  3. Eagle files for a MeanPenguin MySensors PCB
30 Posts 15 Posters 24.7k Views 6 Watching
    meanpenugin
    wrote on last edited by meanpenugin
    Any feedback would be appreciated before I send it off to be produced.
    Attached are the Schematic and the Layout and will be updated as changes are made from the suggestions.
    Using various entries in the Forum and using this as a starting point (thanks @THERICK), this is what I have...
    http://forum.mysensors.org/topic/205/my-ideal-sensor-node-pcb/22
    ##Size##
    5cm x 5cm
    ##Power##
    If using 5V Regulated
    • Use 5V Arduino Pro Mini
    • Connect pins 1 and 2 on Jumper 1
    • Connect pins 1 and 2 on Jumper 2
    • VCC is 5V
    • Install AMS1117
    • +3V3 is 3.3 volts
    If using 3.3V Regulated
    • Use 3V3 Arduino Pro Mini
    • Connect pins 2 and 3 on Jumper 1
    • Connect pins 2 and 3 on Jumper 2
    • VCC is 3.3V
    • Install a jumper wire across IN and OUT pins labeled for the AMS1117 (Don't install the AMS1117)
    • +3V3 is 3.3 volts
    • No 5v sensors
    Using Unregulated > 5V
    • Install the LM7805 (Vin pin on left, Vout pin on right)
    • Use capacitors (C3, C4) as needed
    • VCC is 5 volts
    • Install AMS1117
    • +3V3 is 3.3 volts
    ##Data Pins##
    Right edge of the board
    • Two digital pins on 3v3 with optional pull-up resistor.
    • One digital pins on VCC with optional pull-up resistor.
    Center of the board Mini Proto area (Columns from Left to Right)
    • VCC
    • Data pins (A0, A2, A2, D3, D5, D8)
    • Independent holes 3 x 7
    • GND
    ##Required Bill or Materials##
    1 x Arduino Pro Mini (5V or 3V3 depending on the supply power and sensor requirements)
    1 x NRF24L01+ 2.4GHz Wireless Transceiver
    1 x Capacitor for the Radio across 3V3 and Gnd
    1 x AMS1117 5V-3.3V Step Down Module (If NOT supplying 3v3 regulated power)
    ##Optional##
    1 x 7805 + Capacitors if not providing regulated power
    PCB Mount 3 Pin Plug-in Screw Terminal Block for Power In and Data pins on the Right side of the board
    Female pin headers for the Arduino and the Radio
    Sensors
    Pull-up resistors
    Panelized Gerber file sent to ITead: ArduinoMiniProBoard v2-Panel-Gerber 2014-11-04.zip [Order the 5cmx10cm board for $15, which gives you 10 boards you cut in half to make 20] (http://imall.iteadstudio.com/open-pcb/pcb-prototyping/im120418002.html).
    Note: I was able to email them and ask to double the 5cmx10cm to the 10cmx10cm for $19 netting 40 boards. You would have to do more cutting. I was able to do it easily with a box cutter and a straight edge ruler.
    Eagle Files: ArduinoMiniProBoard-v2-0.zip
    11/24/2014: Tested v2 board and it is working. I have about 50 feet with 3 walls in between with not much failures. I need to see if caps will extend the range...
    11/12/2014: Uploaded v2 Schematics and picture of the Board. Will post the Gerber files when I receive my board and they test OK.
    10/31/2014: Found problems with the board.. Need to make a Rev 2 and retest.
    M M 2 Replies Last reply
      meanpenugin
      Updated 9/24/2014
      • Completed Schematic
      • Initial Layout (Panelized) 2 Boards @ 50mmx50mm completed
      Updated 9/23/2014
      • Added 5 pin proto-area with Power and Gnd
      • Auto routed the board
        Nice one @meanpenugin!
        • aquaproA
          aquaproA
          aquapro
          Nice and thanks for the detailed description.
          • M meanpenugin
            ##Size##
            5cm x 5cm
            ##Power##
            • VCC is 5V
            • Install AMS1117
            • +3V3 is 3.3 volts
            • VCC is 3.3V
            • +3V3 is 3.3 volts
            • No 5v sensors
            • VCC is 5 volts
            • Install AMS1117
            • +3V3 is 3.3 volts
            ##Data Pins##
            • VCC
            • GND
            ##Optional##
            Sensors
            Pull-up resistors
            meanpenugin
            Update 9/25/2014
            • Completed Board with all Silkscreen
            • Added Ground plane on bottom, Vcc plane on top
              Ready to send it to be built...
            • R
              R
              Rek
              Ill take a few of those if you are ordering extra :) Looks good.
              M 1 Reply Last reply
              • R Rek
                meanpenugin
                @Rek Send me your address on chat and if the board tests ok, I'll send a couple your way..
                • M meanpenugin
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @meanpenugin Have you received the boards yet, did they work as expected?
                  Any thoughts on a new version? Would you consider replacing the AMS1117 with some other solution? I mean seeing as we don't really have a good boost available. Or is it perhaps better to keep it as is and plug in a boost circuit when we have it?
