  3. Arduino Nano Gateway for Vera - PCB link
28 Posts 12 Posters 24.8k Views 3 Watching
  • R
    R
    rosskinard
    wrote on last edited by rosskinard
    Here is the link to the Gateway PCB I created, had fabricated and tested.
    http://oshpark.com/shared_projects/qPdmZWG3
    Keep in mind that OSH Park charges by the board size, and you get 3 of the boards. This one costs $14.65 for 3 copies.
    Since few people need more than one it might make sense for users to pool together and order them as a group. That does mean one person will be responsible for ordering/paying and will have to ship the boards to the others.
    Vodden and SirMeili have called dibs on the 2 spare ones from my prototype order.
    Please give feedback.
    Parts needed:
    R1 and R3 - 220 ohm resistor (for RED and GREEN LEDs)
    R2 - 470 ohm resistor (for BLUE LED)
    R4 - 10K ohm resistor (INCLUDE button pull resistor)
    C1 - 4.7uF electrolytic capacitor (4mm diameter - 2mm lead spacing)
    Button - https://www.sparkfun.com/products/97
    2x4-pin header socket - http://www.ebay.com/itm/10PCS-2x4-Pin-8P-2-54mm-Double-Row-Female-Straight-Header-Pitch-Socket-Pin-Strip-/310727244114
    For the Nano socket...I used 2 of the 16-pin header sockets and cut one off with a Dremel to make a 15-pin strip.
    http://www.ebay.com/itm/10-Pcs-2-54mm-Pitch-16-Pin-Female-Single-Row-Straight-Header-Strip-PH-8-5mm-/181108150525
    Let me know if you have any questions.
    Ross
    • R
      R
      rosskinard
      Here is the Gateway assembled:
        Fantastic!
        • DvbitD
          DvbitD
          Dvbit
          Thanks. Fantastic.
          I am looking for somebody wanting to share the order with me.
          I will order from Italy (Rome) so ideally other Italians would be better (shipping costs wise) even though all Europeans are welcome.
          Please pm me.
          • clippermiamiC
            clippermiamiC
            clippermiami
            wrote on last edited by clippermiami
            Great looking work.
            It appears this is the USB version. Does anyone know of a PCB for the Ethernet version?
            • clippermiamiC
              clippermiamiC
              clippermiami
              Ross, i've sent you a ENC28J60 Ethernet device to work with. In looking at it however if not already you should be aware that there are two versions of this thing, the
              "narrow" one I sent you (about the width of the Ethernet connector) and a slightly wider one. The pinout is the same just wider so I thought i'd mention that in case you were not aware as you begin playing around with the PCB layout to accommodate the Ethernet adapter.
              clippermiamiC 2 Replies Last reply
              • clippermiamiC
                clippermiamiC
                clippermiami
                It seems like it would be practical to design a general purpose sensor board with a number of population options
                1. Populate with parts for external power
                2. Populate with parts for battery power
                3. I/O connections using screw terminals to allow connection various devices, power and ground. For example a screw terminal strip connected to the unused I/O pins, a ganged Vcc screw strip, a ganged Gnd Screw strip.
                The base board could carry a Nano (for simplicity ) and a radio. The terminal strips would allow attachment of a variety of I/O devices, light, temp, humidity, etc.So we'd end up with a single PCB that could serve as Gateway or remote sensor, power options, connection options, etc.
                • clippermiamiC clippermiami
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  @clippermiami Ross, just wondering if the Post Office delivered the Ethernet adapter?
                  I've received my Serial Gateway PCBs today and tomorrow I'll put one together. Hopefully I'll have better luck with your PCB version than I've had with the scramble-wire one I've been trying to get working for two weeks now
                    clippermiamiC
                    clippermiamiC
                    clippermiami
                    @clippermiami Ross, how is the Ethernet Gateway PCB coming?
                    R 1 Reply Last reply
                      R
                      R
                      rosskinard
                      @clippermiami Boards arrived...waiting on some sockets and a few other components to arrive so I can assemble it.
                      clippermiamiC 1 Reply Last reply
                      • R rosskinard
                        clippermiamiC
                        clippermiamiC
                        clippermiami
                        @rosskinard good news, looking forward to it
                          R
                          R
                          rosskinard
                          @clippermiami Still waiting...gotta love ePacket Delivery from China. Never can tell when you'll get something.
                          BulldogLowellB clippermiamiC 2 Replies Last reply
                          • R rosskinard
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            I'm watching/waiting too ;)
                            We should do a custom case for it using 3D printing.
                              clippermiamiC
                              clippermiamiC
                              clippermiami
                              @BulldogLowell That would be good. I'll buy one, you volunteering? My 3D printer is in the shop for service, it ran out of 3D :-)
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                I don't have any 3D either, but I have a good hookup from the last project!
                                I will just need to get a PCB. When you have it working, I'll buy one (or two) and then I'll do the housing.
                                  clippermiamiC
                                  clippermiamiC
                                  clippermiami
                                  @BulldogLowell I'm looking forward to it as well and plan to buy a board when it is available. Right now I'm using Ross's excellent serial gateway but I really want to get it on my LAN instead.
                                  • R rosskinard
                                    clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    @rosskinard Yes, it arrives when it gets there :-)
                                    • O
                                      O
                                      Omemanti
                                      Looks really great!,
                                      Are there any Dutch people who would like to order some?
                                      • daulagariD
                                        daulagariD
                                        daulagari
                                        @mark-van-winden : Yes, interested and living in Holland.
                                        Price for three boards is reasonable and shipping, if you are using first-class mail, should also be not too expensive.
                                        • daulagariD
                                          daulagariD
                                          daulagari
                                          Placed an order an no additional shipping costs!
                                          @mark-van-winden: Let me contact you, I like to two of them but if you still want one...
