Servo only does 90 degrees
  • Hello all,
    This night I finally made some time to build a gateway and a device to use a servo.
    The only issues I had was finding drivers to programm the nano and the uno ( I use the uno for the servo).
    Now , there is 1 issue. The servo only turns max 90 degrees. I uploaded the sketch without changing anything.
    http://www.mysensors.org/build/servo
    It should to a full 180 degrees I think ? it is a standard futaba S3001.
    The servo is good ( I checked with my RC transmitter and reciever)
    anyone has an idea how to troubleshoot?
    edit ... oh ... that's wierd... when I use the slider or open-close , it does the 90 degrees. but when I click up-down, it does full 180 degrees ...... why not with the slider??
    thanks,
    Cor
  • Just recieved a responce via another forum.
    I ran in the same problem. I fixed it by replacing the line:
    myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * val); // sets the servo position 0-180
    by the following 2 lines of code:
        val = map(val, 0, 100, 0, 180); // scale 0%-100% between 0 and 180)
        myservo.write(val);       // sets the servo position 0-180
  • 1
  • 15
  • 24
  • 10
11.3k
