  3. Test of Step-Up-Modules (sparkfun, Pololu & china-module) / any other?
26 Posts 8 Posters 16.1k Views 6 Watching
  • A Offline
    A Offline
    ahhk
    i tested 3 step-up-boards in the same configuration /sensor:
    https://www.pololu.com/product/2114/specs
    Sleep-current: 103uA
    https://www.sparkfun.com/products/10967
    Sleep-current: 28uA
    http://www.ebay.de/itm/Elevador-Tension-DC-D-Step-Up-Boost-0-8-3-3-V-a-3-3-V-Arduino-3-3-V-ESP-8266-/221886656856?hash=item33a979b158
    Sleep-current:243uA
    Isn't this the china-module, which normally should be "quite good" (linked at mysensors...)?
    Are there any other step up modules as good as the sparkfun NCP1402-Module? Or better and cheaper china-modules?
    Greetings
    • E Offline
      E Offline
      ericvdb
      wrote on last edited by ericvdb
      I bought these, both the 5V and 3.3V versions
      http://www.aliexpress.com/item/8pcs-Very-small-DC-DC-0-9-5V-to-DC-5V-Step-UP-Boost-Voltage-Converter/32268508188.html
      http://www.aliexpress.com/store/product/8-pcs-Ultra-small-DC-DC-0-8-3-3V-to-DC-3-3V-Step-UP/1525466_32268496143.html
      • A Offline
        A Offline
        ahhk
        Same china-modules. They are crap compared to the sparkfun module......
        • E Offline
          E Offline
          ericvdb
          Crap?? The ones I got consume +/- 60uA while the arduino is sleeping, wouldn't say thats crap...
          • m26872M Offline
            m26872M Offline
            m26872
            I just measured the sleep currents for a few of my nodes (china step-up module linked from there).
            First one really old I just found (I've no clue what sketch or lib is in there) equipped with one DS18B20: 440uA
            Second node with two DS18B20 (one probe style) and a rather fresh code which I think I'd be able to trace lib and IDE versions etc for: 59uA (Not bad!)
            Third one of the "famous two" node 106 (dht22 and bmp180): 98uA
            One note is that the price of these step-ups is high to start with and seems to have doubled in one year, so I doubt I'll buy more of these. And probably and hopefully that goes for any other step-up as well. Better to design for low voltage directly, when you can.
            • A Offline
              A Offline
              ahhk
              440uA and 98uA is far too much! 59uA is quite good but not very good.
              Sleep current is in my config the biggest part, which sucks most of the juice out of the batteries.
              Maybe this is a quality problem of the china-modules?
              I tested my 3 modules with the same node - i just replaced the step-up and measured the current. So my results are based on the same sketch, hardware and lib....
              m26872M 1 Reply Last reply
              • scalzS Offline
                scalzS Offline
                @ahhk:
                but your 59uA is not the booster only. if you want low power you will need to change things in software, including removing watchdog first. and cut off all you can. sorry I have no time for a tut for the moment. I am finishing my rev 1.1 for my board and need to make documentations for boards I started.
                and you are right, there are design things which can affect power consumption of different modules. like inductors, capacitors quality, efficiency... that is why I decided to design entirely my board, so I don't depend on different random quality of external modules and it is reproductible..
                Not easy task I think to depend on external module, mainly for ultra low power. The more variables you add in the system, the more luck you have to break your low power..
                • A ahhk
                  m26872M Offline
                  m26872M Offline
                  m26872
                  @ahhk
                  "Quite good" is far from "crap". 59uA looks coherent with @ericvdb 's 60uA. I never claimed I did a comparative test, I just measured what I had laying around. I doubt the differences I measured depend on the step-ups.
                  • scalzS Offline
                    scalzS Offline
                    another thing too.. How do you measure power consumption? do you have uCurrent?
                    I say this because you get 28uA from sparkfun module. And in datasheet it says it is 30 uA if Vout is 1.9V and 45uA for Vout 3.3v NCP1402 33T1 model, so it is very near ericvdb results..
                    • A Offline
                      A Offline
                      ahhk
                      My Multimeter is a Peaktech 3410. Manual says: "0,1 µA; +/- 1,5 %".
                      BOD disabled, 8mhz internal, only HTU21D and NRF are connected...
                      I still dont understand, why my china-module takes 243uA with same configuration...
                      I am just replacing the step-up module on the breadboard.
                      • scalzS Offline
                        scalzS Offline
                        oki.
                        but for more low power you need to not use the watchdog. and it is used in gw.sleep.
                        others tips too are to set unused pins in output mode, and set them = 0 if I remember right. because it consumes too. look at gammon power savings tuto, you will learn interesting things..
                        for your china module, I can't see on pictures what is the reference of the booster ic...then looking at datasheet would tell more.
                        • A Offline
                          A Offline
                          ahhk
                          what can i save without the watchdog?
                          gw.sleep doesnt work without watchdog, i think? what can be a workaround?
                          i found a blog, where someone tested the powersavings by setting the pins to outputmode. This is <1uA. not a big deal...
                          • NeverDieN Offline
                            NeverDieN Offline
                            Running Gammon's "Sketch J" drops you down to 150nA, and it doesn't set unused pins to anything.
                            • scalzS Offline
                              scalzS Offline
                              yes of course setting pins mode is the last optimizations. Like Neverdie said, you should try Sketch J.
                              but you can do all what you want, if your power supply is not good, you will never get <uA..
                              • A Offline
                                A Offline
                                ahhk
                                To reach <50uA is the target. I dont need to get nA.
                                The difference between 100uA and 50uA is the change intervall of the batteries. every year or nearly every 2 years :D
                                I will take a look at "Sketch J"....sound interesting...
                                • E Offline
                                  E Offline
                                  ericvdb
                                  Just took the time to shoot a pic of my Step-Up consumption, including a Voltage regulator MCP1702-3.3
                                  As you can see, it's consuming 54uA with nothing connected.
                                  Step-Up module: link
                                  The capacitors are really important, one on the input of the step-up module, the other on the output of the MCP1702-3.3, both are 22uF. Without them, consumption is 2.20mA
                                  rvendrameR 1 Reply Last reply
                                  • icebobI Offline
                                    icebobI Offline
                                    icebob
                                    @ericvdb great observation. But this board is not an MCP1702, because MCP1702 is a voltage regulator IC
                                    E 1 Reply Last reply
                                    • m26872M Offline
                                      m26872M Offline
                                      m26872
                                      Reading this thread again makes me remember another observation I did when was trying to get my mini PIR sensor up and running.
                                      I was measuring load current and switched between the old "big" china step-up and the now more common smaller sized one. Identical load. The sleep current was a lot more for the newer smaller one. Could have been those 240uA, not sure but I remember it was the double or something. I was really confused since the two boards look to be populated with the same componets. I didn't look into this further cause I could bearly make the PIR stable on boost supply in any way.
                                      Edit. Power Led disabled, of course.
                                      • icebobI Offline
                                        icebobI Offline
                                        icebob
                                        On my custom node PCB, I will use MCP16251 chip to boost supply to 3.3V.
                                        http://ww1.microchip.com/downloads/en/DeviceDoc/25173A.pdf
                                        By docs, If I use it from one AA battery (1.5V), the efficiency is ~80%, consumes ~14uA. I think it is not bad.
                                        • icebobI icebob
                                          E Offline
                                          E Offline
                                          ericvdb
                                          Where did you read that it's an MCP1702??
                                          This test setup has a Step-Up module to 5V AND a voltage regulator to 3.3V. I never mentioned the MCP is included in the Step-Up module.
