@yury said in Wall Socket Insertable Node:
Looks cool! Do you have experience with capacities switches? I did not play much with them. afraid to use close to AC interference though...
You need to use a capacitive IC with active shielding, basically you have an extra electrode around your touch electrode and the touch IC will compare capacitive change of the touch electrode with capacitive change from the shield electrode. If the change is due to electrical interference then both electrodes will be changed in a similar way and the IC will not trigger.
@kristof-delaere
The terms that you refer to are footprint/package specifications (size, shape).
Here are links to the above components on digikey:
CMOS SMD (oscillator)
http://www.digikey.com/product-detail/en/epson/SG7050CAN-27.000000M-TJGA3/SER3999CT-ND/5175091
0207W (120 ohm resistor)
http://www.digikey.com/product-detail/en/tt-electronics-welwyn/WRM0207C-120RFI/985-1466-1-ND/3648019
0207W (2.7k ohm resistor)
http://www.digikey.com/product-detail/en/yageo/MCP100JR-2K7/MCP100JR-2K7-ND/2169183
