bravo and good explanation
good to show that Arduino "8bits" and MySensors can do things simply, without gas factory
an extensible basis for further input/output
(door contact - relay control ...etc )
a line of the examples given in the sketches for the use of RS485 can be a source of problem
(it's my case, I use Pin2 or3 for a long time )
// Define this to enables DE-pin management on defined pin
#define MY_RS485_DE_PIN 2
(2 or 3 is an interrupt pin for a Uno)
avoided interrupt pins.
the pin 10 is a good thing
I mean the ESP framework version, selected by the board version
https://arduino.esp8266.com/Arduino/versions/2.0.0/doc/installing.html#:~:text=Open Boards Manager from Tools,from a drop-down box.
