Sensebender Micro + button
  • Hello all !
    I like the way that this sketch: https://www.mysensors.org/hardware/micro work with Jeedom.
    And I need a bell button that doesn't need a batterie per month.
    So i've tried to mix with this sketch: https://www.mysensors.org/build/binary
    But it's a fail. It only show the data once.
    The button is in D3. I may use D4 latter (as a secret button maybe). By using D3, we can use the ftdi port to power the circuit, and to cable the button. But then, i want to see how many time a button-cell can be used.
    so:
    0_1453483204520_IMG_20160122_162415-2.jpg 0_1453483211180_IMG_20160122_163324-2.jpg
    How to use the interrupt fonction to wake up when pressing the button, and have a 10 minutes wake-up if no press ?
    (And yeah, i could take off all the serial part)
    Thanks for helping !
    ps: can't we write down the code ? It may be a bug from the forum but i can't go down...
     * Version 1.0 - Henrik Ekblad
     * Default sensor sketch for Sensebender Micro module
     * Act as a temperature / humidity sensor by default.
     * If A0 is held low while powering on, it will enter testmode, which verifies all on-board peripherals
     * Battery voltage is as battery percentage (Internal message), and optionally as a sensor value (See defines below)
    #include <Wire.h>
    #include <SI7021.h>
    #include "utility/SPIFlash.h"
    #include <EEPROM.h>
    #include <sha204_lib_return_codes.h>
    #include <sha204_library.h>
    #include <RunningAverage.h>
    #include <avr/power.h>
    #include <Bounce2.h>
    // Define a static node address, remove if you want auto address assignment
    //#define NODE_ADDRESS   3
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    //#define BATT_SENSOR    199
    #define RELEASE "1.2"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    // How many milli seconds between each measurement
    #define MEASURE_INTERVAL 600000
    // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
    #define FORCE_TRANSMIT_INTERVAL 30
    // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
    // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
    // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
    // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
    #define HUMI_TRANSMIT_THRESHOLD 1
    #define TEMP_TRANSMIT_THRESHOLD 1
    // Pin definitions
    #define TEST_PIN       A0
    #define LED_PIN        A2
    #define ATSHA204_PIN   17 // A3
    #define CHILD_ID_BP 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    //#define CHILD_ID 4
    //#define BUTTON_PIN  4  // Arduino Digital I/O pin for button/reed switch
    const int sha204Pin = ATSHA204_PIN;
    atsha204Class sha204(sha204Pin);
    SI7021 humiditySensor;
    SPIFlash flash(8, 0x1F65);
    // Sensor messages
    MyMessage msgBP(CHILD_ID_BP,V_TRIPPED);
    Bounce debouncer = Bounce();
    int oldValue=-1;
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    // Storage of old measurements
    float lastTemperature = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
    RunningAverage raHum(AVERAGES);
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      Serial.begin(115200);
      Serial.print(F("Sensebender Micro FW "));
      Serial.print(RELEASE);
      Serial.flush();
      // First check if we should boot into test mode
      pinMode(TEST_PIN,INPUT);
      digitalWrite(TEST_PIN, HIGH); // Enable pullup
      if (!digitalRead(TEST_PIN)) testMode();
      // Make sure that ATSHA204 is not floating
      pinMode(ATSHA204_PIN, INPUT);
      digitalWrite(ATSHA204_PIN, HIGH);
      digitalWrite(TEST_PIN,LOW);
      digitalWrite(LED_PIN, HIGH);
    #ifdef NODE_ADDRESS
      gw.begin(NULL, NODE_ADDRESS, false);
    #else
      gw.begin(NULL,AUTO,false);
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      humiditySensor.begin();
      Serial.flush();
      Serial.println(F(" - Online!"));
      gw.sendSketchInfo("Sensebender Micro", RELEASE);
      gw.present(CHILD_ID_TEMP,S_TEMP);
      gw.present(CHILD_ID_HUM,S_HUM);
      gw.present(CHILD_ID_BP, S_DOOR);
    #ifdef BATT_SENSOR
      gw.present(BATT_SENSOR, S_POWER);
      isMetric = gw.getConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
     *  Main loop function
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
      if ((measureCount == 5) && highfreq)
        clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
        highfreq = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
      gw.process();
      if (sendBattery > 60)
         sendBattLevel(forceTransmit); // Not needed to send battery info that often
         sendBattery = 0;
    // début du rajout
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msgBP.set(value==HIGH ? 1 : 0));
         oldValue = value;
    // fin du rajout
      gw.sleep(MEASURE_INTERVAL);
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
     * - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      si7021_env data = humiditySensor.getHumidityAndTemperature();
      float oldAvgHum = raHum.getAverage();
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100);
      float diffHum = abs(oldAvgHum - raHum.getAverage());
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        int humidity = data.humidityPercent;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        gw.send(msgTemp.set(temperature,1));
        gw.send(msgHum.set(humidity));
        lastTemperature = temperature;
        lastHumidity = humidity;
     * Sends battery information (battery percentage)
     * Parameters
    void sendBattLevel(bool force)
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        gw.send(msgBatt.set(vcc));
        // Calculate percentage
        vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
        long percent = vcc / 14.0;
        gw.sendBatteryLevel(percent);
     * Internal battery ADC measuring
    long readVcc() {
      #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
        ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
      #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
        ADMUX = _BV(MUX5) | _BV(MUX0);
      #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
        ADcdMUX = _BV(MUX3) | _BV(MUX2);
      #else
      long result = (high<<8) | low;
     * Verify all peripherals, and signal via the LED if any problems.
