Dust Sensor
  • I think my dust sensor is working fine with the second sketch i have attached in this post.
    I think some rows are missing in the MySensors sketch
    I can be wrong but my dust sensor didn't work with MySensors sketch, i had to modify it.
    Anyone that have this sensor and a working sketch?
     * Version 1.0 - epierre
     * Converted to 1.4 by Henrik Ekblad
     * Arduino Dust Sensort
     * connect the sensor as follows :
     *   VCC       >>> 5V
     *   A         >>> A0
     *   GND       >>> GND
     * Based on: http://www.dfrobot.com/wiki/index.php/Sharp_GP2Y1010AU
     * Authors: Cyrille Médard de Chardon (serialC), Christophe Trefois (Trefex)
     * http://www.mysensors.org/build/dust
    #define CHILD_ID_DUST 0
    #define DUST_SENSOR_ANALOG_PIN 1
    unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    int val = 0;           // variable to store the value coming from the sensor
    float valDUST =0.0;
    float lastDUST =0.0;
    int samplingTime = 280;
    int deltaTime = 40;
    int sleepTime = 9680;
    float voMeasured = 0;
    float calcVoltage = 0;
    float dustDensity = 0;
    MyMessage dustMsg(CHILD_ID_DUST, V_LEVEL);
      gw.begin();
      gw.sendSketchInfo("Dust Sensor", "1.1");
      gw.present(CHILD_ID_DUST, S_DUST);
      uint16_t voMeasured = analogRead(DUST_SENSOR_ANALOG_PIN);// Get DUST value
      // 0 - 5V mapped to 0 - 1023 integer values
      // recover voltage
      calcVoltage = voMeasured * (5.0 / 1024.0);
      // linear eqaution taken from http://www.howmuchsnow.com/arduino/airquality/
      // Chris Nafis (c) 2012
      dustDensity = (0.17 * calcVoltage - 0.1)*1000;
      Serial.print("Raw Signal Value (0-1023): ");
      Serial.print(voMeasured);
      Serial.print(" - Voltage: ");
      Serial.print(calcVoltage);
      Serial.print(" - Dust Density: ");
      Serial.println(dustDensity); // unit: ug/m3
      if (ceil(dustDensity) != lastDUST) {
          gw.send(dustMsg.set((int)ceil(dustDensity)));
          lastDUST = ceil(dustDensity);
      gw.sleep(SLEEP_TIME);
    Int val = 0;
    this is not in use anywhere in the code and if you comment it out it will still compile
    can be deleted
    2.
    You need to connect 6 cables otherwise it will not work.
    In beginning it says
     *   VCC       >>> 5V
     *   A         >>> A0
     *   GND       >>> GND
    Here you can find how it must be connected
    https://www.sparkfun.com/datasheets/Sensors/gp2y1010au_e.pdf
    and here
    http://arduinodev.woofex.net/2012/12/01/standalone-sharp-dust-sensor/
    Original sketch for Sharp GP2Y1010AU0F is like this
     Standalone Sketch to use with a Arduino Fio and a
     Sharp Optical Dust Sensor GP2Y1010AU0F
     Blog: http://arduinodev.woofex.net/2012/12/01/standalone-sharp-dust-sensor/
     Code: https://github.com/Trefex/arduino-airquality/
     For Pin connections, please check the Blog or the github project page
     Changelog:
       2012-Dec-01:  Cleaned up code
     This work is licensed under the
     Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
     To view a copy of this license, visit http://creativecommons.org/licenses/by-nc-sa/3.0/
     or send a letter to Creative Commons, 444 Castro Street, Suite 900,
     Mountain View, California, 94041, USA.
    int measurePin = 6;
    int ledPower = 12;
    int deltaTime = 40;
    void setup(){
      Serial.begin(9600);
      pinMode(ledPower,OUTPUT);
    void loop(){
      digitalWrite(ledPower,LOW); // power on the LED
      delayMicroseconds(samplingTime);
      voMeasured = analogRead(measurePin); // read the dust value
      delayMicroseconds(deltaTime);
      digitalWrite(ledPower,HIGH); // turn the LED off
      delayMicroseconds(sleepTime);
      // 0 - 3.3V mapped to 0 - 1023 integer values
      // recover voltage
      calcVoltage = voMeasured * (3.3 / 1024);
      dustDensity = 0.17 * calcVoltage - 0.1;
      delay(1000);
    1. MySensors sketch doesn't include any POWERLED, without this it cant work
    int ledPower = 12;
  • Hero Member
    hello,
    Thanks for reporting, I will check again here, for I never really successfully managed to have this one working.
    Beside this, the two others (cheaper but good anyway !) are working fine, see my repo here:
    https://github.com/empierre/arduino
  • @flopp
    same experience here,
    The sketch provided by Mysensors.org does not switch on/off the LED used to detect the dust particle (code below with corrections).
    I tested that sensor (Sharp_GP2Y1010AU) with smoke and because it does not have a fan (like the nova fitness SD011) or does not create a draft with a resistor (like the Shinyei PPD42NS) the fumes can go around completely undetected. When i tested the sharp and Shinyei in parallel the later seemed a lot more reliable.
    I also modified the code for the sharp sensor to get the arduino to loop thru multiple readings before sending a smoothed result back to the gateway.
    Code below with lots of debugging.
    *   VCC       >>> 5V
    *   A         >>> A0
    *   GND       >>> GND
    *   LED       >>> 2
    #define DUST_SENSOR_ANALOG_PIN 0
    int ledPower = 2;
    const int numreadings = 60;
    unsigned long SLEEP_TIME = 10*1000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    int val = 0;// variable to store the value coming from the sensor
    float valDUST = 0.0;
    int deltaTime = 40;
    void setup(){
     gw.begin();
    void loop(){
    float cumsum = 0;
    float temp = 0;
    float temp1 = 0;
    float cum_density = 0;
         for (int sample = 0; sample < numreadings; sample ++){ // loop reading dust sensor
           // recover voltage
           temp = voMeasured * (5.0 / 1024.0);
           cumsum = cumsum + temp;// cumulative sum over 60 seconds
           delay(1000);
           Serial.print("reading sample: ");
           Serial.println(sample);
           Serial.println(voMeasured);
           Serial.print(" - cumulative: ");
           Serial.println(cumsum);
    dustDensity = (0.17 * cumsum - 0.1)* (1000/60);
    Serial.println("#########################################");
    //  if (ceil(dustDensity) != lastDUST) {
    //      gw.send(dustMsg.set((int)ceil(dustDensity)));
    //      lastDUST = ceil(dustDensity);
  • 33
  • 8
  • 17
  • 6
  • 9
