  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.9k Views 15 Watching
  • petewillP
    petewillP
    petewill
    wrote on last edited by petewill
    Hi Everyone,
    I recently decided to make a very simple/cheap scene controller with a 1x4 membrane keypad. I normally try to automate as many things as I can but sometimes it's just nice to have some physical buttons. I have this in my bedroom so I can turn on/off lights, fans etc without having to open my eyes. Hopefully this will be of use to someone...
    https://youtu.be/KMGj5Bi7vL0
     * Version 1.0 - PeteWill
     * A simple scene controller for use with MySensors.  8 scenes can be executed.
     * 4 with short button presses and 4 with long button presses (held .5 seconds or more).
     * Watch a how to video here: https://youtu.be/KMGj5Bi7vL0
    #include <Keypad.h>
    #define NODE_ID 14 // or set to AUTO if you want gw to assign a NODE_ID for you.
    #define SN "Scene Controller"
    #define SV "1.0"
    #define KEYPAD_CHILD_ID 0
    MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
    const byte ROWS = 4; //four rows
    const byte COLS = 1; //three columns
    char keys[ROWS][COLS] = {
      {'1'},
      {'2'},
      {'3'},
      {'4'}
    byte rowPins[ROWS] = {6, 7, 4, 5}; //connect to the row pinouts of the keypad
    byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
    Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    byte lastState;
      gw.begin(NULL, NODE_ID);
      gw.sendSketchInfo(SN, SV);
      gw.present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
      keypad.addEventListener(keypadEvent); // Add an event listener for this keypad
      char key = keypad.getKey();
    void keypadEvent(KeypadEvent key) {
      switch (keypad.getState()) {
        case PRESSED:
          lastState = 1;
          break;
        case HOLD:
          lastState = 2;
          break;
        case RELEASED:
          int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
          if (lastState == 2) {
            keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
          gw.send(scene.set(keyInt));
          break;
    Here is a link for a keypad: http://www.ebay.com/itm/171505110526?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Here is another option for a scene controller keypad contributed by @AWI. It has capacitive touch buttons and an interrupt to battery power can be used. Thanks @AWI!
    http://forum.mysensors.org/topic/2001/how-to-make-a-simple-cheap-scene-controller-with-video/14
      Great work @petewill!
      • AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        Great & simple.. for a "touch" version (similar code/connection, price is for 10 pcs. ;-) )
          I have this on the lab-bench also... But I haven't had time to try it out yet.
          http://www.ebay.com/itm/251631847404?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
          • petewillP
            petewillP
            petewill
            @AWI & @hek thanks, yeah, I have been wanting to play with capacitive touch too! Someday soon hopefully :)
            DrJeffD M AWIA 3 Replies Last reply
            • petewillP petewill
              DrJeffD
              DrJeffD
              DrJeff
              Another stellar video @petewill ! Thanks! Now time to 3D print a box and add batteries for your night stand.
                msebbe
                Cool! What do you think about a battery version of this? (short battery life?)
                • HoffanH
                  HoffanH
                  Hoffan
                  @petewill
                  Where did you get your touchpad?
                    AWIA
                    AWIA
                    AWI
                    @petewill To get you started with capacitive: the ones with the TTPxxx chip in 4/8/16 button versions like have pins with leds for every button. Can also generate an interrupt at keypress (so no need to poll the keyboard in low-power applications). And can can also be used with a simple serial protocol (only 2/3 pins needed). I would be happy to supply the code (but don't want to mess-up your great topic any further ;-) )
                    • petewillP
                      petewillP
                      petewill
                      @DrJeff Yes, that would be great! Someday...
                      @msebbe Yes, this version would have short battery life because it's not sleeping. But, if @AWI posts his code a battery version sounds possible.
                      @Hoffan you can get them here: http://www.ebay.com/itm/171505110526?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      @AWI That would be great if you could supply the code for a capacitive sleeping node! If you could supply the wiring diagram and parts list also I will add it to the first post as another option (giving credit to you of course). Thanks!
                      • Tomasz PazioT
                        Tomasz PazioT
                        Tomasz Pazio
                        @petewill really nice thing which can also be a nice solution for "old" people leaving with us.
                        I was thinking to use matrix keypad which I own.
                        Any help from community? probably analog input should be used as digital input because of missing inputs on nano...
                        link
                        AWIA petewillP 2 Replies Last reply
                        • Tomasz PazioT Tomasz Pazio
                          link
                          AWIA
                          AWIA
                          AWI
                          @Tomasz-Pazio The keyboard you mention is a standard 4 x 4 matrix keyboard. You can wire it with 8 pins for which you can also use the analog pins. These can be addressed by A0, A1, etc. The library @petewill used in the sketch can handle this keyboard.
                            link
                            petewillP
                            petewillP
                            petewill
                            @Tomasz-Pazio You will also need to adjust the code as mine is specifically designed to use 4 buttons. It shouldn't be too difficult to modify though.
