debugging a network of MySensors nodes based on dev branch 1.6
  • Hi guys,
    is anybody know controller to debug development branch of mysensors lib 1.6?
    i'm recently tried to create gateway with builtin sensors based on dev branch but don't know how to debug it (aka build sensors tree like in MYSController) ? or just any controller that can support dev branch ( better Vera, MyController.org, Domoticz)
  • or who can advise how i can build gateway with locally attached sensors ? and test it ?
  • Just from someone who's working pretty heavily in IoT...
    I'd not recommend hooking up sensors to the gateway. Run the gateway as just a gateway. It will make things simpler in the long run.
    Also, Arduino Nano clones are $1.80 from Aliexpress, and the short range nRF chips are $.63/each and the 1km range one is $3.
  • Admin
    @timota
    There hasn't been any breaking changes in 1.6 from the controller side (except for MQTT and additional sensor-types which might not be supported).
    If you look at the gateway examples in 1.6 they have a empty loop/presentation/setup block. Just fill it in with something from the other sensor examples.
    True, but I'd say it's ok if you don't have a sub-radio net to handle traffic for. For instance using a standalone ESP8266 as a sensor.
  • My idea is to create GW based on ESP8266 and add additional sensors based on RF433 (i have a couple old power switches) - so from my point of view no need additional arduino. But when i added those sensors to presentation functions - MYSController does not show them at all - only GW and internal inside it. What i'm doing wrong? or controller does not support GW builtin sensors ?
    My code is:
    void presentation() {
    	Serial.print("Send Sketch Info: ");
    	Serial.print(SKETCH_NAME);
    	Serial.println(SKETCH_VERSION);
    	Serial.println("S_LIGHT");
    	present(ID_S_LIGHT,S_LIGHT);
    so could you pls advise
  • @timota Can you post your entire sketch?
  • it simple as it can be, just for test
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #define MY_DEBUG_VERBOSE
    #define MY_NODE_ID 10
    #define MY_BAUD_RATE 9600
    // Gateway mode always enabled for ESP8266. But we add this anyway ;)
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "SSID"
    #define MY_ESP8266_PASSWORD "PASSWORD"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    #define SKETCH_NAME "ESP8266WiFi"
    #define SKETCH_VERSION "0.1"
    boolean metric = true;
    #define ID_S_LIGHT 2
    MyMessage msg_S_LIGHT(ID_S_LIGHT,V_LIGHT);
    bool isLightOn=0;
    	// Get controller configuration
    	Serial.print("Get Config: ");
    	metric = getConfig().isMetric;
    	Serial.println(metric ? "Metric":"Imperial");
    	present(ID_S_LIGHT,S_LIGHT,"Hall Light");
      // Send locally attech sensors data here
    What i missed
  • @timota Try removing the nRf define:
    I do not have any experience with MyS 1.6 so I am not sure what else could be preventing the child sensor from being 'presented' to the controller.
  • No luck. Even with full debug i dont see any lines related to presentation (aka send data or something, only Serial.print)
    Below log from serial console and screenshot from MYSController
     ‚n?–4“Ò¶£ÿOAaû0;255;3;0;9;Starting gateway (R-NGE-, 1.6.0-beta)
    scandone
    state: 0 -> 2 (b0)
    .state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 9
    pm open phy_2,type:2 0 0
    cnt
    connected with SKYBC0D8, channel 6
    ip:192.168.0.51,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.51
    Send Sketch Info: ESP8266WiFi0.1
    Get Config: Imperial
    S_LIGHT
    0;255;3;0;9;Init complete, id=0, parent=0, distance=0
    i guess we need @hek advise here. @hek could you pls help with GW on ESP and internal sensors
  • 6
  • 4
  • 48
  • 17
  • 482
