  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 43.1k Views 4 Watching
  • freedomoticF Offline
    freedomotic
    wrote on last edited by freedomotic
    Hi all,
    I'm Mauro, member of Freedomotic development team.
    I'm working on a plugin for MySensors based on serial protocol.
    I need some testers to complete my work (no hardware available for now) so if you want to contribute please reply.
    Of course any suggestion, idea is welcome. All Java code is hosted on https://github.com/mcicolella/freedomotic/tree/mysensors-plugin/plugins/devices/mysensors
    Soon I'll post a brief tutorial for testing.
    Thanks and congrats for this interesting project
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
    • hekH Online
      hekH Online
      Welcome Mauro!
        freedomotic
        I have a question about commands for actuators. Is it possible to control a light (on/off)?
        In this case must I write a command on serial?
        Can you give me an example?
        hekH 1 Reply Last reply
        • freedomoticF freedomotic
          hekH Online
          hekH Online
          @freedomotic
          To turn on a light for node-id 13 with child-sensor-id 1 write the following to the gateway. In this example I don't ask for ack back to controller.
          13;1;1;0;2;1\n
            freedomotic
            the first prototype is ready for testing.
            First of all you must download the last build from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
            Java 1.7 required.
            Next extract the attached file into freedomotic_ROOT/plugins/devices.
            Open mysensors-manifest.xml into mysensors folder and set the port name of your gateway.
            Start freedomotic and then click on the plugin icon on the left side. It will be green.
            The plugin is configured for lights, temperature, pressure and light sensor. A new sensor icon will be added on the map. For lights you can click on it to turn on/off.
            It requires testing and adjustments so if you want to give a try let me know.
            mysensors.zip
            • hekH Online
              hekH Online
              @freedomotic
              We get small donations from the MySensors member to develop the project. New controller support is something we really encourage. If @freedomotic team need a small contribution to buy test-hardware let me know.
                freedomotic
                Hi Hek
                thanks for your offer. I think testing on large scale it's better to find and remove bugs.
                For now I'm using a simulator based on Arduino (without sensors/actuator) to send protocol strings on the serial.
                It seems working well.
                  freedomotic
                  Here some screenshots
                    freedomotic
                    Hi Hek
                    I added an icon from your Github profile. Can I use it?
                      Hi Hek
                      hekH Online
                      hekH Online
                      @freedomotic
                      Yes.
                        freedomotic
                        Hi all,
                        we created a page on our marketplace http://www.freedomotic.com/content/plugins/mysensors
                        You can download and test the plugin. For now I just simulated the serial protocol by a customized arduino sketch.
                        Bye
                        • hekH Online
                          hekH Online
                          Added page on http://www.mysensors.org/build/freedomotic
                            freedomotic
                            Thanks!
                            Just a note: in home page news there is a little typo: Freedomotic(s). So the link is broken.
                              Thanks!
                              hekH Online
                              hekH Online
                              @freedomotic said:
                              a little typo
                              Doh.. It will be fixed in a few minutes.
                                freedomotic
                                Hi all,
                                source code is now integrated on our master branch https://github.com/freedomotic/freedomotic/tree/master/plugins/devices/mysensors
                                C 1 Reply Last reply
                                  Hi all,
                                  C Offline
                                  C Offline
                                  Chetan
                                  Hi @freedomotic , i am not able to download the mysensors plugin from market place.. it is showing conteneously as connecting to online respository...
                                    freedomotic
                                    Hi @Chetan
                                    I just installed the plugin with no problem.
                                    Can you try again? Anyway you can download the file manually from marketplace page 1 Right click and Save as.. on .device file
                                    2. Unzip it into freedomotic_root/plugins/devices
                                    Let me know and thanks
                                      freedomotic
                                      Hi all,
                                      we are translating our software in different languages: in particular Swedish.
                                      Can you take a look and verify if it's correct?
                                      https://www.transifex.com/projects/p/freedomotic-open-source-buildi/
                                      • D Offline
                                        diamantmatch
                                        hey all,
                                        I have installed freedomotic on my pc and up and running with the mysensors plugin.
                                        there is a serial gateway(arduino duemilanove) connected via USB. i also have one sensor in the field with a relay switch.
                                        The serial connection of the gateway to the mysensors plugin is open. I verified this through the log view plugin where i saw the gateway presenting itself and telling the gateway startup is complete.
                                        The problem however is that when the sensor presents itsself asking for a node-ID, the controller never responds with anything. The node just keeps asking for a node ID by presenting as ID 255.
                                        Is there some kind of option in freedomotic or the mysensors plugin where i have to enable the vending of node ID's ? Or am i doing something wrong here..
                                        Thanks in advance,
                                        vincent
                                          freedomotic
                                          Hi Vincent,
                                          please can you give me more details? What's the expected reply from the controller (freedomotic)?
                                          And your sensor request? I developed the plugin by simulating devices communications. Maaybe something is not complete.
                                          Thanks for your support.
                                          A 1 Reply Last reply
                                          113.2k
