release.
                        One question, it mentions the new sensors, where would I find the "multimeter" sensor? Had a look but could not see anything
                        • hekH Offline
                          hekH Offline
                          @diggs
                          I haven't made sketch-examples for all new sensor types yet. The community needs to help me with that. :)
                          D 1 Reply Last reply
                          • D Offline
                            Dheeraj
                            @hek and team. congratulation on new milestone.
                            • JohnJ Offline
                              JohnJ Offline
                              John
                              Congratulations to you and all contributors! I will try to update the plugin asap.
                              • RJ_MakeR Offline
                                RJ_MakeR Offline
                                RJ_Make
                                Yeeeeeee Haaaaaaaw :bowtie:
                                RJ_Make
                                • epierreE Offline
                                  epierreE Offline
                                  epierre
                                  @hek I have them all already:
                                  Water leak,Moisture : my leaf wetness
                                  Sound: I have stopped by waiting to have a real decibel algorithm... but I need FFT for that...
                                  Vibration: done it too ;-) help yourself !
                                  https://github.com/empierre/arduino/blob/master/FloodSensor.ino
                                  https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
                                  https://github.com/empierre/arduino/blob/master/SoundSensor2.ino
                                  https://github.com/empierre/arduino/blob/master/VibrationSensor.ino
                                  hekH 1 Reply Last reply
                                  • epierreE epierre
                                    hekH Offline
                                    hekH Offline
                                    @epierre
                                    Thanks, I'll take a look at them and possibly lift them into the examples folder.
                                    For the flood sensor, what kind of conductivity probe are you using.
                                    • epierreE Offline
                                      epierreE Offline
                                      epierre
                                      @hek: two conductors ;-) well anything you want here it is binary logic, you don't need to mesure the resistance to know how wet it is ...
                                      • O Offline
                                        O Offline
                                        oded00
                                        What is the best practice to upgrade from 1.4?
                                        i'm using vera
                                        • hekH Offline
                                          hekH Offline
                                          As said above.. you don't need to update everything in one big bang unless you want to use the new features. Add new sensors with the updated library if you want.