    void testMode()
      uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
      uint8_t ret_code;
      byte tests = 0;
      digitalWrite(LED_PIN, HIGH); // Turn on LED.
      Serial.println(F(" - TestMode"));
      Serial.println(F("Testing peripherals!"));
      Serial.flush();
      Serial.print(F("-> SI7021 : "));
      Serial.flush();
      if (humiditySensor.begin())
        Serial.println(F("ok!"));
        tests ++;
      else
        Serial.println(F("failed!"));
      Serial.flush();
      Serial.print(F("-> Flash : "));
      Serial.flush();
      if (flash.initialize())
        tests ++;
      else
      Serial.flush();
      Serial.print(F("-> SHA204 : "));
      ret_code = sha204.sha204c_wakeup(rx_buffer);
      Serial.flush();
      if (ret_code != SHA204_SUCCESS)
        Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
      Serial.flush();
      if (ret_code == SHA204_SUCCESS)
        ret_code = sha204.getSerialNumber(rx_buffer);
          Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
        else
          Serial.print(F("Ok (serial : "));
          for (int i=0; i<9; i++)
            if (rx_buffer[i] < 0x10)
              Serial.print('0'); // Because Serial.print does not 0-pad HEX
            Serial.print(rx_buffer[i], HEX);
          Serial.println(")");
          tests ++;
      Serial.flush();
      Serial.println(F("Test finished"));
      if (tests == 3)
        Serial.println(F("Selftest ok!"));
        while (1) // Blink OK pattern!
          delay(200);
          delay(200);
      else
        Serial.println(F("----> Selftest failed!"));
        while (1) // Blink FAILED pattern! Rappidly blinking..
  • Plugin Developer
    Hi!
    Regarding the scrolling not working while in edit, yeah, I experiencing that also. I'm on Chrome 47, Ubuntu. I always have to edit in full screen.
    This is my sketch for a sensebender connected to my door bell:
    2016-02-29: Updated sketch to fix bug in siVolt calculation and set max vcc to 3.2 V.
     * Version 1.0 - Thomas Bowman Mørch
     * Version 1.3 - Thomas Bowman Mørch
     * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
     * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
     * MODIFIED by Martin Hjelmare
     * Sensebender Micro default sketch with addition of binary switch and interrupt,
     * taken from Patrick 'Anticimex' Fallberg's sketch BinarySwitchSleepSensor.
     * Also fixed the bug with the diff calculation for the temperature, and changed
     * vcc 100% rating to 3V, instead of 3.3V.
    #include <Wire.h>
    #include <SI7021.h>
    #include <EEPROM.h>
    //#include <avr/power.h>
    #define NODE_ADDRESS   1
    #define RELEASE "1.3"
    #define AVERAGES 2
    // How many milli seconds should we wait for OTA?
