Send RelayActuator state back to gateway
  • I have modded a sonoff with the mysensors firmware and added a feature that switches the light on and off by using a gpio pin. The problem is that I can't find a way to tell my gateway the updated state of the relay. If I turn in on from my Vera gateway but then turn it off with the physical switch it still shows as "on" on the vera, which makes it confusing. Is there a way to update it?
  • Admin
    Guess you mean the controller?
    It should be enough to use the send-function like in any other example-sketch.
  • @hek Thanks for the help, but I think I explained it wrong. I wanted my sonoff relay to send the updated state of the relay when I use the physical switch, because it updates the status on the Vera only when I turn it off and on from there. From what I read I can only use the send function to control the relay, but not to send its state back to my Vera.
  • Admin
    The send-function is used to send updates to the controller, in your case the physical-button-switch-change. Doing the send, does not control anything on the node itself.
