MQTT Gateway retained flag
  • I succeed to add the retained flag for the MQTT Gateway.
    To access this flag, I have inserted few modification into the file MyGatewayTransportMQTTClient.cpp
    The whole code and instructions for use are here: https://github.com/Mihai258/MySensors_MQTT_retained/tree/master
  • Admin
    Good!
    Maybe you can clean it up and create a proper pull request?
    A few PR notes:
    • The define should probably follow the the rest of the sketch configs by prefixing it with MY_
    • Adding it to /keywords.txt (gives highlighting it in the Arduino IDE)
  • I did not work too much with github and still find it somehow a little bit annoying for me, but I was trying to do this.
    I also have updated the new inserted constant as you advice.
    The new definition should be moved to the MyConfig.h , but now it was easier to modify only one file.
    My tests were done on MQTT Gateway made by Arduino Uno (clone) + Ethernet shield 5100 and it works very nice.
11.3k
