  3. MyController.org
  4. Releases
Releases
Scheduled Pinned Locked Moved MyController.org
25 Posts 6 Posters 13.3k Views 4 Watching
  • J
    J
    jkandasa
    wrote on last edited by jkandasa
    MyController.org happily releasing 0.0.2-alpha5 build to the world :) It has various new features and bug fixes.
    You can download it from MyController.org website (or) from github page
    Document Page 0.0.2-alpha5
    Demo URL: http://demo.mycontroller.org (Authentication: demo/demo)
    • Suresh MaliS
      Suresh MaliS
      Suresh Mali
      wrote on last edited by Suresh Mali
      Hi jkandasa,
      Amazing job on the MyController. I am trying to install on raspi. Post installation and setting up java, when tried to start. It does not start, below isw the log file.
      Exception in thread "main" java.lang.UnsupportedClassVersionError: org/mycontroller/standalone/StartApp : Unsupported major.minor version 52.0
      	at java.lang.ClassLoader.defineClass1(Native Method)
      	at java.lang.ClassLoader.defineClass(ClassLoader.java:792)
      	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
      	at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
      	at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
      	at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
      	at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
      	at java.security.AccessController.doPrivileged(Native Method)
      	at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
      	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
      	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
      	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
      	at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
      Please help. Thanks.
      J 1 Reply Last reply
      • Suresh MaliS Suresh Mali
        Hi jkandasa,
        J
        J
        jkandasa
        @Suresh-Mali said:
        Hi jkandasa,
        @Suresh-Mali You have to upgrade your java version to 1.8 or later. For raspi Oracle java is recommended with MyController.
        Refer: http://forum.mysensors.org/topic/1907/mycontroller-org/63
        Suresh MaliS 1 Reply Last reply
        • J jkandasa
          @Suresh-Mali said:
          Hi jkandasa,
          Suresh MaliS
          Suresh MaliS
          Suresh Mali
          @jkandasa Thanks, Got it working after updating Java 8JDK, which installed JRE1.8
          Is there a page that I can request for features or changes, like There is no section which shows me information about the type of gateway configured and if its working or not.
          • Suresh MaliS
            Suresh MaliS
            Suresh Mali
            On using I had a couple of questions.
            • How do I configure more than 1 type of gateway. I have a node which runs using ESP8266 and has DHT11 to read Temp+Hum. Its loaded with EasyESP. Its send data through MQTT. And at the same time Raspi is configured with serial gateway using NRF24L01.
            • Add edit option for Timers.
              J
              J
              jkandasa
              @Suresh-Mali Nice! Yes, you have to raise bugs, features requests in github issues section
                J
                J
                jkandasa
                @Suresh-Mali MyController designed to support only one gateway, It can be either serial, eathernet, MQTT or NRF24L01 (via RPI).
                You can attach your DHT11 with NRF24L01, so we can access it from RPI serial gateway.
                Created a feature request for Timers edit option
                • J
                  J
                  jkandasa
                  MyController.org released 0.0.2-alpha5 build
                  DidiD 1 Reply Last reply
                  • bpairB
                    bpairB
                    bpair
                    Awesome - Thanks!
                    • J jkandasa
                      DidiD
                      DidiD
                      Didi
                      @jkandasa
                      :+1:
                      if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                        mvader
                        @jkandasa nice release. this is working well.
                        for others who run into this.
                        i couldn't get mine to start. i looked at the logs and read that i should stop - rm db file - start
                        and that worked.
                        • M mvader
                          and that worked.
                          J
                          J
                          jkandasa
                          and that worked.
                          @mvader Thank you! I forget to mention this. You did it!!
                          0.0.2-alpha5 version has huge changes in database, Hence I could not support for upgrade. I'm sorry for that.
                          • J
                            J
                            jkandasa
                            Your requests are in 0.0.2-alpha5, Kindly check it.
                            @diggs Export Sensor Data - https://github.com/mycontroller-org/mycontroller/issues/6
                            @mvader Support for DualOptiboot-bootloader - https://github.com/mycontroller-org/mycontroller/issues/25 I do not have hardware, Could you please check this feature on your setup?
