Power for (re-used) wall plug
  • Mod
    I want to re-use two old 433MHz wall plugs (it is an older version of these).
    I can take out all that is in there and replace it with my own stuff.
    However, the thing obviously (EU) has 230 volts and nothing else.
    I am new to this so the question is: what is the (best) way to bring the 230 volts down to what the board (Pro Mini), radio and the relay switch need?
    Thanks in advance,
    Marcel
  • Admin
  • Mod
    Hmm, I thought of that as well but I did not find any of these at 2A.
    Will (have to) look further now that I know they exist because this supplier does not ship to Germany 😞
    Thanks!!!
    Edit: found this one here
  • You can also just use transmitter of 433MHz wave and send commands to the wall plug.
    I have all the plugs maintained like that.
  • Mod
    Hi Andriej,
    I won't do that because I have experienced quite some issues with that frequency.
    Some of my neighbours use the same frequency and I have had my (kitchen) light go on and off without doing anything (or even being home) too many times with these 2 devices.
    That is why I decided to re-use their housing but not the technology...
    But, thank you for the suggestion!
    Cheers,
    Marcel
  • 87
  • 10
  • 7
  • 1
  • 7
11.3k
