  3. Arduino Options
Arduino Options
6 Posts 5 Posters 4.2k Views 3 Watching
  • wmylionelW Offline
    wmylionelW Offline
    wmylionel
    Here are some alternative arduino boards that can be used for the wonderful pairing of arduino + nrf24l01.
    For sensor (arduino+nrf24l01 header) - Sensor Node by Elecrow,
    http://www.elecrow.com/wiki/index.php?title=Sensor_Node_V1.2_(ATmega_328)
    For gateway (arduino+ethernet+nrf24l01 header) - IBOARD by Iteadstudio,
    http://imall.iteadstudio.com/development-platform/arduino/arduino-compatible-mainboard/im120410001.html
    Please add any other hardware options you find and that make this project even simpler to implement.
    • greglG Offline
      greglG Offline
      gregl
      dude....i wish id seen your post before! - i just "discovered" the same two boards! and posted above too
      I totally agree these do look ideal for what we are doing!
      • greglG Offline
        greglG Offline
        gregl
        I just placed an order...
        Foca IM120525005 1 $6.50
        IBoard IM120410001 1 $17.50
        RBoard IM120618001 1 $19.50
        ITEAD Arduino Nano IO shield IM120417016 5 $25.00
        Now the waiting begins!
        J 1 Reply Last reply
        • P Offline
          P Offline
          PITP2
          That's sound good :-)
          But how long the CR2032 will powered the sensor ? .. because i use 2*AA battery on my pcbsensor and for the time being my sensor was power less than 2 months.
          • SleepyhatS Offline
            SleepyhatS Offline
            Sleepyhat
            For an ethernet gateway, I have an Arduino MEGA 2560. Here is the pinout I have working:
            • MEGA *
            • ----------- Connection guide ---------------------------------------------------------------------------
            • 52 Radio & Ethernet SPI SCK
            • 50 Radio & Ethernet SPI MISO (SO)
            • 51 Radio & Ethernet SPI MOSI (SI)
            • 53 Ethernet SPI Slave Select (CS) Pin 53, the SS pin, must be an o/p to put SPI in master mode
            • 9 Radio TX LED using on board LED (optional) +5V -> LED -> 270-330 Ohm resistor -> pin 9. ********
            • 8 Radio RX LED (optional) +5V -> LED -> 270-330 Ohm resistor -> pin 8. ********
            • 7 Radio error LED (optional) +5V -> LED -> 270-330 Ohm resistor -> pin 7. ********
            • 6 Radio SPI Slave Select
            • 5 Radio Chip Enable (CE)
            • 3 Inclusion mode button (optional), 10K pull down to GND, button to VCC) ********
            • 2 Radio IRQ pin (optional), W5100 Int, if linked to pin 2) ********
            • Powering: both NRF24l01 radio and Ethernet(ENC28J60) uses 3.3V
              The ********* were just a visual reference for me on the "optional" pins since I was not using them in testing.
            • greglG gregl
              J Offline
              J Offline
              jhiegel
              @gregl I know its been a year+ from your post, but I figured out a way around 'the waiting' ....I order stuff every few days from China that I might/probably will need for another upcoming project & that way have a series of things coming in over a couple of months. Sometimes they screw me up & deliver too fast, but I can live with that!!!!! Now I have a good inventory of 'cheap' items to draw from for projects and of course I continue to order.
              11.8k
              113.2k