                            @bpair Add support for Metric or Imperial - https://github.com/mycontroller-org/mycontroller/issues/26 and Retry Serial Port and Virtual Port support (implemented Retry Serial Port) - https://github.com/mycontroller-org/mycontroller/issues/36
                            @Suresh-Mali Value does not get updated, if the device was actioned by timer - https://github.com/mycontroller-org/mycontroller/issues/35
                              mvader
                              wrote on last edited by mvader
                              for the firmware upload
                              i see this in the logs
                              [ST_FIRMWARE_CONFIG_RESPONSE], [NodeId:3, SensorId:255, PayLoad: 01000200A8066891]
                              but nothing further..
                              i'm not sure how to tell if it's working or not.
                              other than to wait?
                              should i continue to refresh logs and look for payload/packet updates?
                              • M mvader
                                other than to wait?
                                J
                                J
                                jkandasa
                                other than to wait?
                                For now there is no option, you have to wait
                                You can see payload.packet updates when you enable debug log
                                @mvader Enable DEBUG for org.mycontroller.standalone.mysensors package in mycontroller/conf/logback.xml
                                  <logger level="DEBUG" name="org.mycontroller.standalone.mysensors"/>
                                I have to add some mechanism to know more about without enabling debug log.
                                Added a ticket to track firmware status https://github.com/mycontroller-org/mycontroller/issues/37
                                M 1 Reply Last reply
                                  mvader
                                  @jkandasa said:
                                  okay i will check this tonight and let you know.
                                  some kind of realtime packet/payload screen would be a nice feature :)
                                  thanks
                                  • J
                                    J
                                    jkandasa
                                    Document updated for 0.0.2-alpha5 release.
                                    • M mvader
                                      thanks
                                      J
                                      J
                                      jkandasa
                                      As node and controller communicates asynchronous, showing in real time would be bit difficult. I will have this feedback in my mind, will work to implement.
                                      For now we have an option to check it via logs page. https://github.com/mycontroller-org/mycontroller/issues/37 This will be available in 0.0.2-alpha6 release. In the current release (0.0.2-alpha5) this fix will not be.
                                      Thank you!
                                      • J jkandasa
                                        other than to wait?
                                        mvader
                                        @jkandasa said:
                                        I enabled debug in the logs , rebooted the rpi2
                                        this is what i have after telling the firmware to upload
                                        trying to reboot a sensor
                                        and then manually rebooting the device.
                                        it doesn't appear it's sending
                                        Oct 22, 2015 10:43:18 PM Sensor Internal Sent [I_CONFIG], [NodeId:3, SensorId:255, PayLoad: I]
                                        Oct 22, 2015 10:43:18 PM Sensor Internal Received [I_CONFIG], [NodeId:3, SensorId:255, PayLoad: 0]
                                        Oct 22, 2015 10:43:18 PM Sensor Presentation Received [S_ARDUINO_NODE], [NodeId:3, SensorId:255, PayLoad: 1.5]
                                        Oct 22, 2015 10:43:01 PM Sensor Internal Sent [I_REBOOT], [NodeId:3, SensorId:255, PayLoad: ]
                                        Oct 22, 2015 10:42:41 PM Sensor Internal Received [I_VERSION], [NodeId:0, SensorId:0, PayLoad: 1.5]
                                        Oct 22, 2015 10:42:13 PM Sensor Stream Sent [ST_FIRMWARE_CONFIG_RESPONSE], [NodeId:3, SensorId:255, PayLoad: 01000200A8066891]
                                        also on a separate issue
                                        time zone
                                        can this be a configurable option?
                                        it seems to default to
                                        Version: 0.0.2-alpha5, Timezone: UTC(+0000)
                                        i have the TZ set correctly on my rpi2
                                        (i'm EDT timezone)
                                        thanks
                                        • M mvader
                                          time zone
                                          (i'm EDT timezone)
                                          thanks
                                          J
                                          J
                                          jkandasa
                                          @mvader said:
                                          If you enable or disable debug logs in MyController , there is no need to reboot your rpi.
                                          Whatever you change in mycontroller/conf/logback.xml the out logs will be in mycontroller/logs/mycontroller.log
                                          Based on the log seems like, gateway cannot communicate with your node. Only receiving from node. If you have any relay board, or something send ON/OFF from MyController and check it?
                                          time zone
                                          Right now it's taking system timezone as timezone. I hope if we give it as configurable option may leads confusion.
                                          (i'm EDT timezone)
                                          thanks
                                          You have to set timezone with the help of raspi-config https://learn.adafruit.com/adafruits-raspberry-pi-lesson-2-first-time-configuration/changing-timezone
                                          I believe your rpi still with UTC. If you run date command from your raspberry PI what is the output?