    #define OTA_WAIT_PERIOD 300
    #define HUMI_TRANSMIT_THRESHOLD 0.5
    #define TEMP_TRANSMIT_THRESHOLD 1.0
    // Pin definitions
    #define TEST_PIN       A0
    #define OTA_ENABLE     A1
    #define LED_PIN        A2
    // Sensor messages
    #ifdef BATT_SENSOR
    #define CHILD_ID_BUTTON 3
    #if (BUTTON_PIN < 2 || BUTTON_PIN > 3)
    #error BUTTON_PIN must be either 2 or 3 for interrupts to work
    MyMessage msg(CHILD_ID_BUTTON, V_TRIPPED);
    // Global settings
    boolean ota_enabled = false;
    boolean transmission_occured = false;
    int oldValue = -1;
     * Setup code
      Serial.flush();
      pinMode(TEST_PIN,INPUT_PULLUP);
      //digitalWrite(TEST_PIN, HIGH); // Enable pullup
      pinMode(OTA_ENABLE, INPUT);
      digitalWrite(OTA_ENABLE, HIGH);
      if (!digitalRead(OTA_ENABLE)) {
        ota_enabled = true;
      digitalWrite(OTA_ENABLE, LOW); // remove pullup, save some power.
      // Setup the button
      pinMode(BUTTON_PIN, INPUT_PULLUP);
    #ifdef NODE_ADDRESS
    #else
      Serial.flush();
      gw.sendSketchInfo("Sensebender Micro Bell", RELEASE);
    #ifdef BATT_SENSOR
      gw.present(BATT_SENSOR, S_MULTIMETER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      gw.present(CHILD_ID_BUTTON, S_DOOR);
      raHum.clear();
      if (ota_enabled) Serial.println("OTA FW update enabled");
      measureCount ++;
      sendBattery ++;
        if (!ota_enabled) clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
        highfreq = false;
        measureCount = 0;
      gw.process();
         sendBattery = 0;
      if (ota_enabled & transmission_occured) {
          gw.wait(OTA_WAIT_PERIOD);
      gw.sleep(5);
      int buttonValue = digitalRead(BUTTON_PIN);
      if (buttonValue != oldValue) {
         // Send in the new buttonValue
         gw.send(msg.set(buttonValue==HIGH ? 0 : 1));
         oldValue = buttonValue;
      // Sleep until something happens with the sensor
      gw.sleep(BUTTON_PIN-2, CHANGE, MEASURE_INTERVAL);
     * Parameters
      bool tx = force;
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      float diffHum = abs(lastHumidity - raHum.getAverage());
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        transmission_occured = true;
     * Parameters
        lastBattery = vcc;
      float siVolt = vcc / 1000.0;
    #ifdef BATT_SENSOR
        gw.send(msgBatt.set(siVolt, 2));
        vcc = min(vcc, 3200L); // vcc max is 3200
        long percent = vcc / 13.0;
    long readVcc() {
      #else
    void testMode()
      uint8_t ret_code;
      byte tests = 0;
      Serial.flush();
      Serial.flush();
        tests ++;
      else
      Serial.flush();
      Serial.flush();
        tests ++;
      else
      Serial.flush();
      Serial.flush();
      Serial.flush();
        else
          tests ++;
      Serial.flush();
      if (tests == 3)
          delay(200);
          delay(200);
      else
  • Thanks a lot !
    There is many improvements between the very first sketch !
    And with OTA... Thanks !
  • @martinhjelmare there is a bug (for code bender and arduinoUI). It doesn't like siVolt. '"siVolt' was not declared in this scope"
    your code:
     * Parameters
        lastBattery = vcc;
      siVolt = vcc / 1000;
    #ifdef BATT_SENSOR
        gw.send(msgBatt.set(siVolt));
        vcc = min(vcc, 3000L); // vcc max is 3000
        long percent = vcc / 11.0;
    old code
     * Parameters
        lastBattery = vcc;
    #ifdef BATT_SENSOR
    How did you compil ?
  • Admin
    @Pierre-P
    You just need to declare siVolt as a float type
    float siVolt = vcc/100;
    #ifdef....
  • @tbowmo "call of overloaded 'set(float&)' is ambiguous"
    I don't know what it mean.
    And i don't know why the very first sketch is working for you and not for me ! 😅
     * Parameters
        lastBattery = vcc;
        float siVolt = vcc / 1000;
    #ifdef BATT_SENSOR
    /*******************************************f```
  • Plugin Developer
    @Pierre-P
    Sorry that was my addition and I haven't actually tested the siVolt thing yet. Everything else works though. But I don't see why it shouldn't work if you declare it properly first.
  • BATT_SENSOR si declared.
