SensorID not stored in EEPROM
  • HI all,
    I am using domoticz in combination with mysensors. It appears that when I reboot the whole system (gateway + sensors) or sometimes even just the sensors, they are rerecognised by the system. I read that the ID should be stored in the EEPROM, but it appears this does not happen. Anything I can test?
    Kind regards
    Steve
  • Admin
    Connect the sensor to your computer and look in the IDE/Serial Monitor. If debug is enabled you should see the node id stored in EEPROM.
  • I rebooted the sensor and now it does store the sensorID. (Could this have been as I was on 1.6.5-R5 and now on 1.7.7 or the IDE?)
  • 4
  • 9
  • 20
  • 274
11.3k
