  3. MyWeatherGatewayESP8266 (1.6 dev branch)
1 Posts 1 Posters 3.8k Views 2 Watching
  • E
    E
    emc2
    wrote on last edited by emc2
    Hi there.
    A couple of weeks ago I started to play with the 1.6 branch to hook up a sensor directly on the gateway, and decrease the clutter of cables and breadboards lying around.
    Here is the result, a ESP8266 gateway with weather station sketch allowing me to measure the atmospheric pressure, temperature and humidity (indoor). Because of the limited number of pins available I used a BME280 sensor instead of a BMP180 + dht. It may be a couple of dollar more expensive, but it's nicer to wire!
    A few drawbacks / limitations:
    • the CE pin is by default wired on the I2C bus. You will either need to move it, or to move the I2C bus pins. It can be easily done by commenting / uncommenting a few lines on top of the sketch.
    • BME280 is extremely sensitive. It's good right? Well not if you keep it too close of the ESP8266. Temperature will be up to 3°C higher than it really is! I still have to figure out how to resolve this issue. For now I'm back with having long wires between the BME module and the ESP :/
    • I moved the I2C bus to GPIO 1 and 3. These are the TX and RX pins, close to the USB port. I2C and Serial communication are sort of interfering with each other if occurring in the same time. MY_DEBUG is off to prevent this. You may want to move SDA and SCL around, especially for debug purpose, but here it's close to a GND and 3.3V supply which is convenient. Maybe there is a way to do a nice PCB but I never tried before.
    Code updates, if any, will be available on https://github.com/emc2cube/MyWeatherGatewayESP8266
     * Important: I2C setup and NRF24L01 wiring
     * By default the NRF24 CE pin is wired on GPIO4. On ESP8266 default SDA and SCL pin are respectively GPIO4 and GPIO5.
     * Both CE pin and SDA (or even SCL) can be moved so depending of your setup you will have to move at least one of these.
     * Look for "#define MY_RF24_CE_PIN", "#define SDA" and "#define SCL" lines to adapt to your wiring.
     * By default Adafruit BME280 library is looking for a BME280 sensor on the I2C bus at (0x77).
     * If your sensor is set with the low adress (0x76) you can uncomment the lines "#undef BME280_ADDRESS" and "#define BME280_ADDRESS (0x76)"
     * Or you can set it on high by changing the jumper/bridge setting on the PCB.
    // MySensor ESP8266 Gateway configuration
    #include <EEPROM.h>
    //#define MY_DEBUG    // I2C devices may have a funky behaviour when serial communication is occuring and GPIO 1 and 3 are used for I2C bus (RX and TX ports).
    #define MY_BAUD_RATE 9600
    // Gateway mode always enabled for ESP8266. But we add this anyway ;)
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "MySSID"
    #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
    // To use native I2C pins CE should be moved. Declare the new GPIO used here.
    // GPIO 3 is pin D9 (RX below D8)
    //#define MY_RF24_CE_PIN 3
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    // Child sensor ids
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define HUM_CHILD 2
    // I2C setup: SDA and SCL pin selection
    #include <Wire.h>
    // If using the standard MySensor wiring direction we can't use default I2C ports. I2C ports moved next to the second GND and 3.3v ports for convenient wiring of I2c modules.
    #define SDA 3  //default to GPIO 4 (D2) but NRF24L01+ CE is plugged on D2 by default for the ESP gateway. SDA changed to GPIO 3 (RX)
    #define SCL 1  //default to GPIO 5 (D1). SDA changed to GPIO 1 (TX)
    // BME280 libraries and variables
    // Written by Limor Fried & Kevin Townsend for Adafruit Industries.
    // https://github.com/adafruit/Adafruit_BME280_Library
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BME280.h>
    //#undef BME280_ADDRESS         // Undef BME280_ADDRESS from the BME280 library to easily override I2C address
    //#define BME280_ADDRESS (0x76) // Low = 0x76 , High = 0x77 (default on adafruit and sparkfun BME280 modules, default for library)
    Adafruit_BME280 bme; // Use I2C
    // Weather station variables and functions
    // Adapt this constant: set it to the altitude above sealevel at your home location.
    const float ALTITUDE = 23; // meters above sea level. Use your smartphone GPS to get an accurate value!
    // Set this to true if you want to send values altough the values did not change.
    // This is only recommended when not running on batteries.
