Codebender shutdown notice
  • Admin
    Codebender will be suspending their service in a couple of months:
    We have already replaced all codebender sketches on the main site so it shouldn't be much of a problem.
    Forum
    There still is a few codebender sketches embedded in forum posts. Those will probably be unreachable when their service shuts down. We suggest you try to grab the code and embed the sketch directly in the post instead.
    OpenHardware.io
    The codebender embed function will stop working here as well. You can instead easily embed code from your github repo directly into the page by using the following syntax in the project markdown:
    ``https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino``
    This will fetch and embed the sketch with some meta information (last commit, author etc.) which will look like this:
    https://www.mysensors.org/build/humidity#example
  • 5
  • 109
  • 109
  • 110