                            • AWIA
                              AWIA
                              AWI
                              Not even close to @petewill 's great build descriptions but here my version the "touch" version which can be battery operated. The used keyboard uses around 150uA. The touch panel generates an interrupt which wakes the arduino, reads the key and swiches a scene.
                              upload-10b4b56c-4f8e-4f43-ac06-69217e48adcb
                              The code below toggles between 'Scene ON' and 'Scene OFF' and stores the last state in EEPROM.
                              All credits to @petewill
                               *   	   1.1 - AWI
                               *  with an 8 key keypad, make sure to attach the pins and fill keyPins[] resp.
                              #define SV "1.0"
                              const byte KEYPAD_CHILD_ID = 0 ;
                              MyMessage scene_on(KEYPAD_CHILD_ID, V_SCENE_ON);
                              MyMessage scene_off(KEYPAD_CHILD_ID, V_SCENE_OFF);
                              const int DV = 2;									//DataValid (=key pressed) pin goes there
                              const int DV_int = DV-2;							//DataValid interrupt on pin 3 => 1
                              const unsigned long SLEEP_TIME = 3600000 ;			// sleep for an hour (or more if you want to)
                              volatile boolean DVint = false ; 					// interrupt flag, set by interrupt
                              const byte keyPins[] = {A0, A1, A2, A3, 3, 4, 5, 6};// keypad pins, (8 pin keyboard)
                              byte keyState[8]  ;									// hold current keystate (copy of EEPROM)
                              void setup(){
                              	pinMode(DV,INPUT);          					// Data Valid (interrupt)
                              	for (int i=0 ; i < sizeof(keyPins); i++){
                              		keyState[i] = gw.loadState(i) ; 			// load last Scenestates from EEPROM
                              // loop only if interrupt, else sleep
                              void loop(){
                                  // if so get a key value and send to MySensosrs network
                              	byte key = fetchData();    						// if so fetch key
                                  Serial.println(key);							// serial print as binary
                              	if (key > 0){									// (key-1) is used as index
                              		boolean keyVal = !gw.loadState(key-1);		// use lastState from EEPROM and toggle
                              		gw.saveState(key-1, keyVal);				// save new state to EEPROM
                              		if (keyVal) gw.send(scene_on.set(key-1));	// set the Scene On or Off
                              		else gw.send(scene_off.set(key-1));
                                  DVint=false;									// reset interrupt flag
                              	gw.sleep(DV_int, RISING, SLEEP_TIME);			// node wakes up on key interrupt or time
                              	Serial.println(" key pressed or time trigger ");
                              // interrupt routine, only sets flag
                              void intrp(){DVint = true;};
                              // fetch serial data, only highest number key is returned
                              byte fetchData(){
                              	int Key=0;                        				// default key = 0 (nothing pressed)
                              	for (byte i = 0 ; i < sizeof(keyPins) ; i++){	// check each key,
                              		if(digitalRead(keyPins[i]) == HIGH) Key=i+1;// set key if pressed (now only highest key)
                              	return Key;										// return Key (0 if no key pressed)
                              petewillP 1 Reply Last reply
                              • Tomasz PazioT
                                Tomasz PazioT
                                Tomasz Pazio
                                ok easy.... two changes and 32 scenes can be managed :)
                                const byte COLS = 4;
                                byte rowPins[ROWS] = {3, 4, 5, 6};
                                byte colPins[COLS] = {A0, A1, A2, A3};
                                char keys[ROWS][COLS] = {{'1','2','3','A'},
                                                         {'4','5','6','B'},
                                                         {'7','8','9','C'},
                                                         {'*','0','#','D'}};
                                 keyInt = keyInt + 100;
                                • AWIA AWI
                                   *   	   1.1 - AWI
                                  #define SV "1.0"
                                  void setup(){
                                  void loop(){
                                  byte fetchData(){
                                  petewillP
                                  petewillP
                                  petewill
                                  @AWI Excellent, thanks for adding the code for the capacitive touch, battery operated sensor! I added a link to your post in my initial post.
                                  • B
                                    B
                                    brom_snor
                                    Hi Petewill
                                    I 'd like to build your Scene Controller but I am missing the keypad.h library. Where can I get it?
                                    greetings
                                    Brom_Snor
                                    • B brom_snor
                                      Hi Petewill
                                      greetings
                                      Brom_Snor
                                      petewillP
                                      petewillP
                                      petewill
                                      @brom_snor
                                      Sorry about that. I thought it was part of the default libraries. I must have downloaded it a while ago. This one should work: http://playground.arduino.cc/Code/Keypad
                                      • F
                                        F
                                        Fred LaR
                                        Hi all - Another capacitive version with an "out of the bottle" keypad - 4 buttons. Like AWI's version, also toggles between 'Scene ON' and 'Scene OFF', but states are kept in a variable (keyState) - LEDs added for better toogle visibility. Capacitive routine found at http://www.arduino.cc/playground/Code/CapacitiveSensor
                                        Great post from @petewill and nice version from AWI. Thanks!
