DHT11 locally on a ESP8266 MQTT Gateway
  • Hi
    Im trying to get my ESP8266 MQTT Gateway with a locally attached DHT11 sensor to work and I almost got it.
    My problem is that the temp im reading is waaaay off. See screenshot
    Serial monitor
    Any help would be appreciated.
    The sketch im using is this:
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "SSID"
    #define MY_ESP8266_PASSWORD "PASSWORD"
    #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1 , 87
    #define MY_PORT 1883
     #include <ESP8266WiFi.h>
     #include <DHT.h>
    //DHT11 stuff, This node on MQTT mygateway1-out/X/1/1/0/0 for temperature and mygateway1-out/X/0/1/0/1 for humidity
    #define DHT_DATA_PIN 5
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 2000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_BUTTON_PIN  1
    // Set blinking period
    // Flash leds on rx/tx/err
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      wait(dht.getMinimumSamplingPeriod());
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      wait(UPDATE_INTERVAL);
  • I can also add that the room in measuring is quite cold. Like about 13-16 degrees so its not only a decimal error.
    I might have a faulty DHT11 module but im not shure.
  • Mod
    @Yeitso What DHT11 library are you using? It might not be compatinly with ESP8266...
    You could try the library describved here: https://techtutorialsx.wordpress.com/2016/04/24/esp8266-read-dht11-measurements/
  • Yeah im gonna try to switch to adafruits lib. Atm im using the one from mysensors.
  • 1
  • 15
  • 24
