  3. My sensorboard MYS 1.0beta
121 Posts 44 Posters 113.7k Views 13 Watching
    Mrlynx
    Original thread got lost in the forumcrash.
    I have made a sensorboard that is under testing.
    spec:
    socket for arduino pro mini 5v/3,3V
    socket for radio
    3,3v regulator
    4 AD input with voltage dividers
    7 gpio availble with pullups on all pins
    I have som small mods left to do in the voltage dividers.
    Is there any interest in boards or kits (board + components) for just a few dollars?
    http://www.sa2avr.se
    D 1 Reply Last reply
    • L
      L
      larky
      Sure, one or two for testing!
      • Z
        Z
        Zeph
        wrote on last edited by Zeph
        Why external pullups for the pins?
        Is there a ground plane beneath the radio's antenna?
          Mrlynx
          The external pullups are for humidity sensor and 1-wire.
          Yes there is a power plane and a ground plane under the radio.
          • AnticimexA
            AnticimexA
            Anticimex
            The ATmega has internal pull-ups on most IO. Is it not adequate to use those for pulls for I2C and sensors? Are they to weak?
              Mrlynx
              The internal pullups is about 50K but for 1-wire and humidity you need a 4,7K ohm resistor.
              • M Mrlynx
                spec:
                socket for radio
                3,3v regulator
                D
                D
                djdworks
                @Mrlynx i'll be very happy to buy 10 of them
                • P
                  P
                  p0lar
                  Im in for a few. what do I need to provide you with?
                  • jendrushJ
                    jendrushJ
                    jendrush
                    This is sensor board i've made 2 days ago :) temp_node.jpg
                      Mrlynx
                      wrote on last edited by Mrlynx
                      I have updated the layout and added caps to the voltage dividers.
                      I am now going to order components for a batch of 100 boards.
                      what pull-up resistors and voltagedividers do you need?
                      I think that I will supply the kit with some 1K, 4,7k and 10K.
                      The price for a kit will probably be 7$ + shipping. Just add an Arduino pro mini, radio and sensor to make it a node.
                      @djdworks and @p0lar are first in line when they are ready.
                      @jendrush nice work.
                      T jendrushJ 2 Replies Last reply
                      • M Mrlynx
                        tjay4x4
                        @Mrlynx I'm in your boat, wanna get 10 boards.
                        • M Mrlynx
                          jendrushJ
                          jendrushJ
                          jendrush
                          @Mrlynx said:
                          nice work.
                          Thank you. This is only temperature board, but best part of this board is cost.
                          Piece of PCB ~30 cents,
                          pins ~30 cents,
                          power connector ~10 cents,
                          capacitor+resistor ~ 10 cents,
                          3.3V regulator ~ 10 cents
                          :) less than 1$ for complete board, and about 7$ for all parts including radio, arduino mini, wall usb charger, and cables:) This is power of MySensors!
                          Thank you @Hek, and rest of the team!
                          Z 1 Reply Last reply
                            Mrlynx
                            Schematic for the updated MYS 1.1 mys11.pdf
                            • D
                              D
                              djdworks
                              I had a look to PDF schematics and i have a request to include SDA and SCL pins since many sensors uses such pins if possibile. Thanks a lot.
                                Mrlynx
                                Only problem is SDA and SCL are located on separate pins on top of the pro mini module and not in the normal row of pins. (A4-A5)
                                • Z
                                  Z
                                  Zeph
                                  SDA and SCL seem to come in two places on APM's - inside the row of pins, and sometimes at the end opposite the serial programming pins. A host PCB could allow either.
                                    Mrlynx
                                    I have now added SDA/SCL(A4/A5) to MYS 1.1
                                    Is there any more ideas to be added before I send it for production?
                                    mys111.pdf
                                    • P
                                      P
                                      p0lar
                                      cool on the full kit price but can we also get just plain boards? I have a few home-built sensors that I need to upgrade :)
                                      • D
                                        D
                                        djdworks
                                        Well done I'm very happy for SDA and SCL added on the board thanks a lot.
                                        Yesterday night I had a deeper look into the PCB and i was thinking that if you add 3 pins with MISO, MOSI and SCK your board will be good also to build ethernet gateway or connect additional SPI device.
                                          Mrlynx
                                          I have thought about the spi channel but I cant really understand why the ethernet gateway sketch uses different CE/CS pins for the radio.
                                          Why cant the radio use pin 9/10 and the ethernet shield 5/6?
                                          Maybe @hek can shed som light on the matter?
                                          hekH 1 Reply Last reply