    const bool SEND_ALWAYS = true;
    // You should not need to edit anything after this line //
    // Constant for the world wide average pressure
    const float SEALEVEL_PRESSURE = 1013.25;
    // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    unsigned long previousMillis = 0;
    const char *weatherStrings[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,       // Stable weather
      SUNNY = 1,        // Slowly rising HP stable good weather
      CLOUDY = 2,       // Slowly falling Low Pressure System, stable rainy weather
      UNSTABLE = 3,     // Quickly rising HP, not stable weather
      THUNDERSTORM = 4, // Quickly falling LP, Thunderstorm, not stable
      UNKNOWN = 5       // Unknown, more time needed
    const char *situationStrings[] = { "very low", "low", "normal", "high", "very high" };
    enum WEATHER_SITUATION
      VERY_LOW_PRESSURE = 0,   // p > -7.5hPa
      LOW_PRESSURE = 1,        // p > -2.5hPa
      NORMAL_PRESSURE = 2,     // p < +/-2.5hPa
      HIGH_PRESSURE = 3,       // p > +2.5hPa
      VERY_HIGH_PRESSURE = 4,  // p > +7.5hPa
    float lastPressure = -1;
    float lastTemp = -1;
    float lastHum = -1;
    int lastForecast = -1;
    int lastSituation = NORMAL_PRESSURE;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
    // get kPa/h by dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage tempMsg(TEMP_CHILD, V_TEMP);
    MyMessage humMsg(HUM_CHILD, V_HUM);
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    MyMessage situationMsg(BARO_CHILD, V_VAR1);
    MyMessage forecastMsg2(BARO_CHILD, V_VAR2);
    void initPressureSensor() {
      Serial.print(F("NRF24L01+ CE pin on GPIO"));
      Serial.println(MY_RF24_CE_PIN);
      #if defined(SDA) && defined(SCL)
        Serial.print(F("Using custom I2C pins: SDA on GPIO"));
        Serial.print(SDA);
        Serial.print(F(" and SCL on GPIO"));
        Serial.println(SCL);
        Wire.begin(SDA,SCL);
      #else
        Serial.println(F("Using default I2C pins: SDA on GPIO4 and SCL on GPIO5"));
        Wire.begin();
      if (!bme.begin(BME280_ADDRESS)) {
        Serial.println(F("Could not find a valid BME280 sensor, check wiring or I2C address!"));
        while (1) {
          yield();
    int getWeatherSituation(float pressure)
      int situation = NORMAL_PRESSURE;
      float delta = pressure - SEALEVEL_PRESSURE;
      if (delta > 7.5)
        situation = VERY_HIGH_PRESSURE;
      else if (delta > 2.5)
        situation = HIGH_PRESSURE;
      else if (delta < -7.5)
        situation = VERY_LOW_PRESSURE;
      else if (delta < -2.5)
        situation = LOW_PRESSURE;
      else
      return situation;
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      // Uncomment when debugging
      Serial.print(F("### 5min-Average:"));
      Serial.print(lastPressureSamplesAverage);
      Serial.println(F(" hPa"));
      return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
        if (firstRound) // first time initial 3 hour
          dP_dt = change * 2; // note this is for t = 0.5hour
        else
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
        if (firstRound) //first time initial 3 hour
          dP_dt = change; //note this is for t = 1 hour
        else
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
        else
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
        else
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
        else
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
        else
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
      int forecast = UNKNOWN;
      if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
      else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
        forecast = CLOUDY;
      else if ((dP_dt > 0.05) && (dP_dt < 0.25))
        forecast = SUNNY;
      else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
      else
        forecast = UNKNOWN;
      // Uncomment when dubugging
      Serial.print(F("Forecast at minute "));
      Serial.print(minuteCount);
      Serial.print(F(" dP/dt = "));
      Serial.print(dP_dt);
      Serial.print(F("kPa/h --> "));
      Serial.println(weatherStrings[forecast]);
      return forecast;
    bool updatePressureSensor()
      bool changed = false;
      float temperature = bme.readTemperature();
      float humidity = bme.readHumidity();
      float pressure_local = bme.readPressure() / 100.0; // Read atmospheric pressure at local altitude
      float pressure = ( pressure_local / pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255)); // Local pressure adjusted to sea level pressure using user altitude
      if (!metric)
        // Convert to fahrenheit
        temperature = temperature * 9.0 / 5.0 + 32.0;
      int forecast = sample(pressure);
      int situation = getWeatherSituation(pressure);
      if (SEND_ALWAYS || (temperature != lastTemp))
        changed = true;
        lastTemp = temperature;
        Serial.print(F("Temperature = "));
        Serial.print(temperature);
        Serial.println(metric ? F(" *C") : F(" *F"));
        if (!send(tempMsg.set(lastTemp, 1)))
          lastTemp = -1.0;
      if (SEND_ALWAYS || (humidity != lastHum))
        lastHum = humidity;
        changed = true;
        Serial.print(F("Humidity = "));
        Serial.print(humidity);
        Serial.println(F(" %"));
        if (!send(humMsg.set(lastHum, 1)))
          lastHum = -1.0;
      if (SEND_ALWAYS || (pressure != lastPressure))
        changed = true;
        lastPressure = pressure;
        Serial.print(F("Sea level Pressure = "));
        Serial.print(pressure);
        if (!send(pressureMsg.set(lastPressure, 1)))
          lastPressure = -1.0;
      if (SEND_ALWAYS || (forecast != lastForecast))
        changed = true;
        lastForecast = forecast;
        Serial.print(F("Forecast = "));
        if (send(forecastMsg.set(weatherStrings[lastForecast])))
          if (!send(forecastMsg2.set(lastForecast)))
        else
          lastForecast = -1.0;
      if (SEND_ALWAYS || (situation != lastSituation))
        changed = true;
        lastSituation = situation;
        Serial.print(F("Situation = "));
        Serial.println(situationStrings[situation]);
        if (!send(situationMsg.set(lastSituation)))
          lastSituation = -1.0;
      return changed;
      initPressureSensor();
      metric = getConfig().isMetric;
    void presentation() {
      sendSketchInfo("Weather Station Gateway", "1.6");
      // Register sensors to gw (they will be created as child devices)
      present(BARO_CHILD, S_BARO);
      present(TEMP_CHILD, S_TEMP);
      present(HUM_CHILD, S_HUM);
      updatePressureSensor();
      wait(SLEEP_TIME);   // do not use sleep() or delay(), it would prevent required TCP/IP and MySensor operations!
