How to turn on V_LIGHT with MQQT manually?
  • Trying to figure out how to turn on a light by publishing a MQTT command manually (via MQTTLens).
    Device ID is 101 on node 0. Serial monitor on the Arduino shows: 0;255;3;0;9;Sending message on topic: P/0/101/1/0/2
    I'm also curious about the Receive function at the end
    if (message.type==V_LIGHT)
    Where does it get the message type from? where would it find V_LIGHT?
    Full sketch:
    // This MQTT gateway works on Arduino Mega2560 only!
    //#define MY_RADIO_NRF24
    // Set this nodes subscripe and publish topic prefix
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "P"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "S"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "M1"
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    // The PINs mentioned here are for Arduino Mega2560 ! Color code is from MySensor site
    #if !defined(MY_W5100_SPI_EN)
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 14 // Green
      #define MY_SOFT_SPI_MISO_PIN 16  // Violet
      #define MY_SOFT_SPI_MOSI_PIN 15  // Blue
    #define MY_RF24_CE_PIN 17  // Orange
    #define MY_RF24_CS_PIN 18  // Yellow
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192,168,1,16
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    #include <OneWire.h>
    #include <DHT.h>
    #define CHILD_ID_Analog1 1
    #define CHILD_ID_PIR 2
    #define CHILD_ID_GAS 3
    #define CHILD_ID_T1 4
    #define CHILD_ID_REL1 101
    #define CHILD_ID_REL2 102
    #define CHILD_ID_HUM 7
    #define CHILD_ID_TEMP 8
    Ethernet use the following PINs, do not use them:
    Mega: 4, 10, 50, 51, 52, 53
    #define Analog_PIN A5
    #define PIR_PIN 2
    #define MQ_PIN A4
    #define ONE_WIRE_BUS 3
    #define REL1_PIN 7
    #define REL2_PIN 8
    #define HUMIDITY_SENSOR_DIGITAL_PIN 33
    #define TEMPERATURE_PRECISION 12
    OneWire oneWire(ONE_WIRE_BUS);
    MyMessage msgAnalog1(CHILD_ID_Analog1, V_VAR1); //24 .. 28
    MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED); // 16
    MyMessage msgGas(CHILD_ID_GAS, V_VAR1); //24
    MyMessage msgT1(CHILD_ID_T1, V_TEMP); // 0
    MyMessage msgREL1(CHILD_ID_REL1, V_LIGHT);  // 2
    MyMessage msgREL2(CHILD_ID_REL2, V_LIGHT);  // 2
    MyMessage msgHum(CHILD_ID_HUM, V_HUM); // 1
    MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); // 0
    DHT dht;
    // address must be updated
    DeviceAddress addrTemp1 = { 0x28, 0xFF, 0x57, 0x98, 0x80, 0x15, 0x42, 0x17 };
    const unsigned long tUpdate=60000; //update interval
    unsigned long t0;
    int InA1;
    byte StatePIR=0;
    byte oldStatePIR=0;
    int InAnalog1;
    int valMQ=0;
    int refMQ=1023; // refference value will be the lowest value read from the sensor
    float Temp1;
    float Temp, Hum;
    byte StateREL=0, StateREL1=0, StateREL2=0;
      pinMode(PIR_PIN, INPUT_PULLUP);
      sensors.begin();
      sensors.setResolution(addrTemp1, TEMPERATURE_PRECISION);
      pinMode(REL1_PIN, OUTPUT);
      digitalWrite(REL1_PIN, StateREL1);
      pinMode(REL2_PIN, OUTPUT);
      digitalWrite(REL2_PIN, StateREL2);
      t0=millis();
    void presentation() {
      present(CHILD_ID_Analog1, S_CUSTOM);
      present(CHILD_ID_PIR, S_MOTION);
      present(CHILD_ID_GAS, S_CUSTOM);
      present(CHILD_ID_T1, S_TEMP);
      present(CHILD_ID_REL1, S_LIGHT);
      present(CHILD_ID_REL2, S_LIGHT);
      present(CHILD_ID_HUM, S_HUM);
      StatePIR=digitalRead(PIR_PIN);
      if (StatePIR != oldStatePIR) {
        oldStatePIR=StatePIR;
        ServerUpdate();
      if ((millis()-t0) > tUpdate) ServerUpdate();
    void ServerUpdate() {
      InA1=analogRead(Analog_PIN);
      send(msgAnalog1.set(InA1));
      send(msgPir.set(StatePIR ? "ON" : "OFF"));
      InAnalog1=analogRead(MQ_PIN);
      if (InAnalog1<refMQ) refMQ=InAnalog1; // if read value is lower that actual, change the 0 refference with the actual one
      valMQ=InAnalog1-refMQ;
      send(msgGas.set(valMQ));
      Temp1 = sensors.getTempC(addrTemp1);
      send(msgT1.set(Temp1,1));
      Hum = dht.getHumidity();
      Temp = dht.getTemperature();
      send(msgTemp.set(Temp, 1));
      send(msgHum.set(Hum, 1));
      send(msgREL1.set(StateREL1 ? "ON":"OFF"));
      t0=millis();
      if (message.type==V_LIGHT) {
        StateREL=strcmp(message.data,"ON")==0;
        switch(message.sensor) {
          case 101: {
            StateREL1=StateREL;
            if (StateREL) {
              digitalWrite(REL1_PIN, HIGH);
            else {
              digitalWrite(REL1_PIN, LOW);
          break;
          case 102: {
            StateREL2=StateREL;
            if (StateREL) {
              digitalWrite(REL2_PIN, HIGH);
            else {
              digitalWrite(REL2_PIN, LOW);
            send(msgREL2.set(StateREL2 ? "ON":"OFF"));
          break;
  • Never mind figured it out.
    There was a problem somewhere in that sketch. basically started from scratch again. merged the W5100 MQTT client gateway sketch and the relay sketch. then referred to here for serial MQTT syntax.
    Hope anyone else thats struggling finds this info useful.
11.3k
