Openhab2.0 binding
  • Re: openHAB 2.0 binding
    I have an arduino pro mini driving a 5v relay module, turning on and off a bunch of LEDs.
    In OpenHab logs I see which seems that Node 2 is sending 3 ACK packets. 0_1485813732368_Capture.PNG
    This behavior is not consistent, other times seems only one packet is sent:
    Running 2.1.1 library from MySensors download link.
    Not sure if this is normal behavior or should I open a bug ticket ?
    Thx.
  • Hero Member
    @frg Thank you for reporting! The binding is not working as expected, because it resends the message two times although it already received an ACK from the node.
    The binding is producing more traffic than needed, I need to look into that.
    Please file an issue (with .things and .items file) here: https://github.com/tobof/openhab2-addons
  • 22
  • 135
  • 10
  • 132
  • 7
