Sensor flooding gateway
  • Hi,
    I just can't see what's wrong with this sensor. It should only be sending from S0 once every minute but it floods the gateway with messages as fast as it can.
    I'm using 1.6.5 for this sensor.
    Here's my code:
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to create a node thay repeates messages
     * from nodes far from gateway back to gateway.
     * It is important that nodes that has enabled repeater mode calls
     * gw.process() frequently. Repeaters should never sleep.
    #include <FastSPI_LED.h>
    #include <DigitalIO.h>
    #include <MyTransportNRF24.h>
    #include <EEPROM.h>
    // Radio Variables
    #define RADIO_CE_PIN        5  // radio chip enable
    #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
    // LED Variables
    #define CHILD_ID 1
    #define NUM_LEDS 150
    // Motion sensor Variables
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID_MOTION 2   // Id of the sensor child
    // Light sensor Variables
    #define CHILD_ID_LIGHT 0
    #define LIGHT_SENSOR_ANALOG_PIN 3
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    // Sometimes chipsets wire in a backwards sort of way
    struct CRGB { unsigned char b; unsigned char r; unsigned char g; };
    // struct CRGB { unsigned char r; unsigned char g; unsigned char b; };
    struct CRGB *leds;
    MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW);
    MyHwATMega328 hw;
    MySensor gw(transport, hw /*, signer*/);
    MyMessage msg(CHILD_ID,V_DIMMER);
    MyMessage motionMsg(CHILD_ID_MOTION, V_TRIPPED); // Motion sensor message
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); // Light sensor message
    int lastLightLevel;
    int lastMillis;
    boolean lastTripped;
    long RGB_v[3] = {0,0,0};
        // Setup FastSPI
        FastSPI_LED.setLeds(NUM_LEDS);
        FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
        FastSPI_LED.init();
        FastSPI_LED.start();
        leds = (struct CRGB*)FastSPI_LED.getRGBData();
      // The third argument enables repeater mode.
      gw.begin(incomingMessage, 8, false);
      //Send the sensor node sketch version information to the gateway
      gw.sendSketchInfo("RGB", "1");
      // Motion sensor
      gw.present(CHILD_ID, S_DIMMER);
      gw.present(CHILD_ID_MOTION, S_MOTION);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      prog3(120);
      // Motion sensor stuff
        // Read digital motion value
      if (tripped != lastTripped) {
    //    Serial.println(tripped);
        gw.send(motionMsg.set(tripped?"1":"0"));  // Send tripped value to gw
        lastTripped = tripped;
      // Light sensor stuff
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      if((lastMillis+SLEEP_TIME) < millis()) {
    //    Serial.println(lightLevel);
          gw.send(lightMsg.set(lightLevel));
          //lastLightLevel = lightLevel;
          lastMillis = millis();
      // By calling process() you route messages in the background
      gw.process();
      //gw.wait(SLEEP_TIME);
      if (message.type == V_DIMMER) {
        //Serial.println( "V_DIMMER command received..." );
        //Serial.println( message.data );
        int prog= atoi( message.data );
        switch(prog) {
          case 1: prog1(); break;
          //case 2: prog2(); break;
          case 3: prog3(120); break;
          case 4: prog4(); break;
      else if (message.type == V_RGB) {
    //    Serial.println( "V_RGB cmd received... " );
        int addr_r = 10;
        int addr_g = 11;
        int addr_b = 12;
        String hexstring = message.getString();
        // Get rid of '#' and convert it to integer
        long number = (long) strtol( &hexstring[0], NULL, 16);
        // Split them up into r, g, b values
        RGB_v[0] = number >> 16;
        RGB_v[1] = number >> 8 & 0xFF;
        RGB_v[2] = number & 0xFF;
        EEPROM.update(addr_r, RGB_v[0]);
        EEPROM.update(addr_g, RGB_v[1]);
        EEPROM.update(addr_b, RGB_v[2]);
        prog3(120);
      else {
        //Serial.println( "OTHER cmd received..." );
    // Program 1 - Turn on the light
    void prog1() {
      // one at a time
        memset(leds, 0, NUM_LEDS * 3);
        for(int i = 0 ; i < NUM_LEDS; i++ ) {
            leds[i].r = 255;
            leds[i].g = 255;
            leds[i].b = 255;
          FastSPI_LED.show();
          delay(30);
    // Program 3 - Static decoration light
    void prog3(int p3level) {
    //    Serial.println( "Starting prog3" );
      // Fade in/fade out
        int r_value = 255;
        int g_value = 255;
        int b_value = 255;
        int address_r = 10;
        int address_g = 11;
        int address_b = 12;
        r_value = EEPROM.read(address_r);
        g_value = EEPROM.read(address_g);
        b_value = EEPROM.read(address_b);
    //    Serial.println( "Setting color to: ");
        for(int k = 0; k < 256; k++) {
          for(int i = 0; i < ((NUM_LEDS/3)*2); i++ ) {
              if(k < b_value) {
                leds[i].b = k;
              if(k < g_value) {
                leds[i].g = k;
              if(k < r_value) {
                leds[i].r = k;
          FastSPI_LED.show();
          delay(3);
        delay(300);
        for(int k = 0; k <= p3level; k++) {
          for(int i = 0; i < (NUM_LEDS/3); i++ ) {
              if(b_value > 0) {
                leds[i].b = b_value;
              if(g_value > 0) {
                leds[i].g = g_value;
              //if(k > (r_value+30)) {
              if(r_value > 0) {
                leds[i].r = r_value;
          if(k=p3level) {
            for(int i = (NUM_LEDS/3)*2; i < (NUM_LEDS); i++ ) {
              leds[i].b = 0;
              leds[i].g = 0;
              leds[i].r = 0;
          b_value--;
          g_value--;
          r_value--;
          FastSPI_LED.show();
          delay(3);
    // Program 4 - Turn off the light
    void prog4() {
      // one at a time
            leds[i].r = 0;
            leds[i].g = 0;
            leds[i].b = 0;
          FastSPI_LED.show();
          delay(3);
    This is what it's sending:
    send: 8-8-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:100
  • Mod
    Uncomment
    and you'll probably see what is wrong. The print statements are there to help you debug 🙂
  • Contest Winner
    @Aloha with this statement on line 120: lastMillis = millis();
    You try to put an "unsigned long" (16 bits) in to an integer (8bits)
    this will change also the next variable in your case "bool lastTripped"
    Try to change line 71:
    int lastMillis;
    into
    unsigned long lastMillis;
  • @mfalkvidd said:
    Uncomment
    Hehe, yes you are right. The problem is the size of my sketch. It's really on the limit, if I just uncomment 1 print statement the sketch is too big. 😓 So I have to comment out or remove something else in order to uncomment something. ☺
    int lastMillis;
    into
    Wow, I'm impressed you saw that!
    It's actually working now. 👌
    With one less thing to worry about I might get some good sleep tonight. Thanks! 😄
  • 1
  • 1
11.3k
