Codebender motion sketch compile error
  • I'm trying to use codebender to upload the default motion sensor node to my Arduino and am getting this compile error:
    In file included from (library file) MySensor/MyGateway.cpp:12:
    (library file) MySensor/MyGateway.h:39:28: error: use of undeclared identifier 'DEFAULT_CE_PIN'
                    MyGateway(uint8_t _cepin=DEFAULT_CE_PIN, uint8_t _cspin=DEFAULT_CS_PIN, uint8_t _inclusion_time = 1, uint8_t _inclusion_pin = 3, uint8_t _rx=6, uint8_t _tx=5, uint8_t _er=4);
    Can someone tell me how to get around this?
  • Admin
    That's strange... did you clone the sketch together with library? Are you having some old MySensors version in your account?
    To be honest, I have no idea. I was trying to run it directly from the sensor information page from the build link. I do have an account, but I have no idea if I have an old version. I guess I'll have to investigate my account and see if I can update/uninstall the old version.
    I'm back at this and am totally confused. I thought that the codebender site would have the updated MS code and examples. Do I need to do something specifically to get it to work with my account? I'm trying to upload the humidity sensor sketch and am getting this error:
    (sketch file) HumiditySensor.ino:40:5: error: no matching constructor for initialization of 'DHT'
    DHT dht;
    (library file) DHT/DHT.h:31:3: note: candidate constructor not viable: requires at least 2 arguments, but 0 were provided
      DHT(uint8_t pin, uint8_t type, uint8_t count=6);
    (library file) DHT/DHT.h:23:7: note: candidate constructor (the implicit copy constructor) not viable: requires 1 argument, but 0 were provided
    class DHT {
    I do have the Arduino IDE installed but it seems to be all messed up. I'm trying to uninstall it and get it working again. I'm not sure how I munged it up but I have no way to upload MS stuff. Any help is greatly appreciated. I only have a small window of time to work on these side projects so any help is really appreciated.
  • Admin
    Codebender only support arduino 1.0 (if I remember right), which isn't compatible with mysensors 2.0. So latest and greatest of mysensors can't be supplied through codebender.
  • @tbowmo Still very unclear how this works. I'm assuming that codebender is self contained and that I should be able to use it to upload code to my arduino . I understand that this may be outdated, but it should still work right?
    At this point I'm just trying to find some way to upload a temp/humidity sketch to my node and I'm having a heck of time getting things working.
    I don't really care if I use 2.0 or an older version, but I'm not seeing a 2.0 example of the temp/humidity sketch. Does one exist?
  • Admin
    @chuckconnors
    Sorry, I don't use codebender at all, so I do not know how it works.. (I got my info from what @hek told me last weekend during our meet-up at his place)
  • @tbowmo Sorry. I was unclear. I don't mind using the Arduino IDE on my windows machine, but I don't know how to install the correct libraries to use the legacy code. Either that or is there a temp/humidity example sketch for 2.0? I can't find one in the code examples and I don't know what needs to be modified from the older version to make it work with 2.0. Just changing the include name is not enough.
  • Admin
    @chuckconnors
    We moved a lot of examples to a separate repository on GH during our release, as we can't have all the 3rd party libraries distributed with the core..
    This is located at https://github.com/mysensors/MySensorsArduinoExamples, where you can find lot's of examples (all of them is updated to 2.0.0)
  • 4
  • 5
  • 14
11.3k
