Distance / Time measure and clock tuning
  • Hello All,
    I have built a nice little distance sensor using a Sensebender micro. The power footprint is very low: batteries would last several months.
    I'm trying to push it further. To do so, I'm wondering if I could play with the clock of the Atmega.
    I have understood that delay(), millis(), .. primitives don't behave appropriately after using clock_prescale_set() usage.
    Here is my question: is there a standard library (like NewPing) that handles these changes appropriately ?
    Regards,
    QQ.
  • Its not like "defaultish"-library but currently I am using this piece:
    https://github.com/fschaefer/Prescaler/blob/master/prescaler.h
    It features some code to get the "real" millis but all librarys that depend on arduino "delay" and "millis" function might do wrong delays/timings.
    All my nodes run at 1mhz to power them up with even 2xAA batteries @2,4volt or less. If some nodes have a more stable supply I use the library this way:
        uint8_t old_ps = getClockPrescaler();
        setClockPrescaler(0x00);
        oled.setCursor(0,1);
        oled << mymin << "," << sum << "," << mymax << "," << (diff < 1024 ? diff : 1024) << "," << (acc < 1024 ? acc : 1024) << " " << endl;
        oled << "sf: "  << spike_forgiveness << " " << endl;
        oled.setCursor(64,3);
        oled.print(readVcc());
        oled.print("mV  ");
        oled.setCursor(0,3);
        oled.print(RF24_readByteRegister(OBSERVE_TX),HEX);
        setClockPrescaler(old_ps);
    Regarding the power-footprint. Are you using the sleep-function of mysn?
  • Well, I've adapted the NewPing library in order to handle different clocks (using inline definition of millis(), micros(), ...) and....it works perfectly !
    Now I have a low power, low clock ultrasonic sensor that will last for years on a set of 2 AA batteries.
    If I'm not too busy, I might packed it up and publish it 🙂
    QQ.
  • At least in theory .. how much power does the ultrasonic-part consume and/or do you switch it off between measurements?
  • I will publish my voltage curve once I get enough history.
    And yes, I do shut down the sensor (and the booster, and the logic level adapter) between measures 😉
    Qq.
  • 1
  • 5
  • 198
11.3k
