  2. Announcements
  3. MySensors battey board revision 1.0
65 Posts 20 Posters 56.8k Views 6 Watching
  • axillentA
    axillentA
    axillent
    I'm opening this topic for the discussion of the Mysensors board.
    We are very close to production this why an open discussion is very important to fix critical things and to understand your interest on the board.
    The price will very depends on volumes. But lets come to that later.
    Preliminary characteristics:
    50x50 mm size
    on board AAA battery holder
    very efficient step to power up at 3.3V from any single AAA (alkaline or Ni-MH/CD)
    atmega328p running at 1MHz from internal oscillator with ability to speed up to 8MHz on the fly
    NRF24L01 with antenna
    solar power switch, connect external solar panel 0.8-5.5V and solar will be the main power while solar voltage is higher than battery
    one I2C GROVE connector which can be used as a connector to A5/A4
    one GROVE analogue connector to A0/A1
    one GROVE digital connector to D2/D3
    high precision very low power I2C temperature sensor with ability to wake up MCU at temperature alertt
    one red LED
    to program you will need an external USB<->UART like you need to program pro-mini
    sense and drive
    daulagariD 1 Reply Last reply
    • DammeD
      DammeD
      Damme
      Code Contributor
      Any schematic or picture?
      axillentA 1 Reply Last reply
      • DammeD Damme
        axillentA
        axillentA
        axillent
        sense and drive
        DammeD AnticimexA 2 Replies Last reply
        • axillentA
          axillentA
          axillent
          wrote on last edited by axillent
          blnking example running
          just build a configured version of optiboot, add our board to boards.txt and tested upload
          next will be to test internal (battery voltage measurement, solar voltage,temperature sensor) and external conectors
          after that will be radio test
          looks a bit ugly but this is only because it is a simplified prototyping production
          sense and drive
          • axillentA axillent
            DammeD
            DammeD
            Damme
            Code Contributor
            @axillent
            I dont know how much space you have but why not have connectors for the rest of the pins? (atleast miso, mosi d5 d6 d7 and a6 (to be able to hade interrupts on both d3 and a6)
            what will the power consumption be?
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              Exciting stuff!
              1. What sort of price are we talking about approximately? Made in China?
              2. Is there a reason for the 50x50 size? Do you have an enclosure in mind? It almost seems to fit inside a wall junction box.
              3. Still wouldn't have minded an AA-battery instead for more than twice the typical mAh. It's only a few mm more. Perhaps this is a moot point, as the more power hungry sensors that I have in mind wouldn't work on battery anyway.
              axillentA 2 Replies Last reply
              • DammeD Damme
                @axillent
                axillentA
                axillentA
                axillent
                @Damme we had an internal discussion to find a trade of between size and possibilities.
                You see now a very balanced compromise.
                It is also two programming sockets ISP & FTDI and you can actually also find MISO/MOSI/SCK/D0/D1 here
                power consumption from hardware size id minimised as much as possible. This why e use 3.3V and not 5V, this why we do not use crystal for the MCU, the temperature sensor needs power a hundred times lower comparing to DS18B20
                while MCU is sleeping the theoretical consumption from the battery have to be bellow 6uA
                All the rest will very depends on software. We expect to build a special Mysensors library to handle all board specific staff
                sense and drive
                DammeD 1 Reply Last reply
                • DammeD
                  DammeD
                  Damme
                  Code Contributor
                  Me myself was thinging on using li-ion and depending on space charge controller but atleast protection.
                  They come in all sizes and dimensions.
                    DammeD
                    DammeD
                    Damme
                    Code Contributor
                    wrote on last edited by Damme
                    Ofc, missed that one!
                    I think it would be possible to atlease leave solderpads for the rest of the IO incase someone wants to to special stuff.
                      Exciting stuff!
                      axillentA
                      axillentA
                      axillent
                      @bjornhallberg
                      1. At the beginning the retail price will be $15-22, still under discussion.
                        We are in a potential partnership with 1-3 DIY companies having a good reputation already, most of them are located in China but with international team.
                      2. the reason is only a space needed to support selected functionality.
                        This is a BATTERY sensor designed for wireless indoor and outdoor sensors where you actually will use only 1-2 sensors.
                        For the wall tasks we will have a stackable design with a set of compatible boards able to feet standard wall sockets (I hope)
                      3. there is no ideal solution. I expect a good time performance as soon as we will use a well handled software side + alternative power like solar power
                      sense and drive
                      • DammeD Damme
                        axillentA
                        axillentA
                        axillent
                        @Damme look
                        for indoor usage, while you not very limited with size and you want many things been connected it is still a good choice to use one of the standard arduino
                        we will do our own board to support real competition with wall z-wave devices but this is second priority
                        the first priority are small and battery operated devices
                        for this purpose you will not find a well prepared standard arduino
                        sense and drive
                          Exciting stuff!
                          axillentA
                          axillentA
                          axillent
                          @bjornhallberg said:
                          1. Still wouldn't have minded an AA-battery instead for more than twice the typical mAh. It's only a few mm more. Perhaps this is a moot point, as the more power hungry sensors that I have in mind wouldn't work on battery anyway.
