  2. Announcements
  3. MySensors micro step-up module revision 1.0
25 Posts 13 Posters 16.1k Views 1 Watching
  • axillentA
    axillentA
    axillent
    wrote on last edited by axillent
    Through a discussion on the forum we found a potential interest to the step-up module with excellent battery saving capabilities
    We decided to present to you such a module
    It is actually same technology as will be used for MySensors Battery board, but it allows to choose any other board for your battery operated project.
    Module is using one of the best in class chip with hight efficiency and low quiescent current, this allows to run your device for longer time
    Module is designed with standard 2.54 pitch connector, can be easily connected using dupon wires
    Output voltage can be selected by switch 3.3V or 5V
    As power source you can use:
    • for 3.3V output - 1-2 alkaline, 1-3 NiMh/NiCd or solar up to 3.3V
    • for 5V - 1-3 alkaline, 1-4 NiMh/NiCd or solar up to 5V
    100mA output for 3.3V or 70mA for 5V are at minimum guaranteed
    Size is just 15x15mm
    Estimated retail price before shipping cost is $5
    Anyone interested?
    Prototype is on photo fully tested
    sense and drive
    YveauxY B 2 Replies Last reply
    • bjornhallbergB
      bjornhallbergB
      bjornhallberg
      wrote on last edited by bjornhallberg
      Great news! How and where will these be sold?
      I got some sample boost chips from TI today, but soldering them seems hopeless and finding the recommended components isn't easy or cheap so I reckon this is a pretty good deal. And a lot easier to put into production than the whole battery powered board. Also, no need to update the design for this ever, should it work as intended.
      Kudos for soldering this ...
      axillentA marceltrapmanM 2 Replies Last reply
      • clippermiamiC
        clippermiamiC
        clippermiami
        Excellent idea.
          axillentA
          axillentA
          axillent
          @bjornhallberg we are in discussion with one of the DIY company, they have a production abilities and also a distribution network.
          quality should be OK
          we will announce all details as soon as we will enter final agreement
          P.S. The temperature sensor from our board is even smaller in size. I'm soldering all them using regular china soldering iron
          it is hard to imagine, it was hard to imagine for myself too just 6 month ago
          also this I do :)
          sense and drive
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @bjornhallberg said:
            I got some sample boost chips from TI today, but soldering them seems hopeless.
            I have not done this myself yet (this weekend it is my turn) but I found some excellent video's on the subject of soldering SMD's. Just google for 'soldering dmd' ( if you have not already done that :)
            Fulltime Servoy Developer
            • marceltrapmanM marceltrapman
              bjornhallbergB
              bjornhallbergB
              bjornhallberg
              @marceltrapman I'd be willing to give it a try, but the most immediate hurdle is finding the right capacitors and inductor. Finding small quantities cheaply has proven more hopeless than soldering. And the components you get on Ebay, could you ever trust them? Ceramic caps in the uF range turned out to be more expensive than I had anticipated etc etc ... therefore ... you'd be hard pressed to do it yourself for less than $5. Not to mention the work. Plus you have the 5V option that I never considered.
              @axillent That is some crazy small chip! Just out of curiosity, where did you buy that soldering iron (because I need a new one as well, sigh).
              axillentA 1 Reply Last reply
                axillentA
                axillentA
                axillent
                @bjornhallberg
                I purchased it at local store
                surprisingly some goods are cheaper to buy locally than from ebay or ali
                it is a complete soldering station at a value of about $90
                sense and drive
                • axillentA axillent
                  Anyone interested?
                  YveauxY
                  YveauxY
                  @axillent Did you do some measurements on the stability of the supply when powering an Arduino + radio?
                  • YveauxY Yveaux
                    axillentA
                    axillentA
                    axillent
                    @Yveaux what kind of stability you are interested in?
                    the output voltage will be stable while the source is able to source at a level above 0.7V
                    sense and drive
                    YveauxY 1 Reply Last reply
                      YveauxY
                      YveauxY
                      @axillent There was a lot of discussion in another thread about radio troubles caused by fluctuations in power supply. Performance could be improved significantly by adding a capacitor to the supply of the radio. It would be nice if the whole could be powered by just this module, without requiring extra capacitors.
