!TSM:FPAR:FAIL - node not connecting to working GW
  • Hi
    I created a new node with latest 1.5 mysensors version.
    this is what I get in sensor debug:
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    and this is from the 5100 GW debug:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.0.109
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    so node is transmitting and receiving and also the GW
    Why aren't the node get an ID and why the finding parent part is failing?
    I also checked to see this is not working with 5 examples. and I did clear the eeprom.
    also when I flash serial GW to this node just to check if it is power issues everything is OK and the serial GW is OK so it is not power issues. also this 5100 GW works with other sensors...
  • OK
    So I ported all the library to 2.0.0 and the same !TSM:FPAR:FAIL
    So I switch to serial GW and all is OK.
    Is the 5100 ethernet GW example sketch compatible with 2.0.0?
  • Contest Winner
    @Mickey There can be many different reasons, why the node fails to connect to the gateway. For example how you power the ethernet gateway. Looking at you problem I'm guessing that the issue is power related. But for me that's hard to be sure of, based upon your logs.
    It might help if you post the circuits you use.
  • Hi there, I had a similar problem gw and sensor saw each other but the sensor did not get an id. Later I found that the controller hands out the id's, not the gateway. So when I connected the controller to the gw and configured it to use the gw arduino it worked. Not sure if this is your problem also but just in case 🙂
    Greets,
    Mark
  • 15
  • 1
  • 24
11.3k