                          it is not too late to remove holder from the board. it is an option we need to decide.This will allow to be more flexible with power source. But with the holder you can run out of the box at least with temperature sensor
                          sense and drive
                          • DammeD Damme
                            axillentA
                            axillentA
                            axillent
                            lion is too bad for outdoor usage at least for the places in the world were snow is a normal thing at winter))
                            AAA is much more universal because you can choose between alkilene and rechargeable
                            with lion you actually fo not need a step-up
                            you can use 3.3V version of pro-mini with direct connection between VCC and lion
                            radio you can connect to lion using 3.3V LDO or 1-2 1n4148 connected simultaneously to drop voltage from 4.2 (fresh lion) bellow 3.6V (maximum allowed for radio)
                            sense and drive
                            Z 1 Reply Last reply
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              wrote on last edited by bjornhallberg
                              As long as you have the option to (easily) connect / solder wires for a separate 1x or 2x AA holder, or solar I'm sure it'll be fine. And the on-board AAA-battery holder doesn't significantly increase price and / or complicate things. Sounds like something that would be hard to do right without breaking off if it doesn't have the support of an enclosure.
                              Does it measure and report battery level by any chance?
                              $15-22 doesn't sound too bad. I mean, if you add up the cost of components for a simple DIY sensor node, including a prototype board etc, you'd come pretty close to $15. And then you'd still be stuck with a lousy Ebay boost module drawing 1mA.
                                axillentA
                                axillentA
                                axillent
                                @bjornhallberg the holder adds less than half a dollar to the final price.
                                You always can use solar connector for any external alternative source
                                you even will be able to extend life by connecting external AA, on board AAA will start working as soon as AA will run out
                                battery voltage (level) and external source voltage can be measured and reported by radio. The required connections are build in
                                Price is still tricky thing because of discussion going on and also because we all are new to such a business. We will need to have also some profit to support project development. I hope all will be withing $15-$22. We are willing to be competitive but not the cheapest. A good level of innovation is an essential idea of the whole project.
                                Design is open source and anyone can do it himself.
                                sense and drive
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @axillent Looks good. But is not the LED symbol reversed in the schematics?
                                  I am considering making a board as well for personal use (open HW of course), but using through hole components a bit more extensively for ease of customization. And probably a sockeded MCU so I don't have to include programming interfaces. In the future, I (and hopefully all of you) will push new FW to the board OTA so there will not be a need for holes in the case :)
                                  But I might be interested to join in if your are ordering a batch of these as well. Will it be panelized and pick/placed as well?
                                  axillentA Z 2 Replies Last reply
                                  • AnticimexA Anticimex
                                    axillentA
                                    axillentA
                                    axillent
                                    @Anticimex thank you for your attention ) yes, led had a wrong orientation, it was fixed.
                                    I have an DIY experience for making PCB and like you at the beginning willing to use through hole components mostly.
                                    But through the real practice I came to a conclusion that SMD is easy to use, it is cheaper and need much less space.
                                    I also used to make zero-hole PCB using SMD only. This type of PCB requires from me 20-30 minutes of time only for the full production circle. There is 0.5mm copper plates, I use office scissors to cut it in a second.
                                    The programming interface (ISP) is not only for the bootloader programming. It can be used for bootloader upgrade or hardware debugging.
                                    Even Nano have it.
                                    The programming interface (FTDI) can be used also for usual Serial.print debugging.
                                    Both interfaces also can be used for additional I/O.
                                    Sure, there is no absolute ideal solution. We spend a few months discussing what is a good trade off for this board and you see the result.
                                    What do you mean by "panelized and pick/placed as well"?
                                    sense and drive
                                    AnticimexA marceltrapmanM 2 Replies Last reply
                                      Even Nano have it.
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @axillent By panelization that I mean that you send the board to the fab with a BOM, and some reels, and have them solder the components to the board as well. Most if not all fabs will then require you to panelize the board if also picking&placing (that is, multiply the board on a bigger standard-size board, that is fed to the pick&place machine).
                                      Example of a PCB panel
                                      Having a panelized board could also reduce cost for a non pick&placed design, as it allows the manufacturer to make them with less effort (less cutting and less waste).
                                      For larger batches this is a good way to save a lot of work, and if good decisions are made on layout, design and component selection, it is not overly expensive either.
                                      I also like SMD, but for "my" board, I was more thinking of having a generic back-bone which can accept a variety of components, so the user can choose what to put on it and use if for various purposes.
                                      Some "standard" interfaces need to exist of course (socket for MCU, power, RF), but the rest (decoupling, IO, etc) is just left "empty" and for the user to populate with the components they would like.
                                      And don't get me wrong, ISP/FTDI is really good to have, especially on "in progress" projects. But for the gritty end product, I personally prefer to program and debug the MCU on a breadboard, and then put it in a socket in my optimized board/casing. I even consider using the Arduino "as is".
                                      But it could be that I cannot get my casing to be as small as I want it, without soldering the "bare" MCU directly on the board, and then of course programming interfaces will be needed :)
                                        Even Nano have it.
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        Do you use this thickness for all boards?
                                        And what thickness is the copper?
                                        Fulltime Servoy Developer
                                        • bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          Well, needless to say it sounds interesting, when it's been built and tested I'd surely buy a couple of boards. Right now I'm not sure how many actual battery sensors I need and if the sensors I want to run are even viable for battery operation anyway.
                                          I think that for me anyway, more practical things are an issue, like avoiding Swedish customs charges, and finding a GOOD open source automation software so that I can actually use my sensors and not just build them ;-)
                                          If you could also manufacture a separate 3.3V boost circuit based on a modern chip that would be fantastic. I think that is turning out to be a hurdle for most of us that aren't comfortable with SMD/SMT and/or how to nice integrate it into DPI prototyping.
