Serial gateway with the API
  • Hi
    I am pretty new to the mysensor project, but I really like it!
    So I have a few questions regarding my setup. So I have an Raspberry Pi running openhab, to this I am trying to connect 4 arduinos, 3 of them through usb and the last one through voltage converter and serial on GPIO. I am currently making 6 sensor nodes IMG_20151111_073443.jpg
    Each nodes has 2 pir sensors, dht22,light sensor, sound sensor, and co2 sensor. Due to the processing load, my idea was to split these sensors over two arduino uno(atmega 328). Is that a good idea? (The problem is that I am trying to detect which of the two pir sensor were triggered first to see if you are going in or out of the room, hence they will get triggered with >50ms interval).
    Then i have the serial on GPIO arduino nano(due to the fact it was easier to solder 12m cable to the gpio pins instead of terminating it to the usb.) which reads 4 buttons and controlls 4 solid state relays for my bar.
    Then finally I have a arduino controlling several led strips, connected through USB.
    So as a start I managed to get the serial gateway to work by just writing serial.print("12,7,1,0,23.6\n") but now I want to expand it to use real sensors and this is when i get stuck.... Do I need to throw away the libraries since these only work with the radio modem, or should i rewrite them to work with the serial connection or how do I proceed? I need to set the baudrate and give them static node ID. Below is my modified code, that does not work..
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 11
    unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.begin(NULL,12);
      gw.sendSketchInfo("Humidity", "1.0");
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME); //sleep a bit
    Thanks for any feedback
  • Admin
    In the dev-branch you can disable radio support for gw-nodes completely.
    So if I understand you correctly in the development version the method gw.send will then be equal to :
    Serial.print(GwId,NodeID,1,0,msgTemp.set(temperature, 1)\n)
    And in the examples I will then just comment out all the serial.print statements or?
  • Admin
    @skatun
    You just do sending the same way on gateway as on the nodes.
  • 4
  • 933
  • 274
  • 14
11.3k
