Humidity repeater, easy question...?
  • Hi Guys,
    I'm using the humidity sketch from the dev build. Quick question, to enable it as a repeater, so I simply add
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    and change
    sleep(SLEEP_TIME); // Sleep (non repeater) to wait(SLEEP_TIME); // Sleep (non repeater)
    Is that all that's required?
    Thanks,
    Mark
  • Mod
    You should also change
    to use wait, otherwise the node might drop packages during this time.
  • @mfalkvidd I currently have this, what do you suggest I change?
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a humidity/temperature
     * sensor using DHT11/DHT-22
    // Enable debug prints
    // #define MY_DEBUG
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      metric = getConfig().isMetric;
      sendSketchInfo("Temperature + Humidity", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      // Fetch temperatures from DHT sensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      // Fetch humidity from DHT sensor
      if (isnan(humidity)) {
          lastHum = humidity;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
      // sleep(SLEEP_TIME); // Sleep (non repeater)
      // wait(SLEEP_TIME); // Wait (repeater)
    Edit: Apologies, I see what you're advising to do, I missed that line. I've made the change now.
  • 1
  • 24
  • 1
11.3k