                      So, please do some tests with a radio connected running a mysensors sketch with your step-up module (or maybe the whole board once you connect the radio) and compare the results to when directly powered from batteries (without step-up). The range and amount of lost packets should be comparable.
                      • YveauxY Yveaux
                        axillentA
                        axillentA
                        axillent
                        @Yveaux
                        the need of the capacitor for radio is depends on how long are the wires (or PCB tracks) from power source to radio
                        my step-up module have a sufficient capacitor (good quality low ESR X7R) on the output
                        if wires will be not long there will be no need of an additional capacitor
                        otherwise an additional capacitor need to be soldered close to radio
                        on Battery board I add a second capacitor for unquestionable performance
                        sense and drive
                          Anyone interested?
                          B
                          B
                          Bandra
                          @axillent Looks like a much-needed part for our battery sensors. Is there any chance of moving the pins together to emulate the current step converter in the store? Ie, having three pins in a row: Vout GND Vin. This makes it a drop-in replacement for the existing part.
                          • greglG
                            greglG
                            gregl
                            Wow..Nice! Nice fingernails too...i could never photo mine...all chewed up!!! ;-)
                            With respect to the capacitior for the radio - i saw @axillent you are soldering a tantalum cap directly to the radio - i really like that method!
                            http://forum.mysensors.org/topic/185/battery-sensor-v-1-0-pcb/29
                            Alex - i guess this chip cannot output both 3.3 and 5V at the same time, so would it be possible to have a module with two of these chips each one at 3.3 and the other at 5v ??
                            -Then it can be used for 5v sensors/devices.
                            Greg
                            • Z
                              Z
                              Zeph
                              What is the chip used?
                              • Z Zeph
                                axillentA
                                axillentA
                                axillent
                                @Zeph it is the same as for Battery board - tps61222. It has lowest quiescent current on the market
                                sense and drive
                                • BSoftB
                                  BSoftB
                                  BSoft
                                  @axillent said:
                                  tps61222
                                  In the past i was thinking on TPS78233. The idea was solder it on a pro mini board, then i think it could be difficult to solder something too small and quit the idea :D
                                  • B Bandra
                                    axillentA
                                    axillentA
                                    axillent
                                    @Bandra
                                    unfortunately there is no standard convention of this type. It is hard to match all different needs
                                    input and output connectors are a generic tradeoff
                                    sense and drive
                                    • greglG gregl
                                      Greg
                                      axillentA
                                      axillentA
                                      axillent
                                      @gregl
                                      current draw from the battery is a multiplication from the stepup ratio
                                      this means that current draw from the buttery with 5V output is 1.5 times higher comparing to 3.3V with the same current on the output
                                      also current on the output much less depends on the voltage etc. MCU will draw 1-5mA regardless (with some extend) the VCC voltage
                                      this leads into conclusion that as lower VCC used as better will be battery life
                                      In my opinion 2.4V will be even more optimal for Battery board, but it is much more convenient to have 3.3V
                                      While you need 5V you need to choose:
                                      • best choice is to find all needed components able to work from 3.3V. For example PIR sensor is usually run from 4.5-20V. But there is no problem to purchase PIR running from 0.7-6V
                                      • least optimal choice is to select 5V as a basic operation. This way you can use cheap LDO (like XC6206P332MR) to source radio
                                      having two channels in stepup as you requested will double cost because you will need double number of components
                                      and you always can use two universal modules simultaneously, one configured to 3.3V and other to 5V
                                      sense and drive
                                      • RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        Interested.. any ETA?
                                        RJ_Make
                                        hekH 1 Reply Last reply
                                        • RJ_MakeR RJ_Make
                                          @ServiceXp
                                          A sample has been ordered from factory. When Alexander is back from vacation we'll verify and order production. A wild guess 1-1.5 month.