    ... I think msgBatt is not.
    Does it should be here ?
    // Sensor messages
    Wait not it's just under:
    #ifdef BATT_SENSOR
  • Plugin Developer
    @Pierre-P
    It's declared three lines below, inside the ifdefine.
    Try declaring siVolt outside the if block in the battery function.
    Edit: Scrap the last suggestion.
  • If I undefine: //#define BATT_SENSOR 199
    it's working.
    But your code still not 100% so we have to find why.
    But... but, i think i'm making a mistake: yes i plan to use 3volts power. But, i don't want it as a sensor ! I wan't it as a battery level like the very first SensebenderMicro sketch. So... I have to undefine BATT_SENSOR ? And i will not have it set to 3Vcc=100% ?
  • Plugin Developer
    @Pierre-P
    Might you need to specify decimals if sending float as message. If you want to try, add a second argument with an integer number for decimals.
    https://github.com/mysensors/Arduino/blob/1.5.3/libraries/MySensors/MyMessage.cpp#L212
  • Sorry i'm lost. I'm not as good for now.
    (you may already see that)
  • Plugin Developer
    @Pierre-P
        lastBattery = vcc;
    #ifdef BATT_SENSOR
  • oh...😶
    Just need to say use "2" decimals in the message and it's ok...
    The compilation work !
    I'll try this afternoon the difference between #define BATT_SENSOR 199 and //#define BATT_SENSOR 199
    Thanks for your help !
    Voltage is not good (it's a new 3Vcc button cell) and batterie pourcentage is at 76%
    The battery voltage is not just minus 0.3V...
  • Admin
    @Pierre-P
    The measurement method is not accurate at all. It relies on an internal reference that can vary in value between boards (I can't remember the accuracy of it at the moment)
    If you don't want the battery voltage, then uncomment the #define for BATT_SENSOR in the top of the sketch, and move the float siVolt = vcc/1000; to be within the #ifdef BATT_SENSOR like:
    #ifdef BATT_SENSOR
    Now it should compile, and send battery percentage as the standard sensebender sketch.
  • I personaly think that it's quite good. When powered by FTDI, it found 3.00V.
    And I have only add the "//" to BATT_SENSOR and it work good.
    (you inverted the thing in the message just above).
    Thanks again for you help.
    Now i work very good and very fast. I just have to check for adding an antenna to the controller.
  • Admin
    @Pierre-P
    The FTDI probably supplies the board with 3.3V and not 3V..
  • @Pierre-P How do you find the battery life please? I am planning to fit Sensebender with nrf24l01+ SMD and CR2032, but I wonder how long the battery is going to survive? Appreciate if depends on your sketch, but given one is conservative (i.e. no need to send temp/hum every 30-60 sec, but probably every 5-10mins or so), what's your estimate please?
  • I can't tell you for the moment, I haven't check the real voltage of the CR2032 at the beginning. I'll try to make two mesure between 30 days.
    But my sketch is 1800000ms or 30min sleeping (if no-one press the button). Because it's a redundant information, my Jeedom controler have a meteo plugin who's working good. (i'll use it for the mini-night-temperature to have a message if there is glass on my car's windows).
  • @Pierre-P you controller image looks great . What controller is it ?
  • @iotcrazy It is Jeedom, you can find some information here: http://www.mysensors.org/controller/jeedom
    It use an RPI2 if you ant to make it yourself, and a major version will come during the week !
  • @martinhjelmare Any idea why siVolt is reporting values rounding up to either 2V or 3V in Domoticz? All I'd like to have is something like 2.9V
  • Plugin Developer
    @alexsh1
    How are you calculating and sending it? Did you change to float? There was a bug in my original sketch.
    Make sure at least one of the operands is a float in the division.
  • @martinhjelmare
    Yes, it is declared as float
        lastBattery = vcc;
    #ifdef BATT_SENSOR
    It is reported as either 2.000V (battery) or 3.000V (USB) in Domoticz
    Changing siVolt to int or changing 2 in set does not change anything.
  • Plugin Developer
    You should change 1000 to 1000.0, i.e. a float. Float math will be used if any of the operands is a float.
    https://www.arduino.cc/en/Reference/Arithmetic
  • @martinhjelmare Stupid me! Thanks for bringing this up - these issues are so simple, but very easy to overlook. I was about to start pulling my hair out....
11.3k
