Need a refresher on presentation and HA
  • Hi,
    I took a bit of a hiatus from this site/Arduino and now can't for the life of me debug a presentation on a node with two LED lights.
    Here is the errors I am getting during presentation:
    Starting repeater (RNNRA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=24)
    TSM:FPAR
    TSP:MSG:SEND 24-24-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 4-4-24 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=4, dist=1)
    TSP:MSG:PAR OK (ID=4, dist=2)
    TSP:MSG:READ 0-0-24 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSP:MSG:READ 2-2-24 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=2, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=24)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-24 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    TSP:MSG:SEND 24-24-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-24 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:READ 0-0-24 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Holiday Desk Light
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
    TSP:MSG:SEND 24-24-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    !TSP:MSG:SEND 24-24-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=fail:
    NODE:!REG
    NODE:!REG
    Request registration...
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=ok:2
    TSP:MSG:READ 0-0-24 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=24, parent=0, distance=1, registration=1
    and here is my sketch
     * Version 1.0 - Henrik Ekblad
    #define MY_REPEATER_FEATURE
    #define LIGHTS_MULTI 3
    #define LIGHTS_WHITE 5
    #define CHILD_ID_MULTI 1
    #define CHILD_ID_WHITE 2
    #define LIGHTS_MULTI_ON 1  // GPIO value to write to turn on attached relay
    #define LIGHTS_MULTI_OFF 0 // GPIO value to write to turn off attached relay
    #define LIGHTS_WHITE_ON 1  // GPIO value to write to turn on attached relay
    #define LIGHTS_WHITE_OFF 0 // GPIO value to write to turn off attached relay
    MyMessage msgMULTI(CHILD_ID_MULTI, V_LIGHT);
    MyMessage msgWHITE(CHILD_ID_WHITE, V_LIGHT);
    void before() {
        pinMode(LIGHTS_MULTI, OUTPUT);
        pinMode(LIGHTS_WHITE, OUTPUT);
        digitalWrite(LIGHTS_MULTI, loadState(1)?LIGHTS_MULTI_ON:LIGHTS_MULTI_OFF);
        digitalWrite(LIGHTS_WHITE, loadState(2)?LIGHTS_WHITE_ON:LIGHTS_WHITE_OFF);
    // present(255, 18);
      sendSketchInfo("Holiday Desk Light", "1.0");
          present(CHILD_ID_MULTI, S_LIGHT);
          present(CHILD_ID_WHITE, S_LIGHT);
          send(msgMULTI.set(1));
          send(msgWHITE.set(1));
      if (message.type==V_LIGHT && message.sensor == CHILD_ID_MULTI) {
         // Change relay state
         digitalWrite(LIGHTS_MULTI, message.getBool()?LIGHTS_MULTI_ON:LIGHTS_MULTI_OFF);
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
         if (message.type==V_LIGHT && message.sensor == CHILD_ID_WHITE) {
         digitalWrite(LIGHTS_WHITE, message.getBool()?LIGHTS_WHITE_ON:LIGHTS_WHITE_OFF);
    Anyone help a born-again newb? :{
  • Plugin Developer
    • Add a short wait between presentations of child 1 and 2 in presentation. Presentation of second child failed to be received.
    • Send initial values for both children in loop.
    • Send feedback of state change to gateway/controller in receive.
  • hi @martinhjelmare
    I added a wait into the presentation, and that got rid of the fail message. Now I am trying to send the initial value (so that HA will register it) and it does not seem to be working. I also added the sending of the status in the receive message, here is an updated sketch and my debug log. What could I be missing?
    Thanks again!
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 24-24-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    NODE:!REG
    NODE:!REG
    TSP:MSG:SEND 24-24-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    Node registration=1
    TSP:SANCHK:OK
    TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:MSG:FPAR REQ (sender=1)
    TSP:CHKUPL:OK
    TSP:MSG:GWL OK
    TSP:MSG:SEND 24-24-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:SANCHK:OK
    sketch
    void before() {
        digitalWrite(LIGHTS_MULTI, loadState(CHILD_ID_MULTI)?LIGHTS_MULTI_ON:LIGHTS_MULTI_OFF);
        digitalWrite(LIGHTS_WHITE, loadState(CHILD_ID_WHITE)?LIGHTS_WHITE_ON:LIGHTS_WHITE_OFF);
          wait(150);
          wait(150);
          wait(150);
         send(msgMULTI, message.getBool()?LIGHTS_MULTI_ON:LIGHTS_MULTI_OFF);
         send(msgWHITE, message.getBool()?LIGHTS_WHITE_ON:LIGHTS_WHITE_OFF);
  • Plugin Developer
    Send initial values in loop. No set/req messages are allowed until after the node is registered at the gateway. This happens after presentation in mysensors 2.0.
    See example sketch here:
    https://home-assistant.io/components/mysensors/#presentation
  • @martinhjelmare
    Thanks, i finally got it. I went to the example you have on home-assistant.io and removed the button and added a second actuator. Works like it should now. You are the king!
    Final code for anyone whom it may help/want it.
     *Holiday LED Lights MySensors Module, for MySensors v2.0
     * Nothing fancy, just a two actuator (on/off) virtual switch for small
     * low powred LED strings that normally run from a battery pack.
    #define MY_NODE_ID 24 // or comment out for auto
    #define MULTI_PIN  3 // Pin that Multi-Coloured LED string is connected to
    #define WHITE_PIN 5  // Pin that White LED string is connected to
    #define CHILD_ID_MULTI 1 // Child ID for Multi-Coloured LED String
    #define CHILD_ID_WHITE 2 // Child ID for White LED String
    #define MULTI_ON 1
    #define MULTI_OFF 0
    #define WHITE_ON 1
    #define WHITE_OFF 0
    bool stateMULTI = false; // Place holders for the loop function to register nodes in Home-Assistant
    bool initialValueSentMULTI = false;
    bool stateWHITE = false;
    bool initialValueSentWHITE = false;
    MyMessage msgMULTI(CHILD_ID_MULTI, V_STATUS); //Presentation of Switch for Multi-Coloured LEDS
    MyMessage msgWHITE(CHILD_ID_WHITE, V_STATUS); //Presentation of Switch for White LEDS
      digitalWrite(MULTI_PIN, MULTI_OFF);
      pinMode(MULTI_PIN, OUTPUT);
      digitalWrite(WHITE_PIN, WHITE_OFF);
      pinMode(WHITE_PIN, OUTPUT);
    void presentation()  {
      sendSketchInfo("HolidayDeskLights", "1.0");
      if (!initialValueSentMULTI) {
        send(msgMULTI.set(stateMULTI?MULTI_ON:MULTI_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID_MULTI, V_STATUS);
        wait(2000, C_SET, V_STATUS);
        if (!initialValueSentWHITE) {
        send(msgWHITE.set(stateWHITE?WHITE_ON:WHITE_OFF));
        request(CHILD_ID_WHITE, V_STATUS);
      if (message.isAck()) {
      if (message.type == V_STATUS && message.sensor == CHILD_ID_MULTI) {
          Serial.println("Receiving initial value from controller");
          initialValueSentMULTI = true;
        stateMULTI = (bool)message.getInt();
        digitalWrite(MULTI_PIN, stateMULTI?MULTI_ON:MULTI_OFF);
      if (message.type == V_STATUS && message.sensor == CHILD_ID_WHITE) {
          initialValueSentWHITE = true;
        stateWHITE = (bool)message.getInt();
        digitalWrite(WHITE_PIN, stateWHITE?WHITE_ON:WHITE_OFF);
