  3. Are Chinese power supply chargers that dangerous to use ?
22 Posts 9 Posters 21.0k Views 6 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    As you know, power supplies are important in designing a sensor node, and price and safety should be taken in consideration. I checked several topics regarding safe power supplies for AC - DC converters like using HLK-PM01 in this post : http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board , also I checked some of the replies in this huge post : http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
    I'll post some photos of power supply chargers which I bought to use, but I re-watched that video from EEVblog regarding fake Apple charger https://www.youtube.com/watch?v=wi-b9k-0KfE and it really made me think again before using such cheap devices.
    But if those chargers are dangerous, so why do some people encourage using the HLK ? Isn't it Chinese as well ? I can't imagine that it will be much safer than most chargers.
    I also want to know what sort of danger would happen when using those devices ? What sort of safety is missing to avoid harm ?
    I'll post some of the chargers which I bought.
    • sundberg84S
      And also if I may add a question:
      How unsafe are these compared to a say cheap 433mhz plug bought from the store today?
      I guess many of these sheep ones are also manufactures in China.
      AWIA 1 Reply Last reply
      • sundberg84S sundberg84
        AWIA
        AWIA
        AWI
        @sundberg84 Most 433Mhz devices are operating with a very simple "transformerless" power supply which is actually quite simple and relatively safe as long a you don't touch anything ;-)
        example and reading
        upload-68640131-4a3e-456a-b40e-3b64cbdd517c
        ahmedadelhosniA 1 Reply Last reply
        • TD22057T
          TD22057T
          TD22057
          I don't think "from China" means it's bad. But for a power supply, I would be concerned about quality control. I wouldn't be surprised if items that fail a quality check for a big name company get dumped on the open market as parts anyway. Another option to consider is the Samsung cube charger for ~$9, it's tiny, works on 120/240, is well designed (see online tear downs and tests), and is nicely isolated for safety. As long as buy from an actual Samsung version and not a fake, I think it's a really good solution. In the US, I buy them sold by Amazon - not a 3rd party seller on Amazon.
          I think the DIY version is really cool - but it does scare me a little because I'm not trained enough to evaluate it's safety.
          • AWIA AWI
            example and reading
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @AWI Why are "transformless" more safer than using a transformer ?
            I can see also from the article that it can't supply more than 20-40 mA.
            Thanks.
            • TD22057T TD22057
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @TD22057 Yeah of course there are high quality chinese products and they work perfect.
              Actually I am surprised that this 9$ supply is not fake. I guess an actual Samsung will be more expensive.
              The second power adapter in the photos costs around 3.125$ in my country.
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                @petewill I would be pleased if you could share your experience with phone adapters as you have create a sensor node outlet before using a phone charger. Was it fake or original ? Did you face any problem till now or did you change it later ? Any info will be helpful ofcourse.
                Thanks.
                petewillP 1 Reply Last reply
                • ahmedadelhosniA ahmedadelhosni
                  Thanks.
                  AWIA
                  AWIA
                  AWI
                  @ahmedadelhosni Is was meant as an example for what the 433MHZ are using. A important part of the safety comes from the isolation between the high and low voltage side. Isolation is out of the safety equation here (there is none).
                  For many uses (including some MySensors designs) a few mA is more that sufficient. But you need to know what you are playing with before trying :skull:
                  • AWIA AWI
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    @AWI Can isolation be something like charger number 3 ?
                    Till now I don't know what is dangerous when I use one of the above chargers ? Will it cause fire and how ?
                      Thanks.
                      petewillP
                      petewillP
                      petewill
                      I have used many phone chargers in my projects. They are all original chargers that I picked up from the recycle bin at work. I have never had any issues.
                      I started the post for safe in wall transformers to find a good solution because I don't want to use a phone charger in the wall. The HLK was decided as the best solution. It was tested by a third party (you can find the link in the thread) and said to be safe. I personally haven't used on in a project yet (too many projects, not enough time) but I plan to soon.
                      Hopefully that helps.
                      • petewillP petewill
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @petewill Thanks a lot for your reply. This helps of course.
                        I guess also the HLK alone is not enough. The other thread which I posted in the main thread used extra fuses and varistors to secure the circuit.
                        Regarding the third party. You mean this website ? http://lygte-info.dk/
                          petewillP
                          petewillP
                          petewill
                          @ahmedadelhosni Yes, I think it is wise to use the extra components in the circuit.
                          Yep, that's the site.
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            @petewill Thanks a lot. I actually read all the replies in your thread and I now understands safety requirements better than before.
                            Waiting for your great projects :)
                              petewillP
                              petewillP
                              petewill
                              @ahmedadelhosni It is a long thread :)
                              I am torn between all the projects on my list. I thought I would have more time this winter but so far that hasn't been the case. I am still hoping to get to this one soon but a few others have taken priority :(
                              • icebobI
                                icebobI
                                icebob
                                3 weeks ago I ordered some $0.99 USB power supply from Aliexpress: http://www.aliexpress.com/item/Hot-5V-2A-Travel-Convenient-EU-Plug-Wall-USB-Charger-Adapter-For-Samsung-galaxy-S5-S4/32362543740.html
                                Today arrived. I opened and I think it is not bad, isn't it?
                                • icebobI icebob
                                  ahmedadelhosniA
                                  ahmedadelhosniA
                                  ahmedadelhosni
                                  wrote on last edited by ahmedadelhosni
                                  @icebob After I have read almost most of the replies in the thread "safe in wall ... " I would tell you don't ever use this. This is even worse that charger number 1 and 2 which I posted above.
                                  After reading about safe circuits. The idea is that you need to protect all your component from damage and to avoid any overheating + you want a clean steady output.
                                  What i see now that there is no fuse nor varistor components at the AC input. The circuit uses only one diode for rectifying - the one at the upper right - not too bad but I read that a full wave rectifier with four diodes gives cleaner output. Other good circuits have an IC to control the output with feedback and has inbuilt over voltage / over current / over thermal protection. This one uses only transistor with - I guess - the other transistor for feedback. Another bad thing is that there is no isolation at all between high side voltage and low side voltage. The optocoupler in the middle should handle this in a better circuit desing, plus, there is no Y capacitor for isolation. ( See charger number 3, you will find an empty space in the middle and a blue component which is the Y capacitor )
                                  Thus this is a really simple AC to DC charger but with less protection and probably won't provide you with stable voltage. I don't encourage you to use this. You can check the two threads in my origianl post. They use HLK which is a great circuit design as a step down converter.
                                  • icebobI
                                    icebobI
                                    icebob
                                    @ahmedadelhosni thank you for you explanation. I won't use it.
                                    • icebobI icebob
                                      ahmedadelhosniA
                                      ahmedadelhosniA
                                      ahmedadelhosni
                                      @icebob you are welcome. I am not an expert but that is a breif of what I have understood after reading the thread safe in wall...
                                      • epierreE
                                        epierreE
                                        epierre
                                        one led driver nearly exploded through my head once ... some vendors are now showing this:
                                        http://www.aliexpress.com/item/100-genuine-Original-2A-EU-Plug-Wall-Charger-USB-Power-Adapter-Travel-For-Samsung-S4-I9500/2048345033.html
                                        z-wave - Vera -> Domoticz
                                        m26872M 1 Reply Last reply
                                        • epierreE epierre
                                          m26872M
                                          m26872M
                                          m26872
                                          @epierre Hehe. The "fake" one looks really good compared to the one @icebob showed us. IC, fuse and big trafo.
                                          Interesting design choice to squeeze the electrolytic cap between mains input btw. 😰
