Need feedback/help to design an API
  • Hi there,
    I am currently busy designing a MySensors API. This project is named OhMySensors and is available at https://github.com/marvinroger/OhMySensors. Don't mind the front-end code yet.
    This is basically a node.js application acting as a controller, and as a storage layer for the data sent by the sensors. All the data is available through a WebSocket API, documented on the Wiki.
    Do you think the API is well designed? Would you change something? If there are some front-end devs around here, would it be easy for you to build a front-end based on this API?
    Thanks for your feedbacks.
  • Admin
    OhSoSweet... 🙂
    Haven't tried jsblocks myself... better check it out.
  • Hero Member
    a good API for the outside is the one I interface to Domoticz:https://imperihome.zendesk.com/hc/en-us/articles/203875139-ISS-BETA-SPECS
    It has a lot of common functionalities in all home automation controllers (Vera, Fibaro, ....) plus independant as Philipe Hue, Netatmo...
    Here you just collect data, are you going to make a datahub ? there should be a cllient interface such as the one described above to expose it to the outside world.
    I thought, but didn't finish, something to make a UIless controller, that Imperihome could query, thus reducing the maintenance of both end UI.
  • 5
  • 17
  • 75