                                        #define SV "1.2"
                                        #define NODE_ID 20 // or set to AUTO if you want gw to assign a NODE_ID for you.
                                        const byte KEYPAD_CHILD_ID = 1 ;
                                        long time = 0;
                                        long debounce = 800;
                                        const byte keyLeds[] = {14, 15, 16, 17}; //LEDs to turn on/off
                                        const byte keyPins[] = {2, 3, 4, 5}; //capacitive keys
                                        byte keyState = B1111; //save LEDs states
                                        Serial.begin(9600);
                                        for (byte i = 0 ; i < sizeof(keyLeds) ; i++)
                                        { pinMode(keyLeds[i], OUTPUT);
                                        uint8_t pinRead;
                                        pinRead = readCapacitivePin(keyPins[i]);
                                        if (pinRead > 2 && millis() - time > debounce) {
                                        digitalWrite(keyLeds[i], bitRead(keyState,i));
                                        if (bitRead(keyState,i) == 1){
                                        gw.send(scene_on.set(keyPins[i]));
                                        bitWrite(keyState, i, 0);} else
                                        {gw.send(scene_off.set(keyPins[i]));
                                        bitWrite(keyState, i, 1);}
                                        time = millis();
                                        // — readCapPin found at http://www.arduino.cc/playground/Code/CapacitiveSensor
                                        uint8_t readCapacitivePin(int pinToMeasure) {
                                        // Variables used to translate from Arduino to AVR pin naming
                                        volatile uint8_t* port;
                                        volatile uint8_t* ddr;
                                        volatile uint8_t* pin;
                                        // Here we translate the input pin number from
                                        // Arduino pin number to the AVR PORT, PIN, DDR,
                                        // and which bit of those registers we care about.
                                        byte bitmask;
                                        port = portOutputRegister(digitalPinToPort(pinToMeasure));
                                        ddr = portModeRegister(digitalPinToPort(pinToMeasure));
                                        bitmask = digitalPinToBitMask(pinToMeasure);
                                        pin = portInputRegister(digitalPinToPort(pinToMeasure));
                                        // Discharge the pin first by setting it low and output
                                        *port &= ~(bitmask);
                                        *ddr |= bitmask;
                                        delay(1);
                                        // Make the pin an input with the internal pull-up on
                                        *ddr &= ~(bitmask);
                                        *port |= bitmask;
                                        // Now see how long the pin to get pulled up. This manual unrolling of the loop
                                        // decreases the number of hardware cycles between each read of the pin,
                                        // thus increasing sensitivity.
                                        uint8_t cycles = 17;
                                        if (*pin & bitmask) { cycles = 0;}
                                        else if (*pin & bitmask) { cycles = 1;}
                                        else if (*pin & bitmask) { cycles = 2;}
                                        else if (*pin & bitmask) { cycles = 3;}
                                        else if (*pin & bitmask) { cycles = 4;}
                                        else if (*pin & bitmask) { cycles = 5;}
                                        else if (*pin & bitmask) { cycles = 6;}
                                        else if (*pin & bitmask) { cycles = 7;}
                                        else if (*pin & bitmask) { cycles = 8;}
                                        else if (*pin & bitmask) { cycles = 9;}
                                        else if (*pin & bitmask) { cycles = 10;}
                                        else if (*pin & bitmask) { cycles = 11;}
                                        else if (*pin & bitmask) { cycles = 12;}
                                        else if (*pin & bitmask) { cycles = 13;}
                                        else if (*pin & bitmask) { cycles = 14;}
                                        else if (*pin & bitmask) { cycles = 15;}
                                        else if (*pin & bitmask) { cycles = 16;}
                                        // Discharge the pin again by setting it low and output
                                        // It’s important to leave the pins low if you want to
                                        // be able to touch more than 1 sensor at a time – if
                                        // the sensor is left pulled high, when you touch
                                        // two sensors, your body will transfer the charge between
                                        // sensors.
                                        *ddr |= bitmask;
                                        return cycles;
                                        DrJeffD petewillP 2 Replies Last reply
                                        • F Fred LaR
                                          #define SV "1.2"
                                          long time = 0;
                                          Serial.begin(9600);
                                          uint8_t pinRead;
                                          time = millis();
                                          byte bitmask;
                                          *ddr |= bitmask;
                                          delay(1);
                                          *ddr &= ~(bitmask);
                                          *port |= bitmask;
                                          // sensors.
                                          *ddr |= bitmask;
                                          return cycles;
                                          DrJeffD
                                          DrJeffD
                                          DrJeff
                                          @Fred-LaR WOW!
                                          You just perked up my intrest got to try this one!