                  I agree that you could save a great deal of space by hanging the nrf24 over some other components. But I will leave those details to the experts.
                  Eeprom?
                  Really like the protoarea. It seems SMD friendly.
                    meanpenugin
                    @bjornhallberg just got the boards yesterday... A few cuts using the stanley knife and .. snap - I have two boards.. Hope to fire it up this weekend... Open to any and all suggestions..
                    I guess the goal of this board is really for non-battery usage. There are lots of boards focusing on the battery version.. But we can see if this board can be utilized to support the battery as well....
                    I have a question out to @Bandra to see how his board with the radio installed over the Arduio is functioning. If there are no negative effects, I may change mine to that layout...
                    So this board can be Fed Unregulated V+, or 5V regulated, or 3v3 regulated.
                    If supplying unregulated, install a regulator (5v or 3v3)
                    If supplying 5v regulated or installed a 5v regulatore, install a 3v3 regulator for the radio
                    If supplying 3v3 regulated use the board without any regulators
                    The AMS1117 is to use when the supply voltage is 5V or a 5v Regulator is installed - the AMS1117 is used to generate the 3v3 needed for the Radio. Can check if the LE33A in the store is pin compatible and use it instead on the board. Is this what you are suggesting?
                    The EEPROM is interesting - At this point, haven't thought of it. Is the big need so it can be used in OTA programming?
                    The Protoarea are not SMD pads, they are holes. But, it's possible to change them (Option 2 board if there is a lot of interest)
                    • M meanpenugin
                      bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      @meanpenugin Yeah, your board is pretty versatile. No one is stopping people like myself from plugging in a regulator, like the one that will be officially available soon. I meant a regulator that is not in the store, like the tps61097a or whatever (which is still possible to solder without reflow or anything like that.) Preferably one that is cheaper and requires no more components (2xcapacitors, 1xinductor) We had a bunch of them listed in a thread, months ago. I failed miserably at prototyping those myself but I might have more luck when someone more clever has set a pcb to follow.
                      No expert on the eeprom, sorry, don't know what we've decided on basically.
                      I'm not really proficient reading Eagle sketches, it looked like the protoarea had sort of elongated solder pads around the holes. I thought it was some sort of all-in-one solution to be able to fit both smd and throughhole. Regardless, a protoarea is a great idea for making the board a bit more flexible and future-proof. Doesn't have to be smd. I have a bunch of adapters.
                      • L
                        L
                        lunarok
                        For easier reading and understanding, can you list all the parts needed with your PCB ? like headers, capacitors, resistances ...
                        • K
                          K
                          kalle
                          wrote on last edited by kalle
                          @meanpenugin
                          Wow, great work and exact for what I'm looking for.
                          Does the board working well?
                          It would be great if you can share the files or is it possible to order/buy some of the pcb-boards?
                          Kalle
                            meanpenugin
                            @kalle
                            V1 of the board had problems. V2 boards just shipped out of HK and should be here within a week or two...
                            I'll start updating info with the changes in the mean time as it has changed a little bit.
                            Happy to provide you with the files needed to get them ordered.
                            Just want to wait to test the boards before I post them...
                            If you rather not wait, I can give you the Eagle files so you can verify and send the order in to get them produced.
                            I can send a couple of boards for you to test before getting a lot of them produced as well..
                            Edward
                            K 1 Reply Last reply
                            • N
                              N
                              NotYetRated
                              Interested to see how things go with this, have been looking for something similar. Currently, I am not very interested in battery powering, as most other boards seem to have a focus on. Mostly just interested in temp/humidity/presense/ir for now. Let me know if I can do anything to help!
                              Also, what is the size of this guy?
                              • M meanpenugin
                                @kalle
                                Edward
                                K
                                K
                                kalle
                                @meanpenugin
                                Thanks Edward, I can wait and maybe I will ask you later for some boards.
                                Really great work!
                                Kalle
                                • N
                                  N
                                  Nicola Reina
                                  absolutely great! waiting for your files to be piblished to, finally, start building!
                                    meanpenugin
                                    The board tested good.
                                    I have some small changes I would make for the next version but this board is good enough to start building...
                                    The files are attached in the first post.
                                    You you make enhancements, please share your enhancements so everyone else can benefit.
                                    Edward
                                    • K
                                      K
                                      kalle
                                      Hi Edward, big thanks for your work - great job.
                                      • bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        So, I ordered a test batch from DirtyPCBs (Protopack ±10). We'll see how it goes. I felt that their dirty fab needed more of a challenge so I added some completely useless silkscreen graphic to the back and rounded the corners of the pcb. Very interested to see how they react (I guess they love it when people submit silkscreen that covers pads etc) and how the board turns out. I did see in a couple of reviews that their alignment of silkscreen and mask in particular can be a bit off. No big deal I suppose.
                                        Thanks again for your design work.
                                        • N
                                          N
                                          NotYetRated
                                          Just ordered some boards. Look forward to tinkering! Thanks!
