Mysensors 2.0 ESP8266 serial gateway
  • I set in sketch static ip aadress and if esp booting and connected to lan i see in serial monitor
    Connected with home, channel 1
    dhcp client start...
    chg_B1:-40
    0;255;3;0;9;TSM:READY
    f r-40, scandone
    ...................pm open,type:2 0
    ......................................................................................................................................................................................................................................................................................................................0�~?�4�����OCAZ��0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.0.1-beta
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    chg_B1:-40
  • #include <EEPROM.h>
    #include <ArduinoOTA.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "home"
    #define MY_ESP8266_PASSWORD "123456789"
    #define MY_ESP8266_HOSTNAME "ota-gateway-CH.100"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 10, 124, 77, 101
    #define MY_IP_GATEWAY_ADDRESS 10, 124, 77, 176
    #define MY_IP_SUBNET_ADDRESS 255, 255, 255, 0
    #define MY_PORT 5003
    #define MY_GATEWAY_MAX_CLIENTS 1
    //#define MY_CONTROLLER_IP_ADDRESS 10, 124, 77, 46
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    #define MY_INCLUSION_MODE_BUTTON_PIN 3
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
    #define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
    #if defined(MY_USE_UDP)
    #include <WiFiUDP.h>
    #else
    #include <ESP8266WiFi.h>
    ArduinoOTA.onStart( {
    Serial.println("ArduinoOTA start");
    ArduinoOTA.onEnd( {
    Serial.println("\nArduinoOTA end");
    ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
    ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
    ArduinoOTA.begin();
    Serial.println("Ready");
    Serial.print("IP address: ");
    Serial.println(WiFi.localIP());
    void presentation() {
    // Send locally attech sensors data here
    ArduinoOTA.handle();
  • 4
  • 933
  • 5
11.3k
